Manage EDA projects in Workload Factory for EDA
Contributors netapp-mwallis netapp-sineadd netapp-rlithman
You can manage EDA projects to control how your code and artifacts are managed for each project in NetApp Workload Factory for EDA.
Create a project
You can create a new EDA project so that you can leverage the data protection features of your FSx for ONTAP file system for your code and artifacts. .Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select EDA.
  3. Select CI/CD.
  4. Select Add project.
  5. On the Create project page, provide the following:
    1. Project name: Enter a name for the project.
    2. Description: Enter a description for the project.
    3. Filesystem: Provide the following:
      1. Credentials: Select the Amazon AWS credentials to use. EDA uses these credentials to discover FSx for ONTAP file systems that you can use with this project and to create clones and snapshots of projects.
      2. Region: Select the region that this FSx for ONTAP file system resides in.
      3. FSx for ONTAP file system: Select an FSx for ONTAP file system to use with this project.
        You can only select file systems that are configured with a link. Learn more about links.
      4. Choose a volume: Select a volume on which to store the project; EDA uses this volume as a software repository.
        You can only select volumes that are configured as an NFS share.
    4. Operation policies: Provide limits for project clones:
      1. Maximum retention in days: Enter the maximum number of days that a clone should be retained. After this number of days, Workload Factory removes the clone.
      2. Maximum number of clones per user or group: Enter the maximum number of clones that can be provisioned for a user or group.
      3. Maximum clone size in GiB: Enter the maximum size in GiB of a project clone.
    5. Access policies: Explicitly grant project access to specific users or groups:
      1. Policy enforcement scope: Enter single IP addresses or IP address ranges to limit project access to only those IP addresses or ranges.
        For example: 172.16.0.0/24
      2. User or group identifiers: Enter user or group identifiers to limit project access to only those users or groups.
        For example: User1234
  6. Select Create.
Result
The project is created, and appears in the list of projects on the Projects page.
View existing projects
You can view existing projects created in NetApp Workload Factory for EDA by following these steps.
Steps
  3. Select CI/CD.
  4. Select Go to Projects page.
  5. View the existing projects listed on the Projects page.
Edit a project
You can edit the settings of a project at any time.
Steps
  3. Select CI/CD.
  5. On the Projects page, select the option button for the project you want to edit.
  6. Make any needed changes to the project configuration.
  7. Select Save.
View a project's workspaces
A clone or snapshot of a project is known as a workspace. When you create a workspace, it is retained for as long as the project's operation policy allows. You can view existing workspaces for a project by following these steps.
Steps
  3. Select CI/CD.
  5. On the Projects page, choose a project and select View.
  6. View the status and details of all workspaces for this project.
  7. If you see alerts or warnings for a workspace, hover over the alert or warning icon to see the reason.
Delete a project
You can delete a project when it is no longer needed by following these steps.
Steps
  3. Select CI/CD.
  5. On the Projects page, select the option button for the project you want to delete.
  6. Select Delete.
  7. In the confirmation dialog, select Delete.
Result
The project is deleted, and any code or artifacts associated with the project are deleted from the volume. Snapshots and clones of the project are retained.
