Manage the igroups for a file system in NetApp Workload Factory
Use the NetApp Workload Factory console to manage igroups and control client access for FSx for ONTAP block devices. You can view igroup details, manage client access, and delete igroups.
You must associate a link to manage igroups. Learn how to associate an existing link or to create and associate a new link. After you associate the link, return to this operation.
You must have an existing igroup to view and manage.
Manage client access for an igroup
You can manage client access for an existing igroup at any time.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the Block devices tab.
Select the resource type Initiator groups (igroups) to view existing igroups.
Go to the actions menu for the block device and select Manage client access.
Review the client access details displayed for the igroup.
To make changes to client access, select Edit client access.
In the Edit client access dialog, you can edit the following:
igroup name
igroup description
Storage VM name
Block device name
Operating system type
Host initiators
Select Apply.
Delete an igroup
You can delete an existing igroup when it is no longer needed.
Select the menu
Navigate to the actions menu for the block device and then select Delete initiator group.
In the Delete initiator group (igroup) dialog, type "delete" to confirm that you want to delete the igroup, and then select Delete.
