Manage your replication relationships in NetApp Workload Factory
Manage your replication relationships in NetApp Workload Factory. You can pause, resume, reverse, stop, and delete replication relationships between source and target volumes. You can also change the replication schedule of the source volume, and limit the max transfer rate for your replication relationships.
Change the replication schedule of a source volume
Change the replication schedule of the source volume in a replication relationship in NetApp Workload Factory.
Choose how frequently snapshots from the source volume are transferred to the replicated volume to match your recovery point objectives (RPOs).
When an on-premises ONTAP cluster is the target for the replication relationship, changing the replication schedule isn't supported.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the file system to update and then select Manage.
From the file system overview, select the Replication relationships tab.
In the Replication relationships tab, select the actions menu of the replication relationship schedule to change.
Select Edit replication interval.
In the Edit replication interval dialog, select the frequency of snapshot transfer from the source volume. Select one of the following frequencies:
Every 5 minutes
Hourly
Every 8 hours
Daily
Weekly
Select Apply.
Limit the max transfer rate of a replication relationship
Limiting the max transfer rate is optional but recommended. Without a limit, network and application performance might decline.
For critical workloads, such as FSx for ONTAP file systems used primarily for disaster recovery, an unlimited transfer rate is recommended.
Consider how much bandwidth to allocate for replication.
Select the menu
In the Replication relationships tab, select the actions menu of the replication relationship to limit the max transfer rate for.
Select Edit max transfer rate.
In the Edit max transfer rate dialog, select Limited and enter the max transfer limit in MB/s.
Alternatively, select Unlimited.
Select Apply.
Manually update snapshot data in a replication relationship
A replication relationship has a set replication schedule, but you can manually update snapshot data transferred between source and target volumes in NetApp Workload Factory at any time.
Select the menu
In the Replication relationships tab, select the actions menu of the replication relationship to update.
Select Update.
In the Update dialog, select Update.
Pause a replication relationship
Pause a replication relationship to stop scheduled replication updates from the source volume to the target volume. The target volume transitions from read-only to read/write. Both volumes continue to share the latest replication snapshot as a new baseline for later resynchronization.
If you pause when a transfer is in progress, the transfer is not affected, and the relationship becomes "Quiescing" until the transfer completes. If the current transfer aborts, it is now a future transfer and will not restart.
Select the menu
In the Replication relationships tab, select the actions menu of the replication relationship to pause.
Select Pause (Quiesce).
In the Quiesce relationship dialog, select Quiesce.
The relationship pauses and its status shows as "Paused".
Resume a paused replication relationship
When you resume a replication relationship, any changes to the target volume while the replication was stopped are deleted. The target volume transitions from read/write to read-only, and receives updates from the source volume at the scheduled replication interval again.
Any data written to the original source volume between the last data replication and the time that the source volume is disabled is not preserved. |
Select the menu
In the Replication relationships tab, select the actions menu of the replication relationship to resume.
Select Resume.
In the Resume relationship dialog, select Resume.
The relationship resumes and its status shows as "Replicated".
Reverse a replication relationship
Reverse a replication relationship so that the target volume becomes the source volume.
Reverse operations are supported for the following:
Two FSx for ONTAP file systems
One FSx for ONTAP file system and one on-premises ONTAP system
After you stop replication and make changes to the target volume, you can replicate those changes back to the source volume. This process is common in a disaster recovery scenario in which you operate on the target volume for a while and want to switch roles of the volumes.
When you reverse and resume a replication, the source and target roles of your volumes switch; the target volume becomes the new source volume, and the source volume becomes the new target volume. The reverse operation also overwrites the contents of the new target volume with the contents of the new source volume. If you reverse a replication twice, the original replication direction re-establishes.
NOTE:
Reversing replication isn't available when replicating storage VM data and configuration settings.
Make sure that you know the current and future roles of your source and target volumes because changes on the new target volume are overwritten with the new source volume. If used incorrectly, you can experience unintended data loss.
Select the menu
In the Replication relationships tab, select the actions menu of the replication relationship to reverse.
Select Reverse relationship.
In the Reverse relationship dialog, select Reverse.
Stop a replication relationship
Stop a replication relationship in NetApp Workload Factory. When you stop a replication relationship, scheduled replication updates from the source volume to the target volume pause. The target volume transitions from read-only to read/write.
Select the menu
In the Replication relationships tab, select the actions menu of the replication relationship to stop.
Select Break.
In the Break replication dialog, select Break.
The replication status of the volume changes to Broken. The target volume becomes writable.
Delete a replication relationship
Delete a replication relationship in NetApp Workload Factory. When you delete a replication relationship, the relationship between the source and target volume is removed. After you delete the relationship, both volumes continue to exist independently with the current data they contain.
When you delete a replication relationship, FSx for ONTAP also deletes the common replication snapshots of the source and target volume.
Select the menu
In the Replication relationships tab, select the actions menu of the replication relationship to delete.
Select Delete.
In the Delete relationship dialog, select Delete.
