Data Infrastructure Insights
Performance Schema
贡献者 netapp-alavoie
性能架构提供了有关存储、主机、卷和应用程序的 I/O、延迟、吞吐量和其他性能指标的时间序列指标。使用此架构可以分析性能趋势、识别瓶颈并优化工作负载放置。
来源:dwh_performance OData 端点—Data Infrastructure Insights
找到的表格:74 | 关联:167
表之间的关键关系
application_volume_hourly_performance_fact
被引用(父)表 FK列 父级 PK
"应用维度"
applicationTk
tk
"应用组维度"
applicationGroupTk
tk
"业务实体维度"
businessEntityTk
tk
"日期维度"
dateTk
tk
"服务级别维度"
serviceLevelTk
tk
"层级维度"
tierTk
tk
"时间维度"
timeTk
tk
disk_daily_performance_fact
被引用(父)表 FK列 父级 PK
"日期维度"
dateTk
tk
"disk_dimension"
diskTk
tk
"存储维度"
storageTk
tk
"存储池维度"
storagePoolTk
tk
disk_hourly_performance_fact
被引用(父)表 FK列 父级 PK
"日期维度"
dateTk
tk
"disk_dimension"
diskTk
tk
"存储维度"
storageTk
tk
"存储池维度"
storagePoolTk
tk
"时间维度"
timeTk
tk
host_vm_daily_performance_fact
被引用(父)表 FK列 父级 PK
"日期维度"
dateTk
tk
"主机维度"
hostTk
tk
host_vm_hourly_performance_fact
被引用(父)表 FK列 父级 PK
"日期维度"
dateTk
tk
"主机维度"
hostTk
tk
"时间维度"
timeTk
tk
host_volume_hourly_performance_fact
被引用(父)表 FK列 父级 PK
"业务实体维度"
businessEntityTk
tk
"日期维度"
dateTk
tk
"主机维度"
hostTk
tk
"主机组维度"
hostGroupTk
tk
"服务级别维度"
serviceLevelTk
tk
"层级维度"
tierTk
tk
"时间维度"
timeTk
tk
internal_volume_daily_performance_fact
被引用(父)表 FK列 父级 PK
"应用维度"
applicationTk
tk
"应用组维度"
applicationGroupTk
tk
"业务实体维度"
businessEntityTk
tk
"日期维度"
dateTk
tk
"内部卷尺寸"
internalVolumeTk
tk
"k8s_namespace_dimension"
k8sNamespaceTk
tk
"k8s_namespace_group_dimension"
k8sNamespaceGroupTk
tk
"服务级别维度"
serviceLevelTk
tk
"存储维度"
storageTk
tk
"存储节点尺寸"
storageNodeTk
tk
"存储池维度"
storagePoolTk
tk
"层级维度"
tierTk
tk
internal_volume_hourly_performance_fact
被引用(父)表 FK列 父级 PK
"应用维度"
applicationTk
tk
"应用组维度"
applicationGroupTk
tk
"业务实体维度"
businessEntityTk
tk
"日期维度"
dateTk
tk
"内部卷尺寸"
internalVolumeTk
tk
k8sNamespaceTk
tk
k8sNamespaceGroupTk
tk
"服务级别维度"
serviceLevelTk
tk
"存储维度"
storageTk
tk
"存储节点尺寸"
storageNodeTk
tk
"存储池维度"
storagePoolTk
tk
"层级维度"
tierTk
tk
"时间维度"
timeTk
tk
qtree_daily_performance_fact
被引用(父)表 FK列 父级 PK
"应用维度"
applicationTk
tk
"应用组维度"
applicationGroupTk
tk
"业务实体维度"
businessEntityTk
tk
"日期维度"
dateTk
tk
"内部卷尺寸"
internalVolumeTk
tk
k8sNamespaceTk
tk
k8sNamespaceGroupTk
tk
"qtree_dimension"
qtreeTk
tk
"服务级别维度"
serviceLevelTk
tk
"存储维度"
storageTk
tk
"存储池维度"
storagePoolTk
tk
"层级维度"
tierTk
tk
qtree_hourly_performance_fact
被引用(父)表 FK列 父级 PK
"应用维度"
applicationTk
tk
"应用组维度"
applicationGroupTk
tk
"业务实体维度"
businessEntityTk
tk
"日期维度"
dateTk
tk
"内部卷尺寸"
internalVolumeTk
tk
k8sNamespaceTk
tk
k8sNamespaceGroupTk
tk
"qtree_dimension"
qtreeTk
tk
"服务级别维度"
serviceLevelTk
tk
"存储维度"
storageTk
tk
"存储池维度"
storagePoolTk
tk
"层级维度"
tierTk
tk
"时间维度"
timeTk
tk
storage_node_daily_performance_fact
被引用(父)表 FK列 父级 PK
"日期维度"
dateTk
tk
"存储维度"
storageTk
tk
"存储节点尺寸"
storageNodeTk
tk
"层级维度"
tierTk
tk
storage_node_hourly_performance_fact
被引用(父)表 FK列 父级 PK
"日期维度"
dateTk
tk
"存储维度"
storageTk
tk
"存储节点尺寸"
storageNodeTk
tk
"层级维度"
tierTk
tk
"时间维度"
timeTk
tk
switch_performance_for_host_hourly_fact
被引用(父)表 FK列 父级 PK
"应用维度"
applicationTk
tk
"应用组维度"
applicationGroupTk
tk
"业务实体维度"
businessEntityTk
tk
"日期维度"
dateTk
tk
"主机维度"
hostTk
tk
"时间维度"
timeTk
tk
switch_performance_for_port_hourly_fact
被引用(父)表 FK列 父级 PK
"已连接设备维度"
connectedDeviceTk
tk
