Amazon FSx for NetApp ONTAP
Delete the S3 access points for a volume in NetApp Workload Factory
Contributors netapp-rlithman
Delete existing S3 access points from a volume in NetApp Workload Factory.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select Volumes explorer.
  4. Select the actions menu for the volume you want to manage S3 access points for, then select Advanced actions, and then Manage S3 access points.
  5. Select the actions menu for the S3 access point to delete and then select Delete.
  6. In the Delete an S3 access point dialog, select Delete to delete the S3 access point from the volume.
    Workload Factory doesn't delete the inventory or journal table, but you can remove them manually from the AWS Management Console.
