Setup and administration
Connect to an FSx for ONTAP file system with a Lambda link
Contributors netapp-rlithman
To perform advanced ONTAP management operations, set up a connection between your Workload Factory account and one or more FSx for ONTAP file systems. This involves associating new and existing Lambda links, and authenticating the links. Link association lets you monitor and manage certain features directly from the FSx for ONTAP file system that are unavailable through the Amazon FSx for ONTAP API.
About this task
Links use AWS Lambda to execute code in response to events and automatically manage the computing resources required by that code. The links that you create are part of your NetApp account and they are associated with an AWS account.
You can create a link in your account when defining an FSx for ONTAP file system. You use the link for that file system, and you can use it for other FSx for ONTAP file systems. You can also associate a link for a file system later.
Links require authentication. You can authenticate links using credentials stored in the Workload Factory credentials service or with your credentials stored in AWS Secrets Manager. Only one authentication method is supported per link. For example, if you select link authentication with AWS Secrets Manager, you can't change the authentication method later.
Note AWS Secrets Manager isn't supported when using a Console agent.
Associating a new link includes link creation and association.
You have two options for creating links in this workflow - automatically or manually. If you have an AWS GovCloud account, you must create a new link manually.
  • Automatically: Creates a link with automatic registration via Workload Factory. A link created automatically requires tokens for Workload Factory automation and the CloudFormation code is short-lived. It can only be used for up to six hours.
  • Manually: Creates a link with manual registration using either CloudFormation or Terraform from the Codebox. The code persists giving you more time to complete the operation. This is useful when working with different teams like Security and DevOps that might first need to grant the permissions necessary to complete link creation.
Before you begin
  • You should consider which link creation option you'll use.
  • You need to have at least one FSx for ONTAP file system in Workload Factory. To discover FSx for ONTAP file systems, you must have an AWS account with permissions for FSx for ONTAP instances and add credentials in Workload Factory with view, planning, and analysis permissions for Storage management.
  • The following ports must be open in the security group associated with the FSx for ONTAP file system for link connectivity.
    • For the Workload Factory console: port 443 (HTTPS)
    • For CloudShell and FSx for ONTAP Emergency Management System (EMS) events analysis: port 22 (SSH)
  • The link must be able to connect to the following endpoint: https://api.workloads.netapp.com. The web-based console contacts this endpoint to interact with the Workload Factory APIs to manage and operate FSx for ONTAP workloads.
  • You must have the following permissions in your AWS account when adding a link using a CloudFormation stack:
    Details
      "cloudformation:GetTemplateSummary",
      "cloudformation:CreateStack",
      "cloudformation:DescribeStacks",
      "cloudformation:ListStacks",
      "cloudformation:DescribeStackEvents",
      "cloudformation:ListStackResources",
      "ec2:DescribeSubnets",
      "ec2:DescribeSecurityGroups",
      "ec2:DescribeVpcs",
      "iam:ListRoles",
      "iam:GetRolePolicy",
      "iam:GetRole",
      "iam:DeleteRolePolicy",
      "iam:CreateRole",
      "iam:DetachRolePolicy",
      "iam:PutRolePolicy",
      "iam:DeleteRole",
      "iam:AttachRolePolicy",
      "lambda:InvokeFunction",
      "lambda:GetFunction",
      "lambda:CreateFunction",
      "lambda:DeleteFunction",
      "iam:PassRole",
      "lambda:TagResource",
      "ecr:BatchGetImage",
      "ecr:GetDownloadUrlForLayer",
      "lambda:AddPermission",
      "lambda:RemovePermission",
      "cloudformation:DeleteStack",
      "kms:CreateGrant",
      "kms:GenerateDataKey"
Create automatically
Use CloudFormation to automatically create and register the link within Workload Factory.
Note Automatic link creation isn't supported for AWS GovCloud accounts.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Administration.
  3. From the Administration menu, select Links.
  4. On the Links page, select Create and associate.
  5. In the Associate Link dialog, select the file system to associate with the link and select Continue.
  6. Select Create a new link and then select Continue.
  7. On the Create Link page, select Create automatically and then provide the following:
    1. Link name: Enter the name that you want to use for this link. The name must be unique within your account.
    2. AWS Secrets Manager: Optional. Allows Workload Factory to fetch FSx for ONTAP access credentials from your AWS Secrets Manager.
      The link deployment stack automatically adds the following default secret manager ARN regex to the Lambda permission policy: arn:aws:secretsmanager:<link_deployment_region>:<link_deployment_account_id>:secret:FSxSecret*.
      You can either create secrets in alignment with the default permissions or assign your custom permissions for the link policy.