"日期维度"
dateTk
tk
"fabric_dimension"
fabricTk
tk
"端口尺寸"
portTk
tk
"切换维度"
switchTk
tk
"时间维度"
timeTk
tk
switch_performance_for_storage_hourly_fact
被引用(父)表 FK列 父级 PK
"日期维度"
dateTk
tk
"存储维度"
storageTk
tk
"时间维度"
timeTk
tk
switch_performance_for_tape_hourly_fact
被引用(父)表 FK列 父级 PK
"日期维度"
dateTk
tk
"tape_dimension"
tapeTk
tk
"时间维度"
timeTk
tk
时间维度
被引用(父)表 FK列 父级 PK
"日期维度"
dateTk
tk
被引用(父)表 FK列 父级 PK
"应用维度"
applicationTk
tk
"应用组维度"
applicationGroupTk
tk
"业务实体维度"
businessEntityTk
tk
"日期维度"
dateTk
tk
"主机维度"
hostTk
tk
"k8s_node_dimension"
k8sNodeTk
tk
"vm_dimension"
vmTk
tk
被引用(父)表 FK列 父级 PK
"应用维度"
applicationTk
tk
"应用组维度"
applicationGroupTk
tk
"业务实体维度"
businessEntityTk
tk
"日期维度"
dateTk
tk
"主机维度"
hostTk
tk
k8sNodeTk
tk
"时间维度"
timeTk
tk
"vm_dimension"
vmTk
tk
vmdk_daily_performance_fact
被引用(父)表 FK列 父级 PK
"数据存储_维度"
dataStoreTk
tk
"日期维度"
dateTk
tk
"主机维度"
hostTk
tk
"服务级别维度"
serviceLevelTk
tk
"存储维度"
storageTk
tk
"层级维度"
tierTk
tk
"vm_dimension"
vmTk
tk
"vmdk_dimension"
vmdkTk
tk
vmdk_hourly_performance_fact
被引用(父)表 FK列 父级 PK
"数据存储_维度"
dataStoreTk
tk
"日期维度"
dateTk
tk
"主机维度"
hostTk
tk
"服务级别维度"
serviceLevelTk
tk
"存储维度"
storageTk
tk
"层级维度"
tierTk
tk
"时间维度"
timeTk
tk
"vm_dimension"
vmTk
tk
"vmdk_dimension"
vmdkTk
tk
被引用(父)表 FK列 父级 PK
"应用维度"
applicationTk
tk
"应用组维度"
applicationGroupTk
tk
"业务实体维度"
businessEntityTk
tk
"日期维度"
dateTk
tk
"主机维度"
hostTk
tk
"主机组维度"
hostGroupTk
tk
k8sNamespaceTk
tk
k8sNamespaceGroupTk
tk
"服务级别维度"
serviceLevelTk
tk
"存储维度"
storageTk
tk
"存储节点尺寸"
storageNodeTk
tk
"存储池维度"
storagePoolTk
tk
"层级维度"
tierTk
tk
"体积尺寸"
volumeTk
tk
被引用(父)表 FK列 父级 PK
"应用维度"
applicationTk
tk
"应用组维度"
applicationGroupTk
tk
"业务实体维度"
businessEntityTk
tk
"日期维度"
dateTk
tk
"主机维度"
hostTk
tk
"主机组维度"
hostGroupTk
tk
k8sNamespaceTk
tk
k8sNamespaceGroupTk
tk
"服务级别维度"
serviceLevelTk
tk
"存储维度"
storageTk
tk
"存储节点尺寸"
storageNodeTk
tk
"存储池维度"
storagePoolTk
tk
"层级维度"
tierTk
tk
"时间维度"
timeTk
tk
"体积尺寸"
volumeTk
tk
表格和字段
PKPrimary KeyFKForeign KeyNOT NULL必填字段
应用维度
↑ top
实体集:application_dimension
字段 类型 可为Null 注释
tk
Int32
是
此应用程序行的 TK。
name
字符串
是
应用程序的名称。
description
字符串
是
应用程序的描述。
优先级
字符串
是
应用程序的优先级。
url
字符串
是
Insight Server 中此应用程序的 URL。
ID
Int64
是
dwh_inventory.application 中应用程序的 GUID。
最新
字符串
是
指示此行是否为此应用程序的最新行。
dateTk
Int32
是
此应用程序行的创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
"qtree_hourly_performance_fact"
许多
"volume_hourly_performance_fact"
许多
"application_volume_hourly_performance_fact"
许多
"qtree_daily_performance_fact"
许多
"vm_hourly_performance_fact"
许多
"internal_volume_daily_performance_fact"
许多
"internal_volume_hourly_performance_fact"
许多
"vm_daily_performance_fact"
许多
"switch_performance_for_host_hourly_fact"
许多
"volume_daily_performance_fact"
许多
application_group_bridge
↑ top
实体集:application_group_bridge
字段 类型 可为Null 注释
appGroupTk
Int32
是
应用程序组的 TK。
appTk
Int32
是
应用程序的 TK。
isRep
字符串
是
指示此应用程序是否表示其应用程序组。
应用组维度
↑ top
实体集:application_group_dimension
字段 类型 可为Null 注释
tk
Int32
是
应用程序组的 TK。
repApp
字符串
是
表示应用程序组的应用程序的名称。
repAppTk
Int32
是
表示应用程序组的应用程序的 TK。
基数
Int32
是
应用程序组中的应用程序数。
dateTk
Int32
是
创建应用程序组行的日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
↑ top
实体集:application_volume_hourly_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
