Activate external authentication for a GenAI knowledge base
Activate authentication for a knowledge base so that token validation and ACLs are required when using the API endpoints to integrate a knowledge base with a chatbot application. When you activate authentication, you configure settings for a JSON Web Token that will be used for API requests to a knowledge base from chatbot clients.
Log in to Workload Factory using one of the console experiences.
In the AI workloads tile, select Deploy & manage.
From the Knowledge bases inventory page, select the knowledge base for which you want to activate authentication.
Select
and select Manage knowledge base. -
Select the Actions menu and select Manage authentication settings.
Set up authentication:
Select Activate authentication settings.
Provide the required information. Examples are provided, but you should obtain the values for these fields from your authentication provider:
Algorithms: The signing algorithm that your authentication provider uses.
Audience (Optional): A string containing the intended recipient of the token (sometimes a URL).
Issuer: A string that identifies the provider that issued the token.
For example, Amazon Cognito uses issuer strings with the following format:
https://cognito-idp-<region>.amazonaws.com/<UserPoolID>
Where
<region>is the AWS region containing the user pool, and<UserPoolID>is your user pool ID. You can retrieve your user pool ID using the following command:aws cognito-idp list-user-pools --max-results=60 --output=table
JWKS URI: The URI string that provides public keys needed to verify signatures of this token.
For example, Amazon Cognito uses JWKS URI strings with the following format:
https://cognito-idp.<region>.amazonaws.com/<userPoolId>/.well-known/jwks.json
Where
Select Save.
Authentication for the knowledge base is now active, and you can use API endpoints to interact with the knowledge base and integrate the knowledge base with a chatbot application.
