Information Security for Workload Factory
Lambda link IAM permissions for NetApp Workload Factory
Contributors netapp-rlithman
NetApp Workload Factory uses Lambda link permission boundaries to define the IAM access required for Lambda execution and Workload Factory invocation. These permissions are optional, but they are required for ONTAP-native operations. When you configure Secrets Manager support, the link retrieves ONTAP credentials directly from your AWS Secrets Manager at runtime, and the password transits only within your VPC, from Secrets Manager to the Lambda function and then to the ONTAP endpoint.
For request-path and port requirements, refer to Lambda link ports and calls.
Lambda execution role permissions
The Lambda execution role requires the following permissions when deploying a link in your VPC:
Permission Purpose
ec2:CreateNetworkInterface / ec2:DescribeNetworkInterfaces / ec2:DeleteNetworkInterface
Standard VPC-attached Lambda networking
ec2:AssignPrivateIpAddresses / ec2:UnassignPrivateIpAddresses
VPC ENI IP management
secretsmanager:GetSecretValue (scoped to FSxSecret*)
Retrieve ONTAP credentials (only when Secrets Manager is enabled)
CloudWatch Logs (managed policy)
Lambda execution logging
Workload Factory invocation permissions
The Lambda link resource-based policy grants the Workload Factory service principal the following permissions:
Permission Purpose
lambda:InvokeFunction
Execute the Lambda
lambda:GetFunction
Health and status checks
lambda:UpdateFunctionCode
Version upgrades (image updates)
lambda:GetFunctionConfiguration
Configuration verification