timeTk [FK] →"时间维度".tk
Int32
是
时间维度的 TK。
dateTk [FK] →"日期维度".tk
Int32
是
日期维度的 TK。
applicationTk [FK] →"应用维度".tk
Int32
是
应用程序代表的 TK。
applicationGroupTk [FK] →"应用组维度".tk
Int32
是
应用程序组的 TK。
tierTk [FK] →"层级维度".tk
Int32
是
层的 TK。
serviceLevelTk [FK] →"服务级别维度".tk
Int32
是
服务级别的 TK。
businessEntityTk [FK] →"业务实体维度".tk
Int32
是
商业实体的 TK。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间
totalResponseTime
双线
是
总响应时间。
totalResponseTimeMax
双线
是
响应时间的最大值。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
sumOfAveragesVolumeThroughput
双线
是
与应用程序相关的所有卷每小时样本的 totalThroughput 之和。表示应用程序的平均使用量。
maxOfMaxVolumeThroughput
双线
是
与应用程序相关的所有卷每小时样本的最大 totalThroughputMax。代表应用程序最大使用量的最佳情形。
sumOfMaxVolumeThroughput
双线
是
与应用程序相关的所有卷每小时样本的 totalThroughputMax 总和。表示当所有最大值同时发生时最大使用量的最坏情况。
readIops
双线
是
平均每秒读取 io。
writeIops
双线
是
平均每秒写入 io。
sumOfAveragesVolumeIops
双线
是
与应用程序相关的所有卷每小时样本的 totalIops 总和。表示应用程序的平均使用量。
maxOfMaxVolumeIops
双线
是
与应用程序相关的所有卷每小时样本的最大 totalIopsMax 值。代表应用程序最大使用量的最佳情形。
sumOfMaxVolumeIops
双线
是
与应用程序相关的所有卷每小时样本的 totalIopsMax 总和。表示当所有最大值同时发生时最大使用量的最坏情况。
readCacheHitRatio
双线
是
读缓存命中率。
writeCacheHitRatio
双线
是
写入缓存命中率。
totalCacheHitRatio
双线
是
总缓存命中率。
totalCacheHitRatioMax
双线
是
最大总缓存命中率。
writePending
Int64
是
挂起的写入次数。
readIoDensity
双线
是
读取 io 密度。
writeIoDensity
双线
是
写入 IO 密度。
totalIoDensity
双线
是
总 IO 密度。
totalIoDensityMax
双线
是
最大总 IO 密度。
compressionSavingsPercent
双线
是
压缩节省量 (%)。
compressionSavingsSpace
双线
是
压缩节省空间。
totalTimeToFull
双线
是
充满时间。
confidenceIntervalTimeToFull
双线
是
Time to Full 的置信区间。
导航属性(联接)
导航属性 相关实体 基数/联接
服务级别维度
"服务级别维度"
一个 JOIN:serviceLevelTk="服务级别维度".tk
层级维度
"层级维度"
一个 JOIN:tierTk="层级维度".tk
业务实体维度
"业务实体维度"
一个 JOIN:businessEntityTk="业务实体维度".tk
应用维度
"应用维度"
一个 JOIN:applicationTk="应用维度".tk
时间维度
"时间维度"
一个 JOIN:timeTk="时间维度".tk
日期维度
"日期维度"
一个 JOIN:dateTk="日期维度".tk
应用组维度
"应用组维度"
一个 JOIN:applicationGroupTk="应用组维度".tk
业务实体维度
↑ top
实体集:business_entity_dimension
字段 类型 可为Null 注释
tk
Int32
是
此业务实体行的 TK。
全名
字符串
是
业务实体的名称。
租户
字符串
是
租户名称。
lob
字符串
是
业务线的名称。
businessUnit
字符串
是
业务部门的名称。
项目
字符串
是
项目名称。
ID
Int64
是
dwh_inventory.annotation_value 中业务实体的 GUID。
最新
字符串
是
指示此行是否为此业务实体的最新行。
dateTk
Int32
是
此业务实体行创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
许多
"host_volume_hourly_performance_fact"
许多
许多
许多
许多
许多
许多
capacity_volume_fact_current
↑ top
实体集:capacity_volume_fact_current
字段 类型 可为Null 注释
chargebackFactTk
Int32
是
计算卷容量的拒付事实行的 TK。
volumeId
Int64
是
库存中显示的卷的 GUID
storageId
Int64
是
此卷所在存储的 GUID,如清单中所示
volumeName
字符串
是
卷的名称
volumeType
字符串
是
供应商特定的卷类型(例如,SFS、BCV)。
thinProvisioned
字符串
是
指示此卷是否为精简配置卷。
isVirtual
字符串
是
指示此卷是否为虚拟卷。
Snapshot
字符串
是
指示此卷是否为快照卷。
technologyType
字符串
是
指定技术类型(FC/ISCSI/UNKNOWN)。
物理可用 MB
Int64
是
从存储中消耗并在事实行中计算的卷可用容量(以 MB 为单位)。
physicalRawMB
Int64
是
从存储中消耗并在事实行中计算的卷原始容量(以 MB 为单位)。
已配置可用 MB
Int64
是
分配给主机/用户的卷可用容量,在事实行中计数,以 MB 为单位。
已配置原始 MB
Int64
是
分配给主机/用户的卷原始容量在事实行中计数,以 MB 为单位。
cluster_switch_dimension
↑ top
实体集:cluster_switch_dimension
字段 类型 可为Null 注释
tk
Int32
是
此集群交换机行的 TK。
标识符
字符串
是
集群交换机的唯一标识符。
name
字符串
是
集群交换机的名称。
address
字符串
是
集群交换机的地址
serialNumber
字符串
是
集群交换机的序列号
network
字符串
是
集群交换机的网络
version
字符串
是
集群交换机版本
型号
字符串
是
集群交换机型号
已监控
字符串
是
此集群交换机是否受到监控?
