Edit the S3 access points for a volume in NetApp Workload Factory
Update S3 access point details and manage tags for a volume in NetApp Workload Factory.
You can also enable or disable the Inventory table for the access point. The inventory table generates metadata for all objects accessible to the S3 access point and incurs AWS S3 request costs. Refer to Amazon S3 pricing documentation for more information.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select Volumes explorer.
Select the actions menu for the volume you want to edit S3 access points for, then select Advanced actions, and then Manage S3 access points.
From the Manage S3 access points screen, select the actions menu and then select Edit access point.
Make updates and then select Apply.
To set up the infrastructure for the journal table feature, you must select Internet as the network configuration for the S3 access point. Learn how to set up the Journal table infrastructure for NetApp Workload Factory.
