Setup and administration
Configure NetApp Workload Factory notifications
Contributors netapp-mwallis netapp-rlithman netapp-sineadd
You can configure the NetApp Workload Factory notification service to send notifications as alerts in NetApp Console, to any email addresses associated with the account, or to an Amazon SNS topic. Notifications sent as alerts appear in NetApp Console when you have a Console agent or link deployed. When Workload Factory publishes notifications to an Amazon SNS topic, subscribers to the topic (such as people or other applications) receive the notifications at the endpoints configured for the topic (such as email or SMS messages).
Configure Workload Factory notifications
You can configure Workload Factory notifications using NetApp Console or the Workload Factory console.
Important When you configure notifications in NetApp Console, it takes ownership of notification delivery and the Workload Factory console notification options are disabled and displayed in read-only mode. A tooltip states that notifications are managed from NetApp Console. You can then manage notifications only from NetApp Console.
Options for receiving notifications include:
NetApp Console
  • Notifications: Configure Workload Factory to send notifications that appear under the bell icon in NetApp Console.
  • Email: Enable email notifications in NetApp Console to receive notifications to any email addresses associated with the account without requiring Amazon SNS configuration.
  • Amazon SNS: Configure Workload Factory to send notifications to an Amazon SNS topic.
Amazon SNS: Configure Workload Factory to send notifications to an Amazon SNS topic using the Workload Factory console.
Before you begin
The following prerequisites apply only when configuring Amazon SNS notifications:
  • You need to configure Amazon SNS and create Amazon SNS topics using either the Amazon SNS console or the AWS CLI.
  • Note that Workload Factory supports the Standard topic type. This type of topic does not ensure that notifications are sent to subscribers in the order in which they were received, so consider this if you have critical or emergency notifications.
Configure notifications from NetApp Console
Steps
  1. Log in to the NetApp Console.
  2. From the NetApp Console menu, select Workloads, Administration, and then Notifications setup.
  3. On the Notifications setup page, enable one or more of the following notification types:
    1. NetApp Console notifications: Select Enable NetApp Console notifications to configure Workload Factory to send notifications in NetApp Console.
    2. Email notifications: Select Enable email notifications to configure Workload Factory to send notifications to any email addresses associated with the account.
    3. Amazon SNS notifications: Select Enable SNS notifications, then follow the instructions to configure Amazon SNS from the Amazon SNS console.
      After you create the topic, copy the topic ARN and enter it in the SNS topic ARN field on the Notifications setup page.
  4. After you verify the configuration by sending a test notification, select Apply.
Configure notifications from Workload Factory console
Steps
  1. Log in to the Workload Factory console.
  2. From the Workload Factory console menu, select Workloads, Administration, and then Notifications setup.
    • Email notifications: To receive email notifications, configure notification recipients and severity preferences in NetApp Console notification settings.
    • Amazon SNS notifications: Select Enable SNS notifications, then follow the instructions to configure Amazon SNS from the Amazon SNS console.
Subscribe to the Amazon SNS topic
After you configure Workload Factory to send notifications to a topic, follow the instructions in the Amazon SNS documentation to subscribe to the topic so that you can receive notifications from Workload Factory.
Filter notifications
You can reduce unnecessary notification traffic and target specific notification types for specific users by applying filters to the notifications. You can do this using an Amazon SNS policy for SNS notifications, and using the notifications settings in NetApp Console.
Filter Amazon SNS notifications
When you subscribe to an Amazon SNS topic, you receive all notifications published to that topic by default. If you want to receive only specific notifications from the topic, you can use a filter policy to control which notifications you receive. Filter policies cause Amazon SNS to deliver only the notifications that match the filter policy to the subscriber.
