Adjust volume capacity in NetApp Workload Factory
Manually adjust the volume capacity of a volume at any time from the NetApp Workload Factory console.
Optionally, you can enable the autogrow feature to let Workload Factory manage volume capacity for you.
You can adjust volume capacity by increasing or decreasing the provisioned size of a volume. The following table shows the minimum and maximum volume sizes by volume type:
| Volume type | Minimum size | Maximum size |
FlexVol volume |
20 MiB |
300 TiB |
FlexGroup volume |
800 GiB |
2 PiB |
For an iSCSI LUN, increasing the size of the volume also increases the size of the host LUN. After you increase volume capacity, follow the procedure provided by your host operating system to discover the new size of the LUN and expand the file system of the LUN.
Decreasing volume size is supported only for NFS and SMB/CIFS volumes.
To adjust volume capacity, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After the link associates, return to this operation.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select Volumes explorer.
Select the actions menu for the volume you want to modify.
Select Basic actions, then Adjust volume capacity.
In the Adjust volume capacity dialog, set the Provisioned capacity and unit.
Select Adjust to apply the changes.
