Manage database clones in NetApp Workload Factory for Databases
Manage your sandbox clones in NetApp Workload Factory for Databases to keep your development and testing environments reliable and cost-effective. Verify that a clone's data is intact, connect a clone to your CI/CD pipeline to automate software delivery, or refresh, revert, or split a clone to align it with your current development needs. When you no longer need a clone, delete it to free up storage capacity.
Check sandbox data integrity
Run an integrity check to determine if sandbox clone data is intact or corrupt in NetApp Workload Factory for Databases.
When you create a sandbox clone from a source database while it is busy, the clone's data may not be in sync with the most recent snapshot of the source database. This operation checks the integrity of all the objects in the sandbox clone to determine if the sandbox clone data is current.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Databases menu, select Sandboxes.
In Sandboxes, select the actions menu of the sandbox clone to check integrity for.
Select Run integrity check.
In the Integrity check dialog, click Integrity check.
Check the status of the integrity check in Sandboxes or in Job monitoring.
If the integrity check fails, we recommend that you do not use the sandbox clone and create a new sandbox clone.
Connect a sandbox clone to CI/CD
Connect a sandbox clone to a continuous integration and continuous delivery (CI/CD) pipeline with REST API code to improve software delivery via automation in NetApp Workload Factory for Databases.
To deliver a new version of software automatically to your database clone, you should connect to a CI/CD pipeline. Use the REST API code provided from this operation to make the connection.
Select the menu
and then select Databases. -
In Sandboxes, select the actions menu of the sandbox clone to connect to CI/CD tools.
Select Connect to CI/CD tools.
In the CI/CD dialog, copy or download the REST API code needed to connect to CI/CD tools.
Click Close.
Delete a database clone
Delete a sandbox clone in NetApp Workload Factory for Databases when you no longer need it and want to free up storage capacity.
Select the menu
In Sandboxes, select the action menu of the sandbox clone you want to delete.
Select Delete.
In the Delete dialog, select Delete to confirm deletion.
Refresh a database clone
Refresh a database (sandbox) clone in NetApp Workload Factory for Databases so that it is equivalent to the source database at the current moment or a previous point in time.
Refreshing a clone updates the clone either to the source database at the current moment or to a snapshot of the source database taken at a previous point in time. Any changes made to the sandbox clone will be deleted.
A refresh is only possible when the source database is active.
To refresh a database clone from a snapshot, the source database must have at least one snapshot for the operation.
Select the menu
In Sandboxes, select the action menu of the sandbox clone you want to refresh.
Select Refresh.
In the Refresh dialog, select one of the following options:
Refresh to current time
Refresh to point in time
For this option, select the database snapshot from the dropdown menu to refresh to.
Click Refresh.
Revert a database clone
Revert a database (sandbox) clone to its original version at the time of creation in NetApp Workload Factory for Databases.
When you clone a database, the clone at creation is a baseline clone. The data in the cloned database is the same as the source database at the time of creation. As data in a database clone changes over time, you might want to revert the data back to the baseline when the clone was first created. This operation is called re-baselining a clone. Re-baselining a clone rather than creating a new clone saves space; however, any changes made to the database clone will be deleted.
Select the menu
In Sandboxes, select the action menu of the database clone you want to revert.
Select Re-baseline.
In the Re-baseline dialog, select Re-baseline.
Split a database clone
In NetApp Workload Factory for Databases, splitting a database clone from its source database creates a new database which will consume a certain amount of storage capacity. The clone gets deleted when the split is complete and the new database appears in the Inventory.
Consider how much storage capacity is needed for the new database. If needed, increase file system capacity for the FSx for ONTAP file system before you begin.
Select the menu
In Sandboxes, select the action menu of the database clone you want to split.
Select Split.
In the Split dialog, select Split.
View a clone's connection information
View and copy the connection information of a database clone in NetApp Workload Factory for Databases.
Select the menu
In Sandboxes, select the action menu of the sandbox clone to view its connection information.
Select Show connection info.
In the Show connection info dialog, copy the connection information if needed.
Select Close.