monitoringEnabled
字符串
是
是否已为集群交换机启用监控?
monitoringReason
字符串
是
监控集群交换机的原因
ID
Int64
是
dwh_inventory.cluster_switch 中节点的 GUID
最新
字符串
是
指示此行是否是此集群交换机的最新行。
dateTk
Int32
是
此集群交换机行创建日期的 TK。
cluster_switch_port_daily_metrics_fact
↑ top
实体集:cluster_switch_port_daily_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
dateTk
Int32
是
日期维度的 TK。
clusterSwitchPortTk
Int32
是
节点的 TK。
clusterSwitchTk
Int32
是
集群的 TK。
storageTk
Int32
是
已连接存储节点的 TK。
storageNodeTk
Int32
是
已连接存储的 TK。
receiveBytes
双线
是
接收字节。
transmitBytes
双线
是
传输字节。
totalBytes
双线
是
总字节数。
receiveDiscards
双线
是
接收丢弃。
transmitDiscards
双线
是
传输丢弃。
totalDiscards
双线
是
总丢弃数。
receiveErrors
双线
是
接收错误。
transmitErrors
双线
是
传输错误。
totalErrors
双线
是
错误总数。
receivePackets
双线
是
接收数据包。
transmitPackets
双线
是
传输数据包。
totalPackets
双线
是
总数据包数。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
cluster_switch_port_dimension
↑ top
实体集:cluster_switch_port_dimension
字段 类型 可为Null 注释
tk
Int32
是
此集群交换机端口行的 TK。
标识符
字符串
是
集群交换机端口的唯一标识符。
name
字符串
是
集群交换机端口的名称。
duplexType
字符串
是
集群交换机端口的双工类型
storageNodePortName
字符串
是
集群交换机端口的节点端口名称
storageNodePortMtu
字符串
是
集群交换机端口节点端口的最大传输单元
portIndex
字符串
是
集群交换机端口索引
isl
字符串
是
集群交换机端口的交换机间链路
macAddress
字符串
是
集群交换机端口的 MAC 地址
mtu
字符串
是
集群交换机端口的最大传输单元
数字
字符串
是
集群交换机端口号
type
字符串
是
集群交换机端口类型
速度
字符串
是
集群交换机端口的速度
ID
Int64
是
dwh_inventory.cluster_switch_port 中节点的 GUID
最新
字符串
是
指示此行是否是此集群交换机端口的最新行。
dateTk
Int32
是
此集群交换机端口行创建日期的 TK。
cluster_switch_port_hourly_metrics_fact
↑ top
实体集:cluster_switch_port_hourly_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
timeTk
Int32
是
时间维度的 TK。
dateTk
Int32
是
日期维度的 TK。
clusterSwitchPortTk
Int32
是
节点的 TK。
clusterSwitchTk
Int32
是
集群的 TK。
storageTk
Int32
是
已连接存储节点的 TK。
storageNodeTk
Int32
是
已连接存储的 TK。
receiveBytes
双线
是
接收字节。
transmitBytes
双线
是
传输字节。
totalBytes
双线
是
总字节数。
receiveDiscards
双线
是
接收丢弃。
transmitDiscards
双线
是
传输丢弃。
totalDiscards
双线
是
总丢弃数。
receiveErrors
双线
是
接收错误。
transmitErrors
双线
是
传输错误。
totalErrors
双线
是
错误总数。
receivePackets
双线
是
接收数据包。
transmitPackets
双线
是
传输数据包。
totalPackets
双线
是
总数据包数。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
已连接设备维度
↑ top
实体集:connected_device_dimension
字段 类型 可为Null 注释
tk
Int32
是
此织物行的 TK。
标识符
字符串
是
设备的标识符。
name
字符串
是
设备的名称。
制造商
字符串
是
设备制造商。
型号
字符串
是
设备的制造商型号。
type
字符串
是
设备的类型。
固件
字符串
是
设备上运行的固件版本。
ID
Int64
是
设备的 ID
最新
字符串
是
指示此行是否为此设备的最新行。
dateTk
Int32
是
此连接设备行的创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
"switch_performance_for_port_hourly_fact"
许多
数据存储_维度
↑ top
实体集:datastore_dimension
字段 类型 可为Null 注释
tk
Int32
是
此数据存储行的 TK。
naturalKey
字符串
是
数据存储库的 OID。
name
字符串
是
数据存储库的名称。
moid
字符串
是
数据存储的托管对象 ID。
virtualCenterIp
字符串
是
数据存储库虚拟中心的 IP 地址。
url
字符串
是
Insight Server 中此数据存储的 URL。
ID
Int64
是
dwh_inventory.hv_data_store 中数据存储库的 GUID
最新
字符串
是
指示此行是否为此数据存储库的最新行。
dateTk
Int32
是
此数据存储行创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
"vmdk_hourly_performance_fact"
许多
"vmdk_daily_performance_fact"
许多
日期维度
↑ top
实体集:date_dimension
字段 类型 可为Null 注释
