Amazon FSx for NetApp ONTAP
Register your Workload Factory account for NetApp support
Contributors netapp-rlithman
Before you can open a support case with NetApp technical support, you need to add a NetApp Support Site account to Workload Factory and then register for support.
Support registration is required to receive technical support specific to NetApp Workload Factory and its storage solutions and services. You must register for support from the NetApp Console, which is a separate web-based console from Workload Factory.
Registering for support does not enable NetApp support for a cloud provider file service. For technical support related to a cloud provider file service, its infrastructure, or any solution using the service, refer to "Getting help" in the Workload Factory documentation for that product.
Support registration overview
Registering your account ID support subscription (your 20 digit 960xxxxxxxxx serial number located on the Support Resources page in the NetApp Console) serves as your single support subscription ID. Each NetApp account-level support subscription must be registered.
Registering enables capabilities like opening support tickets and automatic case generation. Registration is completed by adding NetApp Support Site (NSS) accounts to the NetApp Console as described below.
Register your account for NetApp support
To register for support and activate support entitlement, one user in your account must associate a NetApp Support Site account with their NetApp Console login. How you register for NetApp support depends on whether you already have a NetApp Support Site (NSS) account.
Existing customer with an NSS account
If you're a NetApp customer with an NSS account, you simply need to register for support through the NetApp Console.
Steps
  1. In the upper right of the Workload Factory console, select Help > Support.
    Selecting this option opens the NetApp Console in a new browser tab and loads the Support dashboard.
  2. From the NetApp Console menu, select Administration, and then select Credentials.
  3. Select User Credentials.
  4. Select Add NSS credentials and follow the NetApp Support Site (NSS) Authentication prompt.
  5. To confirm that the registration process was successful, select the Help icon, and select Support.
    The Resources page should show that your account is registered for support.
    A screenshot that shows an account serial number and a green checkbox and the text Registered for support.
    Note that other NetApp Console users will not see this same support registration status if they have not associated a NetApp Support Site account with their NetApp Console login. However, that doesn't mean that your NetApp account is not registered for support. As long as one user in the account has followed these steps, then your account has been registered.
Existing customer but no NSS account
If you're an existing NetApp customer with existing licenses and serial numbers but no NSS account, you need to create an NSS account and associate it with your NetApp Console login.
Steps
  1. Create a NetApp Support Site account by completing the NetApp Support Site User Registration form
    1. Be sure to select the appropriate User Level, which is typically NetApp Customer/End User.
    2. Be sure to copy the NetApp account serial number (960xxxx) used above for the serial number field. This will speed up the account processing.
  2. Associate your new NSS account with your NetApp Console login by completing the steps under Existing customer with an NSS account.
Brand new to NetApp
If you are brand new to NetApp and you don't have an NSS account, follow each step below.
Steps
  2. Locate your account ID serial number from the Support Resources page.
    A screenshot of the Help menu where Support is the first option listed
  3. Navigate to NetApp's support registration site and select I am not a registered NetApp Customer.
  4. Fill out the mandatory fields (those with red asterisks).
  5. In the Product Line field, select Cloud Manager and then select your applicable billing provider.
  6. Copy your account serial number from step 2 above, complete the security check, and then confirm that you read NetApp's Global Data Privacy Policy.
    An email is immediately sent to the mailbox provided to finalize this secure transaction. Be sure to check your spam folders if the validation email doesn't arrive in few minutes.
  7. Confirm the action from within the email.
    Confirming submits your request to NetApp and recommends that you create a NetApp Support Site account.
  8. Create a NetApp Support Site account by completing the NetApp Support Site User Registration form
    2. Be sure to copy the account serial number (960xxxx) used above for the serial number field. This will speed up the account processing.
After you finish
NetApp should reach out to you during this process. This is a one-time onboarding exercise for new users.
Once you have your NetApp Support Site account, associate the account with your NetApp Console login by completing the steps under Existing customer with an NSS account.
