Track costs for resources in NetApp Workload Factory
Use NetApp Workload Factory to track your FSx for ONTAP file system costs and usage so that you can manage budgets and optimize resources effectively. We use AWS Cost Explorer to provide overall cost with data that requires minimal permissions. Cost by resource (file system or volume) is based on Workload Factory calculations, which provide unique insights that are not available through AWS Cost Explorer.
About this task
Workload Factory gets cost and usage data for your FSx for ONTAP file system resources from AWS Cost Explorer using the following permissions: ce:GetCostAndUsage and ce:GetTags. The following cost details are tracked: usage type, usage SKU, deployment type, usage, and total cost.
In the Cost dashboard, two tabs provide overall cost and cost by resource.
Overall cost is based on data pulled directly from the AWS Cost Explorer API.
Cost by Resource shows you cost estimates by file systems or volumes.
For unique resources, Workload Factory calculates costs by combining the actual performance tier usage, a proportional share of performance tier costs allocated to provisioned but unused space, performance allocations distributed by capacity, and capacity pool usage. Workload Factory multiplies each component by its price per unit for that dimension and sums the results to determine the total cost for each resource.
Workload Factory always shows data at a monthly rate.
You can filter cost and usage data by AWS accounts, credentials, one or more regions, and time ranges so that you can understand your FSx for ONTAP file system consumption. You can also filter by one or more file systems and one or more volumes within a file system.
AWS cost allocation tag keys and tag key values add a layer of filtering to pinpoint specific costs. A tag consists of a key and a value. To filter by tag keys and tag key values, assign tags to your FSx for ONTAP file systems. Learn more about AWS cost allocation tags.
In addition to the cost data in the Cost dashboard, the AI-generated cost executive summary shows your FSx for ONTAP file system costs and your organization's spending patterns. You can generate CSV files of your FSx for ONTAP file system resources to share with your team and stakeholders.
Track costs
The costs shown in the Workload Factory console in the Cost dashboard are based on the data from AWS Cost Explorer, which is updated every 24 hours.
Verify that you meet the following requirements:
You must grant credentials with the view, planning, and analysis permission policy in Workload Factory to track FSx for ONTAP costs.
To filter by AWS allocation tags, verify that your FSx for ONTAP file systems have tags assigned to them.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select Cost.
From the Cost dashboard, filter cost and capacity data for your FSx for ONTAP resources by providing the following:
AWS accounts: Select the accounts you want to view cost data for.
Credentials: Select credentials with view, planning, and analysis permissions.
Regions: Select the AWS regions you want to view cost data for.
Cost data range: Select the time range for cost data to view.
Allocation tag key: (Optional) Select an allocation tag key and its value to generate a detailed cost report for all FSx for ONTAP file systems associated with the AWS tag.
Allocation tag values: (Optional) Select the allocation tag key value that is associated with the allocation tag key to generate a detailed cost report for all FSx for ONTAP file systems associated with the AWS tag.
View the Cost Details for your FSx for ONTAP resources.
Generate cost reports for your FSx for ONTAP resources
Generate cost reports for specific FSx for ONTAP file system resources to share with stakeholders.
In the Cost dashboard, select Generate report.
In the Report screen, provide the following information:
File system: Select one or more FSx for ONTAP file systems to include in the report.
Volume: (Optional) Select one or more volumes to include in the report.
Workload Factory generates a CSV report that you can download.