tk
Int32
是
日期对象的 TK。
fullDate
DateTimeOffset
是
日期对象的日期。
dayInMonth
字节
是
日期对象的月份日期。每月的第一天值为 1。
dayInYear
Int32
是
日期对象在一年中的第几天。一年的第一天值为 1。
dateYear
Int32
是
日期对象的年份。
yearLabel
字符串
是
格式为字符串的年份
monthNum
字节
是
日期对象的月份。1月的值为1。
monthLabel
字符串
是
月份格式为字符串
dayInWeekNum
字节
是
日期对象的星期几。星期日的值为 1。
季度
字节
是
日期对象的季度。第一季度的值为 1。
quarterLabel
字符串
是
季度格式化为字符串
dayInQuarter
Int32
是
日期对象的季度中的天。季度的第一天值为 1。
repQuarter
字节
是
指示此日期是否是其季度的第一个可用日期。
repMonth
字节
是
指示此日期是否是其月份的第一个可用日期。
repWeek
字节
是
指示此日期是否是其一周内可用的第一个日期。
repDay
字节
是
指示此日期是否是其当天可用的第一个日期。
repMonthOrLatest
字节
是
指示此日期是代表月还是最新代表月。此标志由按月处理代表数据的 Datamarts 使用。唯一的区别在于当前月份使用的是最新数据
sspFlag
字节
是
指示此日期是否在存储和存储池数据集市中使用。这适用于月代表和配置中定义的最后天数。
最新
字符串
是
指示此日期是否为表中的最后一个可用日期。
未来
字符串
是
指示此日期是未来日期(预测)还是常规日期。
导航属性(联接)
导航属性 相关实体 基数/联接
"host_vm_daily_performance_fact"
许多
时间维度
"时间维度"
许多
许多
许多
许多
许多
许多
"switch_performance_for_tape_hourly_fact"
许多
许多
"switch_performance_for_storage_hourly_fact"
许多
"storage_node_hourly_performance_fact"
许多
许多
许多
许多
许多
许多
"storage_node_daily_performance_fact"
许多
"disk_hourly_performance_fact"
许多
"disk_daily_performance_fact"
许多
许多
许多
许多
"host_vm_hourly_performance_fact"
许多
↑ top
实体集:disk_daily_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int32
是
事实的 TK。
Int32
是
日期维度的 TK。
diskTk [FK] →"disk_dimension".tk
Int32
是
磁盘性能编号的 TK(如果找到)。
storageTk [FK] →"存储维度".tk
Int32
是
性能编号存储的 TK。
storagePoolTk [FK] →"存储池维度".tk
Int32
是
性能编号存储池的 TK。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readIops
双线
是
每秒读取 IO。
writeIops
双线
是
每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
readUtilization
双线
是
读取利用率(%)。
writeUtilization
双线
是
写入利用率(%)。
totalUtilization
双线
是
总利用率(%)。
totalUtilizationMax
双线
是
最大利用率(%)。
已访问
Int32
是
是否可以访问磁盘?
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
存储维度
"存储维度"
一个 JOIN:storageTk="存储维度".tk
存储池维度
"存储池维度"
一个 JOIN:storagePoolTk="存储池维度".tk
日期维度
"日期维度"
disk_dimension
"disk_dimension"
一个 JOIN:diskTk="disk_dimension".tk
disk_dimension
↑ top
实体集:disk_dimension
字段 类型 可为Null 注释
tk
Int32
是
此磁盘行的 TK。
标识符
字符串
是
磁盘的标识符。
storageIdentifier
字符串
是
磁盘存储的标识符。
name
字符串
是
磁盘的名称。
速度
Int32
是
磁盘速度。
位置
字符串
是
磁盘位置。
角色
字符串
是
存储组中磁盘的角色(例如 PARITY、DATA、SPARE)。
供应商
字符串
是
磁盘供应商(例如 NetApp、SEAGATE)。
型号
字符串
是
磁盘型号。
type
字符串
是
磁盘的类型(例如 SATA、FC)。
diskGroup
字符串
是
磁盘所属磁盘组的标识符(例如 rg0、7)。
状态
字符串
是
磁盘的状态(例如 NORMAL、FAILED)。
serialNumber
字符串
是
磁盘序列号
url
字符串
是
Insight Server 中此磁盘的 URL。
ID
Int64
是
dwh_inventory.disk 中磁盘的 GUID
最新
字符串
是
指示此行是否是此磁盘的最新行。
dateTk
Int32
是
此内部卷行的创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
↑ top
实体集:disk_hourly_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
Int32
是
磁盘性能编号的 TK(如果找到)。
Int32
是
性能编号存储的 TK。
Int32
是
性能编号存储池的 TK。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readIops
双线
是
每秒读取 IO。
writeIops
双线
是
每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
readUtilization
双线
是
读取利用率(%)。
writeUtilization
双线
是
写入利用率(%)。
totalUtilization
双线
是
总利用率(%)。
totalUtilizationMax
双线
是
最大利用率(%)。
已访问
Int32
是
是否可以访问磁盘?
