Protect BlueXP workload factory for Builders projects
Contributors netapp-mwallis
Protect your Builders projects by creating on-demand snapshots directly from workload factory. Snapshots of a project are stored in the filesystem that was associated with the project when it was created.
Create a snapshot of a project
You can create a snapshot of a project by following these steps.
Steps
  1. Log in to workload factory using one of the console experiences.
  2. In the Builders tile, select Go to Projects page.
  3. On the Projects page, select the option button for the project you want to snapshot.
  4. In the resulting menu, select Create a snapshot.
  5. In the Create snapshot dialog, choose a name for the snapshot and select Create.
