OnCommand Workflow Automation
Ports required for Workflow Automation
Contributors netapp-aoife
If you are using a firewall, you must be aware of the required ports for Workflow Automation (WFA).
The default port numbers are listed in this section. If you want to use a non-default port number, you must open that port for communication. For more details, see the documentation on your firewall.
The following table lists the default ports that should be open on the WFA server:
Port Protocol Direction Purpose
80, 443
HTTP, HTTPS
Incoming
Opening WFA and logging in
80, 443, 22
HTTP, HTTPS, SSH
Outgoing
Command execution (ZAPI, PowerCLI)
445, 139, 389, 636
Microsoft-DS, NetBIOS-ssn, AD LDAP, AD LDAPS
Outgoing
Microsoft Active Directory LDAP authentication
161
SNMP
Outgoing
Sending SNMP messages on the status of workflows
3306
MySQL
Incoming
Caching read-only user
25
SMTP
Outgoing
Mail notification
80, 443, 25
HTTP, HTTPS, SMTP
Outgoing
Sending AutoSupport messages
514
Syslog
Outgoing
Sending logs to a syslog server
The following table lists the default ports that should be open on the Unified Manager server:
3306
MySQL
Incoming
Caching data from Active IQ Unified Manager 6.0 and later
The following table lists the default port that should be open on the VMware vCenter:
443
HTTPS
Incoming
Caching data from VMware vCenter
The following table lists the default port that should be open on the SNMP host machine:
162
SNMP
Incoming
Receiving SNMP messages on the status of workflows