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
存储维度
"存储维度"
时间维度
"时间维度"
存储池维度
"存储池维度"
日期维度
"日期维度"
disk_dimension
"disk_dimension"
fabric_dimension
↑ top
实体集:fabric_dimension
字段 类型 可为Null 注释
tk
Int32
是
此织物行的 TK。
标识符
字符串
是
网络结构的标识符。
wwn
字符串
是
网络结构的 WWN。
name
字符串
是
网络结构的名称。
vsanEnabled
字符串
是
指示此结构是否为 VSAN。
vsanId
字符串
是
此结构是 VSAN 时的 VSAN 标识符。
zoningEnabled
字符串
是
如果为 true,则根据区域和区域成员表中的数据强制执行分区。否则,不会在 Fabric 中实施分区。
url
字符串
是
Insight Server 中此结构的 URL。
ID
Int64
是
dwh_inventory.fabric 中 fabric 的 GUID
最新
字符串
是
指示此行是否为此网络结构的最新行。
dateTk
Int32
是
此织物行创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
主机维度
↑ top
实体集:host_dimension
字段 类型 可为Null 注释
tk
Int32
是
此主机行的 TK。
name
字符串
是
主机名称。
标识符
字符串
是
设备的标识符。
IP
字符串
是
以逗号分隔的主机 IP 地址列表。
操作系统
字符串
是
在主机上运行的操作系统。
型号
字符串
是
型号。
制造商
字符串
是
主机的制造商。
url
字符串
是
Insight Server 中此主机的 URL。
ID
Int64
是
dwh_inventory.host 中主机的 GUID。
最新
字符串
是
指示此行是否是此主机的最新行。
dateTk
Int32
是
此主机行创建日期的 TK。
dataCenter
字符串
是
dataCenter 注释值已分配给 dwh_dimensions.host_dimension
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
主机组桥接
↑ top
实体集:host_group_bridge
字段 类型 可为Null 注释
hostGroupTk
Int32
是
主机组的 TK。
hostTk
Int32
是
主机的 TK。
isRep
字符串
是
指示此主机是否代表其主机组。
主机组维度
↑ top
实体集:host_group_dimension
字段 类型 可为Null 注释
tk
Int32
是
主机组的 TK。
repHost
字符串
是
表示主机组的主机的名称。
repHostTk
Int32
是
代表主机组的主机的 TK。
基数
Int32
是
主机组中的主机数。
dateTk
Int32
是
此主机组行创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
↑ top
实体集:host_vm_daily_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int32
是
事实的 TK。
Int32
是
日期维度的 TK。
hostTk [FK] →"主机维度".tk
Int32
是
主机的 TK。
readIops
双线
是
每秒读取 IO。
writeIops
双线
是
每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间。
totalResponseTime
双线
是
总响应时间。
双线
是
总最大响应时间。
ipReceiveThroughput
双线
是
IP 接收吞吐量。
ipTransmitThroughput
双线
是
IP 传输吞吐量。
ipTotalThroughput
双线
是
IP 总吞吐量。
ipTotalThroughputMax
双线
是
最大IP总吞吐量。
cpuUtilization
双线
是
CPU利用率(%)
maxOfAvgCpuUtilization
双线
是
最大CPU利用率(%)
memoryUtilization
双线
是
内存利用率(%)
maxOfAvgMemoryUtilization
双线
是
最大内存利用率(%)
swapInRate
双线
是
互换利率
maxOfAvgSwapInRate
双线
是
最大换入速率
swapOutRate
双线
是
换出率
maxOfAvgSwapOutRate
双线
是
最大换出速率
swapTotalRate
双线
是
总交换率
swapTotalRateMax
双线
是
最大总交换速率
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
主机维度
"主机维度"
一个 JOIN:hostTk="主机维度".tk
日期维度
"日期维度"
↑ top
实体集:host_vm_hourly_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
Int32
是
主机的 TK。
readIops
双线
是
每秒读取 IO。
writeIops
双线
是
每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间。
totalResponseTime
双线
是
总响应时间。
双线
是
总最大响应时间。
ipReceiveThroughput
双线
是
IP 接收吞吐量。
双线
是
IP 传输吞吐量。
ipTotalThroughput
双线
是
IP 总吞吐量。
双线
是
最大IP总吞吐量。
cpuUtilization
双线
是
CPU利用率(%)
memoryUtilization
双线
是
内存利用率(%)
swapInRate
双线
是
互换利率
swapOutRate
双线
是
换出率
swapTotalRate
双线
是
总交换率
