Workload Factory for EDA requirements
Ensure that Workload Factory and AWS are set up properly before you use NetApp Workload Factory for EDA. This includes having your AWS log in credentials, a deployed FSx for ONTAP file system, and more.
- Workload Factory login and account
You'll need to set up an account with Workload Factory and log in using one of the console experiences.
- AWS credentials and permissions
You need to add AWS credentials to Workload Factory with read/write permissions, which means you'll be using Workload Factory in read/write mode for EDA.
Basic mode and Read-only mode permissions are not supported at this time.
AWS credentials are also required to use the latency monitoring feature, which collects CloudWatch metrics for volume performance analysis. To receive notifications for latency events, configure notification preferences in Workload Factory settings. Optional AI analysis for complex latency scenarios is available when NetApp-managed AI analysis is enabled. Learn about latency monitoring. |
- FSx for ONTAP file system
You need a minimum of one FSx for ONTAP file system:
The file system will be used by EDA to store the projects and workspaces that you create.
This FSx for ONTAP file system must use FlexVol volumes. FlexGroup volumes are not supported.
You'll need to know the AWS region, VPC, and subnet where the AWS FSx for ONTAP file system resides.
You'll need at least one volume in the file system with the following configuration:
The volume must be configured as an NFS share.
The file system must be configured with a link. Learn more about links.
You'll need to consider the tag key/value pairs that you want to apply to the AWS resources that are part of this deployment (optional).
