Learn about the Projects dashboard in Workload Factory for EDA
The Projects dashboard lets IT admins and project managers see how projects use storage across FSx for ONTAP file systems and volumes. It shows storage usage patterns so you can spot projects using the most resources, track costs, and adjust storage before capacity or performance problems affect EDA simulations.
How the Projects dashboard works
The Projects dashboard shows CloudWatch metrics for all FSx for ONTAP volumes linked to your AWS credentials. You can create up to five filters using AWS tags to organize and view the data by project, team, application, or other categories.
The dashboard helps you:
Plan capacity and understand costs
Use data to decide how to assign resources
Spot projects that use a lot of resources
Track costs by project or team
Adjust storage before problems occur
For proactive latency performance monitoring, see Learn about latency monitoring.
CloudWatch metrics collected
The dashboard collects and displays the following CloudWatch metrics:
Provisioned capacity: Volume-level metric representing the provisioned storage capacity.
Used capacity: Volume-level metric representing the storage used.
Average/Maximum throughput: Calculated as the average or maximum of the sum of DataReadBytes and DataWriteBytes over the specified time period.
Average/Maximum IOPS: Calculated as the average or maximum of the sum of DataReadOperations, DataWriteOperations, and MetadataOperations over the specified time period.
Custom filters
Custom filters help you organize dashboard data to match how your organization works. Set filters by project, team, or cost center so you can quickly find the data you need without sorting through unrelated information. This makes it easier to plan capacity, track costs, and monitor performance.
You can configure up to five custom filters based on your AWS tags.
Filter label name: The display name that appears in the dashboard
AWS tag key name: The actual AWS tag key used on your resources
Selection type: Single selection or multi-selection
If you don't configure any custom filters, the default filters—file system, volume type, and time range—will still be available, so you can view and use your dashboards.
AWS tags
AWS tags are metadata for your AWS resources. They help you categorize your AWS resources in different ways, for example, by project, application, or business unit.
To use custom filters, add AWS tags to your FSx for ONTAP volumes that match your needs, such as tags for projects, teams, or business units.
For more details about tagging, see What are tags? and AWS Resource Groups Tagging API Reference.
Volume details
The dashboard provides viewing modes to help you analyze your storage metrics at different levels of detail.
Total view
The Total view (default) shows combined metrics for all volumes that match your selected filters. It gives you a quick overview of overall storage performance, including total capacity, IOPS, and throughput.
Use this view to:
Understand overall trends
Plan for future capacity needs
Report on total resource consumption across projects or teams
Volume view
The Volume view shows how individual volumes perform over time. It displays the top 10 volumes for each metric. This helps you see which volumes use the most resources and how they behave during the selected time period.
Use this view to:
Find what is slowing performance
Identify storage volumes that might need to be resized
See which projects or workloads are using the most resources
Volume metrics displayed
When you view individual volumes, the dashboard displays the top 10 volumes out of your total number of volumes for each metric:
Volume used capacity: Shows volumes with the highest current used capacity.
IOPS: Shows volumes with the highest average IOPS during the selected time period.
Throughput: Shows volumes with the highest average throughput during the selected time period.
The dashboard displays only the top 10 volumes for each metric. If you have more than 10 volumes, some volumes might not be displayed in the detailed view. |
When the same volumes appear in multiple metrics, the dashboard uses the same colors in the legend so you can easily follow those volumes across different metrics.
Interactive volume data
Hover over the chart to see exact values at specific times. This helps you link performance changes to events or time periods. The detailed data can help you find performance problems, confirm that optimizations worked, and explain resource usage to others.
When you hover over any volume line in the graphs, you can view:
Volume used capacity: Volume name, used capacity at that point in time, and allocated capacity
IOPS: Volume name, average IOPS for the time range, and maximum IOPS for the time range
Throughput: Volume name, average throughput for the time range, and maximum throughput for the time range
