Add HA pairs to a file system in NetApp Workload Factory
Add high-availability (HA) pairs to scale out an FSx for ONTAP second-generation Single-AZ file system in NetApp Workload Factory to increase performance and capacity. This expansion gives you more performance scalability and flexibility over first-generation file systems.
The new HA pairs use the same SKU and capacity per HA pair.
Adding HA pairs isn't supported for the following:
Multi-AZ HA deployments or first-generation FSx for ONTAP file systems
FSx for ONTAP file systems with more than five storage VMs
FSx for ONTAP file systems with iSCSI LUNs
Configurations that have maximum or close to maximum SSD capacity or have reached IO allocation limits
Consider the following about adding HA pairs:
HA pair removal: You can't remove HA pairs after you add them to the file system.
Operation time and limitations: Adding HA pairs might take approximately 30 minutes. Consider adding HA pairs during a maintenance window or during low activity periods. In addition, adding HA pairs limits other operations like adding more HA pairs, provisioning IOPS, increasing SSD capacity, and updating throughput capacity.
IO allocation: Automatic IO allocation depends on total storage capacity. User-configured IO allocation is multiplied by the number of HA pairs added.
NVMe cache: When adding HA pairs, NVMe cache is enabled by default. We recommend turning off NVMe cache for heavy workloads.
Number of HA pairs: We recommend expanding your file system to an even number of HA pairs for balanced data distribution across HA pairs.
LUN creation: LUN creation is possible on a second-generation Single-AZ file system only if LUNs don't already exist on the file system when adding HA pairs. LUN creation is only supported on a file system with six HA pairs or fewer.
Do the following before you add HA pairs to a file system:
Remove all iSCSI LUNs to scale out the file system.
Make sure that the file system has no more than five storage VMs.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP under Information, select the pencil icon next to HA pairs.
In the Add HA pairs dialog, select the number of HA pairs to add to the file system.
Select Add to confirm the addition of the HA pairs.
Workload Factory initiates the process to add the HA pair(s) to the file system. The file system isn't available for other operations like volume creation until the HA pairs are added. You can monitor the progress of the operation in the Tracker tab.