      Configure VPC private endpoint to AWS Secrets Manager is disabled by default. Selecting this option stores the secret using the VPC private endpoint instead of storing it locally.
    3. Link permissions: Select one of the following options for link permissions:
      • Automatic: Select this option so that AWS CloudFormation code automatically creates the Lambda permission policy and execution role.
      • User-provided execution role: Select this option to assign a specified Lambda execution role and its attached policies to the Lambda link. The following permissions are required for the Lambda permission policy. The secretsmanager:GetSecretValue permission is required only if you enabled AWS Secrets Manager.
        "ec2:CreateNetworkInterface",
        "ec2:DescribeNetworkInterfaces",
        "ec2:DeleteNetworkInterface",
        "ec2:AssignPrivateIpAddresses",
        "ec2:UnassignPrivateIpAddresses",
        Enter the Lambda execution role ARN in the text box.
    4. Tags: Optionally, add any tags that you want to associate with this link so you can more easily categorize your resources. For example, you could add a tag that identifies this link as being used by FSx for ONTAP file systems.
      Workload Factory automatically retrieves the AWS account, location, and security group based on the FSx for ONTAP file system.
  8. Select Create.
    The Redirect to CloudFormation dialog appears and explains how to create the link from the AWS CloudFormation service.
  9. Select Continue to open the AWS Management Console, and then log in to the AWS account for this FSx for ONTAP file system.
  10. On the Quick create stack page, under Capabilities, select I acknowledge that AWS CloudFormation might create IAM resources.
    The CloudFormation template grants Lambda three permissions when you launch it. Workload Factory uses these permissions when using links.
    "lambda:UpdateFunctionCode"
  11. Select Create stack and then Select Continue.
    You can monitor the link creation status on the Events page. This should take no more than five minutes.
  12. Return to the Workload Factory interface and you'll see that the link is associated with the FSx for ONTAP file system.
Create manually
You can create a link using two Infrastructure-as-Code (IaC) tools from the Codebox: CloudFormation or Terraform. With this option, you extract the ARN for the link from AWS CloudFormation and report it here. Workload Factory manually registers the link for you.
Steps
  7. On the Create Link page, select Create manually and then select CloudFormation or Terraform from the Codebox.
  8. Under Details and credentials, provide the following:
    2. AWS Secrets Manager: Always enabled for GovCloud accounts. Optional for other accounts. Allows Workload Factory to fetch FSx for ONTAP access credentials from your AWS Secrets Manager.
      • User-provided: Select this option to assign a specified Lambda execution role and its attached policies to the Lambda link. The following permissions are required for the Lambda permission policy. The secretsmanager:GetSecretValue permission is required only when using AWS Secrets Manager.
    5. Link registration: Select CloudFormation or Terraform for the instructions for how to register the link, and follow the instructions.
      1. After you successfully create the stack, paste the Lambda ARN in the text box in the Workload Factory console. Workload Factory automatically retrieves the AWS account, location, and security group based on the FSx for ONTAP file system.
      2. Select Create.
Result
Workload Factory associates the link with the FSx for ONTAP file system. You can perform advanced ONTAP operations.
After you create a link, associate it with one or more FSx for ONTAP file systems.
Steps
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select FSx for ONTAP.
  4. From FSx for ONTAP, select the actions menu of the file system to associate a link to and then select Associate link.
  5. In the Associate link page, select Associate an existing link, select the link, and select Continue.
  6. Select the authentication mode.
    • Workload Factory: enter the password twice.
    • AWS Secrets Manager: enter the secret ARN.
      Verify that the secret ARN contains the following key-value pairs, though the filesystemID is optional.
      • filesystemID = FSx_filesystem_id (optional)
      • user = FSx_user
      • password = user_password
        Note Authentication with AWS Secrets Manager requires a user, either the FSx_user that you provide or another user that was created on the FSx for ONTAP file system. The default user is fsxadmin if you don't provide a user.
  7. Select Apply.
Result
The link is associated with the FSx for ONTAP file system. You can perform advanced ONTAP operations.
Related information
Learn more about links.
Issue
The link lacks permissions to retrieve the secret.
Resolution: Add permissions after the link is active. Log in to the AWS console, locate the Lambda link, and edit the attached permission policy.
Issue
The secret isn't found.
Resolution: Provide the correct secret ARN.
Issue
The secret isn't in the right format.
Resolution: Go to AWS Secrets Manager and edit the format.
The secret should contain the following key-value pairs:
  • username = FSx_user
Issue
The secret doesn't contain valid ONTAP credentials for file system authentication.
Resolution: Provide credentials that can authenticate FSx for ONTAP file systems in AWS Secrets Manager.
