Learn about the Overview dashboard in Workload Factory for EDA
The Overview dashboard gives IT administrators one place to monitor EDA workloads across multiple FSx for ONTAP file systems. Use it to quickly check system health and usage, choose where to place new volumes or jobs, find volumes or SVMs that may need to be moved, and see when it's time to increase capacity or throughput.
Overview
The Overview dashboard collects CloudWatch metrics for all FSx for ONTAP file systems associated with your configured AWS credentials.
It includes:
Cluster health status: A summary at the top highlights latency events, SSD usage, throughput mode status, capacity recommendations, and ONTAP EMS events across your file systems.
Clusters table: A searchable table that shows usage and performance for each cluster. You can filter and sort the data, move between pages, and export it as a CSV file.
It helps you:
Place new volumes and rebalance workloads
Plan capacity or throughput scaling
Monitor cluster health at scale
Make informed decisions about volume placement
Identify clusters approaching capacity limits
Dashboard components
Cluster health shows a quick view of activity across the file systems you selected. This appears only if at least one FSx for ONTAP link is connected to your file systems.
The health status includes the following areas:
- Latency
Shows the number of latency events found in the selected file systems. This information appears only if latency monitoring is enabled.
- File system elasticity
SSD capacity: Shows how many file systems use Automate, Recommend, or None to manage SSD capacity.
Throughput: Shows how many file systems use Automate, Recommend, or None to manage throughput.
- ONTAP events
Displays the number of EMS events detected, categorized by Capacity, Availability & protection, and Security & other.
Clusters table
The clusters table provides a detailed view of each FSx for ONTAP file system, filtered by your active region and AWS account selections. Data is collected from CloudWatch metrics.
Use the table to:
Identify file systems approaching capacity limits (SSD usage column)
Compare throughput demand to provisioned throughput SKU (Throughput usage P99 column)
Track performance metrics across multiple clusters
Check link configuration status (Associated link column) - Connection validity is verified daily
Select multiple clusters for bulk parameter updates
Select a file system to view cluster details, including cluster information, SSD capacity, and graphs. In the cluster details view, use the Throughput and SSD Capacity options to switch views.
The Throughput view shows client throughput and resource utilization. The SSD Capacity view shows SSD usage trends and capacity recommendations.
SSD capacity management
Management modes
- Notify only (Recommend mode)
Workload Factory analyzes how you use your SSDs and suggests when to increase capacity. You review these suggestions and decide whether to apply them. This keeps you in full control of capacity changes while still benefiting from automated analysis.
- Automate
Workload Factory automatically adds more SSD space when usage reaches set limits. It handles this on its own, so no manual work is needed. This works well for environments that prefer automatic management.
- None
If you have not enabled SSD capacity management, the system does not make capacity recommendations or take automated actions. Use this option if you want to manage capacity yourself.
SSD management parameters
Parameters control how the capacity management system analyzes and acts on your SSD usage:
- Threshold (10-90%)
The SSD usage percentage that triggers capacity recommendations or automation actions. For example, a threshold of 80% means recommendations or actions occur when SSD usage reaches 80%. This setting is available in both Recommend and Automate modes.
- Lookback (1-200 hours)
The time period used to analyze historical SSD usage patterns. A longer lookback period provides more historical context for capacity decisions. Available in Automate mode only.
- Lookahead (1-200 hours)
The time period used to project future capacity needs. A longer ahead period plans further into the future for capacity growth. Available in Automate mode only.
You can set these parameters for each file system individually, or use bulk editing to apply the same settings to multiple file systems.
Throughput management
You can configure elastic throughput increase behavior for one or multiple file systems.
Management modes
Workload Factory evaluates throughput pressure and provides recommendations for you to apply.
- Automate
Workload Factory increases throughput automatically when configured conditions are met.
- None
If you have not enabled Throughput management, the system does not make recommendations or take automated actions. Use this option if you want to manage capacity yourself.
Throughput parameters
The throughput configuration dialog includes:
Utilization threshold (50-100%, default 80%): Throughput utilization percentage that triggers recommendations or automation.
Advanced throughput parameters are available in an expandable Advanced configuration section.
Evaluation window (hours) (12-72 hours, default 24)
Breached metrics (%) (default 66%): Percentage threshold for determining breach
Consecutive breach window (hours) (1-5 hours, default 2)
Consecutive breach metrics (%) (default 95%)
Minimum latency (ms) (default 10 ms)
Maximum throughput SKU (default None)
File system elasticity recommendations
When Workload Factory is in Automate or Recommend mode, it automatically checks each FSx for ONTAP file system and recommends capacity changes. It regularly scans the system to determine whether SSD capacity or throughput should be adjusted. When management is enabled, the file system details page shows SSD capacity and throughput together with historical trends and recommended adjustment points.
When a recommendation is identified:
You receive an immediate notification based on your Workload Factory notification settings.
Identify file systems with recommendations by filtering the Clusters table.
The interface shows the total number of file systems that currently have active recommendations.
The recommendation explains the suggested change and the reasoning behind it, such as: We recommend increasing the SSD size based on your file system SSD usage pattern.
Understanding capacity decision points
The SSD usage graph shows when the system recommended capacity changes or made automatic adjustments. These markers indicate how the system managed capacity over time. If SSD capacity management is turned off, the graph shows only past usage and does not display recommendations or automatic actions.
- Recommendation decision points
Appear when the system detects that more SSD capacity is needed. If capacity has not been increased, these points might appear as often as every 30 minutes. The graph shows each decision point when possible. If the selected time range is too dense, the points are grouped together.
- Automation decision points
Appear when the automation system tries to increase SSD capacity. They show whether the action succeeded or failed.
Use the SSD usage history graph to:
See how often you need to change storage size
Decide whether automation or recommendation mode fits your usage patterns better
Spot repeated storage shortages
Plan future storage needs based on growth over time
Investigate why automation attempts failed
Understanding throughput decision points
The client throughput graph shows when the system recommended throughput changes or automatically adjusted throughput. These markers also appear in the graph legend. If throughput management is off, the graph shows only past throughput and does not display recommendations or automatic changes.
Shown when the system detects that throughput needs to increase. Hover over a decision point to see the details. If multiple recommendations occur at the same timestamp, the point shows the number of recommendations and details for the most recent one.
Shown when the automation system tries to increase throughput. Hover over a decision point to see the details. If the increase succeeded, the new SKU is also shown. If it failed, a short explanation is shown instead. If multiple failures happen at the same time, the point shows the number of failures and details from the most recent one.
Use the client throughput graph to:
See how often you need more throughput
Choose whether automation or recommendation mode works better for your needs
Identify recurring throughput limits
Plan future throughput needs as usage grows over time