swapTotalRateMax
双线
是
最大总交换速率
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
时间维度
"时间维度"
主机维度
"主机维度"
日期维度
"日期维度"
↑ top
实体集:host_volume_hourly_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
Int32
是
房东代表的 TK。
hostGroupTk [FK] →"主机组维度".tk
Int32
是
主机组的 TK。
Int32
是
层的 TK。
Int32
是
服务级别的 TK。
Int32
是
商业实体的 TK。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间
totalResponseTime
双线
是
总响应时间。
双线
是
响应时间的最大值。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
双线
是
与主机相关的所有卷每小时样本的 totalThroughput 总和。表示主机的平均使用量。
双线
是
与主机相关的所有卷每小时样本的最大 totalThroughputMax。代表主机最大使用量的最佳情形。
双线
是
与主机相关的所有卷每小时样本的 totalThroughputMax 之和。表示当所有最大值同时发生时最大使用量的最坏情况。
readIops
双线
是
平均每秒读取 io。
writeIops
双线
是
平均每秒写入 io。
双线
是
与主机相关的所有卷每小时样本的 totalIops 总和。表示主机的平均使用量。
maxOfMaxVolumeIops
双线
是
与主机相关的所有卷每小时样本的最大 totalIopsMax。代表主机最大使用量的最佳情形。
sumOfMaxVolumeIops
双线
是
与主机相关的所有卷每小时样本的 totalIopsMax 之和。表示当所有最大值同时发生时最大使用量的最坏情况。
readCacheHitRatio
双线
是
读缓存命中率。
writeCacheHitRatio
双线
是
写入缓存命中率。
totalCacheHitRatio
双线
是
总缓存命中率。
双线
是
最大总缓存命中率。
writePending
Int64
是
挂起的写入次数。
readIoDensity
双线
是
读取 io 密度。
writeIoDensity
双线
是
写入 IO 密度。
totalIoDensity
双线
是
总 IO 密度。
totalIoDensityMax
双线
是
最大总 IO 密度。
双线
是
压缩节省量 (%)。
双线
是
压缩节省空间。
totalTimeToFull
双线
是
充满时间。
双线
是
Time to Full 的置信区间。
导航属性(联接)
导航属性 相关实体 基数/联接
服务级别维度
"服务级别维度"
层级维度
"层级维度"
业务实体维度
"业务实体维度"
时间维度
"时间维度"
主机组维度
"主机组维度"
一个 JOIN:hostGroupTk="主机组维度".tk
主机维度
"主机维度"
日期维度
"日期维度"
↑ top
实体集:internal_volume_daily_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int32
是
事实的 TK。
Int32
是
日期维度的 TK。
internalVolumeTk [FK] →"内部卷尺寸".tk
Int32
是
内部卷的性能数据的 TK(如果找到)。
Int32
是
性能编号存储的 TK。
virtualStorageTk
Int32
是
前端阵列的 TK(如果容量位于后端阵列上)。否则,值为 N/A。
storageNodeTk [FK] →"存储节点尺寸".tk
Int32
是
存储节点的 TK。
Int32
是
存储池的 TK,用于性能数字(如果找到)。
Int32
是
应用程序代表的 TK。
Int32
是
应用程序组的 TK。
Int32
是
层的 TK。
Int32
是
服务级别的 TK。
Int32
是
商业实体的 TK。
k8sNamespaceTk [FK] →"k8s_namespace_dimension".tk
Int32
是
k8s 命名空间的 TK。
k8sNamespaceGroupTk [FK] →"k8s_namespace_group_dimension".tk
Int32
是
k8s 命名空间组的 TK。
readResponseTime
双线
是
读取平均响应时间。
writeResponseTime
双线
是
写入平均响应时间。
totalResponseTime
双线
是
总响应时间的平均值。
双线
是
响应时间的最大值。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readIops
双线
是
平均每秒读取 io。
writeIops
双线
是
平均每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
writePending
Int64
是
一天的最大挂起写入次数。
readIoDensity
双线
是
读取 io 密度。
writeIoDensity
双线
是
写入 IO 密度。
totalIoDensity
双线
是
总 IO 密度。
totalIoDensityMax
双线
是
最大总 IO 密度。
objectCount
双线
是
对象计数。
filesystemCapacityPhysicalUsed
双线
是
文件系统物理已用容量(GB)。
filesystemCapacityPhysicalAvailable
双线
是
文件系统物理可用容量(GB)。
filesystemCapacityLogicalUsed
双线
是
文件系统逻辑已用容量(GB)。
totalTimeToFull
双线
是
充满时间。
双线
是
Time to Full 的置信区间。
已访问
Int32
是
是否访问内部卷?
前端
字符串
是
是内部卷前端吗?
后端
字符串
是
是内部卷后端吗?
