Amazon FSx for NetApp ONTAP
Manage FSx for ONTAP file system tags in NetApp Workload Factory
Contributors netapp-rlithman
Tags can help you categorize your resources. You can add, edit, and remove tags for a file system at any time in NetApp Workload Factory.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select FSx for ONTAP.
  4. From FSx for ONTAP, select the actions menu of the file system to update and then select Manage file system tags.
  5. In the Manage file system tags dialog, add, edit, or remove tags as needed.
    The maximum number of tags you can apply to a file system is 50.
  6. Select Apply.
