Create an EDA workspace
Contributors netapp-mwallis netapp-sineadd
A workspace in NetApp Workload Factory for EDA is a Perforce representation of a project at a specific moment in time. Workspaces are created using a project snapshot as a basis. You can create new workspaces within an EDA project. You can create workspaces from the Perforce UI.
Before you begin
Ensure you have integrated EDA with the Perforce Helix Visual Client. See Integrate EDA with Perforce for more information.
Steps
  1. Log in to Perforce.
  2. In the Perforce menu, select View > WF.
    The Workload Factory login screen appears within the Perforce UI.
  3. Log in using one of the console experiences.
  4. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select EDA.
  5. Select CI/CD.
  6. Select Create project and then select Create workspace.
  7. On the Create a workspace project page, provide the following:
    1. Select a snapshot to use as a basis for the workspace.
    2. Enter a name for the workspace.
    3. Optionally, enter a user identifier to claim the workspace. This identifier should match the Perforce user ID of the developer that will use this workspace.
  8. Select Create.
Result
The workspace is created, and appears in the list of workspaces on the Workspaces page.