You can filter Amazon SNS notifications by the following criteria:
Description Filter policy field name Possible values
Resource type
resourceType
  • DB
  • Microsoft SQL Server host
  • PostgreSQL Server host
Workload
workload
WLMDB
Priority
priority
  • Success
  • Info
  • Recommendation
  • Warning
  • Error
  • Critical
Notification type
notificationType
  • Deployment
  • Well-architected
Steps
  1. In the Amazon SNS console, edit the subscription details for the SNS topic.
  2. In the Subscription filter policy area, select to filter by Message attributes.
  3. Enable the Subscription filter policy option.
  4. Enter a JSON filter policy in the JSON editor box.
    For example, the following JSON filter policy accepts notifications from the Microsoft SQL Server resource that are related to the WLMDB workload, have a priority of Success or Error, and provide details on Well-architected status:
      "accountId": [
        "account-a"
      "resourceType": [
        "Microsoft SQL Server host"
      "workload": [
        "WLMDB"
      "priority": [
        "Success",
        "Error"
      "notificationType": [
        "Well-architected"
  5. Select Save changes.
For other examples of filter policies, refer to Amazon SNS example filter policies.
For further information about creating filter policies, refer to the Amazon SNS documentation.
Filter notifications in NetApp Console
You can use NetApp Console notifications settings to filter notifications that you receive in the Console by severity level, such as Critical, Info, or Warning.
For more information about filtering notifications in the Console, refer to the NetApp Console documentation.
Notification types and messages
Workload Factory sends notifications for the following events:
Event Description Notification type Severity Workload Resource type
Some database instances in your account are not well-architected
All Microsoft SQL Server instances in your account have been analyzed for well-architected issues. The description for this event gives the number of well-architected instances and unoptimized instances. Review well-architected status findings and recommendations in the Databases inventory from the Workload Factory console.
Well-architected
Recommendation
Databases
Microsoft SQL Server/PostgreSQL server deployment succeeded
The deployment of the Microsoft SQL Server or PostgreSQL host succeeded. For more information, go to job monitoring.
Deployment
Success
Databases
FSx for ONTAP, DB host
Microsoft SQL Server/PostgreSQL server deployment failed
The deployment of the Microsoft SQL Server or PostgreSQL host failed. For more information, go to job monitoring.
Deployment
Databases
Failed replication relationship creation
A SnapMirror replication relationship creation has failed. For more information, go to Tracker.
Replication
Critical
General storage
FSx for ONTAP
FSx for ONTAP creation failure
An FSx for ONTAP file system creation process has failed. For more information, go to Tracker.
FSx for ONTAP file system action
Critical
General storage
FSx for ONTAP
Automatic SSD capacity or inodes increase success
During a recent automatic capacity management update, the FSx for ONTAP file system either increased SSD capacity or volume inodes successfully. For more information, go to Tracker.
Capacity management
Success
General storage
FSx for ONTAP file
Automatic SSD capacity or inodes increase failure
During a recent automatic capacity management update, the FSx for ONTAP file system failed to increase SSD capacity or volume inodes. For more information, go to Tracker.
Capacity management
Critical
General storage
FSx for ONTAP file systems
FSx for ONTAP issue detected
All FSx for ONTAP file systems have been analyzed for well-architected issues. The scan detected one or more issues. For more information, review the well-architected analysis from the Storage dashboard in the Workload Factory console.
Well-architected analysis
Recommendation
General storage
Automatic capacity management event for FSx for ONTAP
The SSD performance tier for the FSx for ONTAP file system reached the warning threshold capacity/percentage total.
Capacity management
Warning
General storage
Automatic inodes management event for FSx for ONTAP
The inode count for the FSx for ONTAP volume reached the warning threshold count/percentage total.
Capacity management
Warning
General storage
Suspicious volume activity detected in FSx for ONTAP file system
NetApp Autonomous Ransomware Protection with AI (ARP/AI) detected suspicious volume activity.
Ransomware protection
Critical
General storage
Latency threshold breach detected
One or more volumes in the FSx for ONTAP cluster exceeded the latency threshold.
Performance monitoring
Warning
EDA
Monthly cost report
Monthly cost summary for your account, showing spending trends, unusual changes, and the best savings opportunities for FSx for ONTAP file systems.
Cost report
Recommendation
General storage
Replication delay
Replication is taking longer than expected.
Replication
Critical
General storage
Custom dashboard creation succeeded
Your custom dashboard has been successfully created and is ready to view.
Custom Dashboards
Success
General storage
Workload Factory account
Custom dashboard creation failed
Workload Factory was unable to create your custom dashboard. Try creating the dashboard again.
Custom Dashboards
General storage
