OnCommand Workflow Automation
Overview of OnCommand Workflow Automation
OnCommand Workflow Automation (WFA) is a software solution that helps to automate storage management tasks, such as provisioning, migration, decommissioning, data protection configurations, and cloning storage. You can use WFA to build workflows to complete tasks that are specified by your processes. WFA supports ONTAP.
A workflow is a repetitive and procedural task that consists of sequential steps, including the following types of tasks:
  • Provisioning, migrating, or decommissioning storage for databases or file systems
  • Setting up a new virtualization environment, including storage switches and datastores
  • Setting up storage for an application as part of an end-to-end orchestration process
Storage architects can define workflows to follow best practices and meet organizational requirements, such as the following:
  • Using required naming conventions
  • Setting unique options for storage objects
  • Selecting resources
  • Integrating internal configuration management database (CMDB) and ticketing applications
WFA features
  • Workflow design portal to build workflows
    The workflow design portal includes several building blocks, such as commands, templates, finders, filters, and functions, that are used to create workflows. The designer enables you to include advanced capabilities to workflows such as automated resource selection, row repetition (looping), and approval points.
    The workflow design portal also includes building blocks, such as dictionary entries, cache queries, and data source types, for caching data from external systems.
  • Execution portal to execute workflows, verify status of workflow execution, and access logs
  • Administration/Settings option for tasks such as setting up WFA, connecting to data sources, and configuring user credentials
  • Web service interfaces to invoke workflows from external portals and data center orchestration software
  • Storage Automation Store to download WFA packs. The ONTAP 9.7.0 pack is bundled with WFA 5.1.
WFA license information
No license is required for using the OnCommand Workflow Automation server.
