Deregister a resource in NetApp Workload Factory for Databases
Contributors netapp-rlithman
Deregister a resource, such as a Microsoft SQL Server instance or an Oracle database, if you no longer want to deploy or monitor resources from the NetApp Workload Factory console. Deregistering resources also removes the amount of FSx for ONTAP storage capacity used by the instance.
You can register the resource again.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Databases.
  3. From the Databases menu, select Inventory.
  4. In the Inventory, select the engine type: Microsoft SQL Server, Oracle, or PostgreSQL.
  5. Locate the resource you want to deregister, select the action menu, and then select Deregister.
