Manage the block devices for a file system in NetApp Workload Factory
From the NetApp Workload Factory console, you can manage the block devices for your FSx for ONTAP file systems. Management tasks include viewing block device details, increasing capacity, managing client access, archiving block device data, and deleting block devices.
Block devices, or LUNs (logical unit numbers), are volumes that contain file systems in a SAN environment and can be accessed by hosts over a network.
You can manage block devices for FSx for ONTAP file systems that use the iSCSI protocol.
You must associate a link to manage block devices. Learn how to associate an existing link or to create and associate a new link. After you associate the link, return to this operation.
You must have an existing block device to view and manage.
View block device details
View details for an existing block device at any time.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the Block devices tab.
Navigate to the actions menu for block device and then select View details.
General details, consumption, access, and protection information for the block device are displayed.
Increase the capacity of a block device
Increase the capacity of an existing block device at any time.
Select the menu
Navigate to the actions menu for the block device and then select Increase capacity.
Enter the new capacity for the block device and select the unit.
Select Increase to apply the changes.
After you increase the size of the block device, follow the procedure provided by your host operating system to discover the new size of the block device and expand the file system on it. |
Manage client access for a block device
You can manage client access for an existing block device at any time by creating igroups, and adding or removing block devices and host initiators.
Select the menu
Navigate to the actions menu for the block device and then select Manage client access.
If no igroup exists, create a new igroup by selecting Create igroup, and then do the following:
Block device name: Enter a block device name. You can select multiple block devices to associate with the igroup.
Operating system type: Select the operating system type.
igroup name: Enter an igroup name.
igroup description: Optionally, enter an igroup description.
Host initiators: Enter one or more host initiators. These initiators must follow iSCSI qualified (IQN) format.
Select Create.
If an igroup already exists, select Edit client access to add or remove block devices and host initiators from the igroup and then select Apply.
Archive the data of an orphaned block device
Block devices that are no longer mapped to a client or unused for seven consecutive days are classified as orphaned block devices. You can archive the data of an orphaned block device to the capacity pool tier to reclaim SSD capacity.
Select the menu
Under Orphan devices, select View and reclaim capacity.
On the Reclaim space for unused block devices screen, select one or more block devices to archive the data and reclaim the capacity.
Select Archive.
Delete a block device
Block devices that are no longer mapped to a client or unused for seven consecutive days are classified as orphaned block devices. This operation unmaps and deletes the selected block device. If the host FlexVol volume doesn't contain any block devices, Workload Factory also deletes it.
Select the menu
Select Delete.