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
服务级别维度
"服务级别维度"
内部卷尺寸
"内部卷尺寸"
一个 JOIN:internalVolumeTk="内部卷尺寸".tk
存储节点尺寸
"存储节点尺寸"
一个 JOIN:storageNodeTk="存储节点尺寸".tk
存储维度
"存储维度"
层级维度
"层级维度"
业务实体维度
"业务实体维度"
应用维度
"应用维度"
存储池维度
"存储池维度"
日期维度
"日期维度"
一个 JOIN:k8sNamespaceGroupTk="k8s_namespace_group_dimension".tk
应用组维度
"应用组维度"
一个 JOIN:k8sNamespaceTk="k8s_namespace_dimension".tk
内部卷尺寸
↑ top
实体集:internal_volume_dimension
字段 类型 可为Null 注释
tk
Int32
是
此内部卷行的 TK。
name
字符串
是
内部卷的名称。
标识符
字符串
是
内部卷的标识符。
storagePoolIdentifier
字符串
是
此内部卷所在的存储池的标识符。
storageName
字符串
是
此内部卷所在的存储的名称。
storageIP
字符串
是
此内部卷所在存储的 IP。
type
字符串
是
内部卷类型。
virtualStorage
字符串
是
指定VirtualStorage(例如vFiler)
spaceGuarantee
字符串
是
内部卷空间保证。
thinProvisioningSupported
字符串
是
内部卷是否支持精简配置。
thinProvisioned
字符串
是
内部卷是否为精简配置。
uuid
字符串
是
内部卷的 UUID。
flexGroupIdentifier
字符串
是
FlexGroup 标识符,此内部卷属于该标识符。
url
字符串
是
Insight Server 中此内部卷的 URL。
ID
Int64
是
dwh_inventory.internal_volume 中的内部卷的 GUID
最新
字符串
是
指示此行是否是此内部卷的最新行。
dateTk
Int32
是
此内部卷行的创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
↑ top
实体集:internal_volume_hourly_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
Int32
是
内部卷的性能数据的 TK(如果找到)。
Int32
是
性能编号存储的 TK。
virtualStorageTk
Int32
是
Int32
是
存储节点的 TK。
Int32
是
Int32
是
应用程序代表的 TK。
Int32
是
应用程序组的 TK。
Int32
是
层的 TK。
Int32
是
服务级别的 TK。
Int32
是
商业实体的 TK。
Int32
是
k8s 命名空间的 TK。
Int32
是
k8s 命名空间组的 TK。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间
totalResponseTime
双线
是
总响应时间。
双线
是
响应时间的最大值。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readIops
双线
是
每秒读取 IO。
writeIops
双线
是
每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
writePending
Int64
是
挂起的写入次数。
readIoDensity
双线
是
读取 io 密度。
writeIoDensity
双线
是
写入 IO 密度。
totalIoDensity
双线
是
总 IO 密度。
totalIoDensityMax
双线
是
最大总 IO 密度。
objectCount
双线
是
对象计数。
双线
是
文件系统物理已用容量(GB)。
双线
是
文件系统物理可用容量(GB)。
双线
是
文件系统逻辑已用容量(GB)。
totalTimeToFull
双线
是
充满时间。
双线
是
Time to Full 的置信区间。
已访问
Int32
是
是否访问内部卷?
前端
字符串
是
是内部卷前端吗?
后端
字符串
是
是内部卷后端吗?
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
内部卷尺寸
"内部卷尺寸"
存储节点尺寸
"存储节点尺寸"
存储维度
"存储维度"
业务实体维度
"业务实体维度"
应用组维度
"应用组维度"
服务级别维度
"服务级别维度"
层级维度
"层级维度"
应用维度
"应用维度"
时间维度
"时间维度"
存储池维度
"存储池维度"
日期维度
"日期维度"
k8s_cluster_daily_metrics_fact
↑ top
实体集:k8s_cluster_daily_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
dateTk
Int32
是
日期维度的 TK。
clusterTk
Int32
是
K8s 集群的 TK。
allocatableCpuSaturation
双线
是
可分配 CPU 饱和度百分比。
capacityCpuSaturation
双线
是
容量 CPU 饱和度百分比。
allocatableMemorySaturation
双线
是
可分配内存饱和度百分比。
capacityMemorySaturation
双线
是
容量内存饱和度百分比。
allocatableCpuCores
双线
是
可分配 CPU 内核。
capacityCpuCores
双线
是
容量 CPU 内核。
usageCpuCores
双线
是
CPU内核使用量。
requestsCpuCores
双线
是
请求 CPU 内核。
limitsCpuCores
双线
是
限制 CPU 内核。
allocatableMemoryBytes
双线
是
可分配内存(以字节为单位)。
capacityMemoryBytes
双线
是
容量内存(以字节为单位)。
limitsMemoryBytes
双线
是
限制内存(以字节为单位)。
requestsMemoryBytes
双线
是
请求内存(以字节为单位)。
usageMemoryBytes
双线
是
使用内存(以字节为单位)。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
k8s_cluster_dimension
↑ top
实体集:k8s_cluster_dimension
字段 类型 可为Null 注释
tk
Int32
是
此群集行的 TK。
标识符
字符串
是
集群的唯一标识符。
name
字符串
是
集群的名称。
ID
Int64
是
dwh_inventory.k8s_cluster 中的集群 GUID
最新
字符串
是
指示此行是否是此集群的最新行。
dateTk
Int32
是
此群集行的创建日期的 TK。
k8s_cluster_hourly_metrics_fact
↑ top
实体集:k8s_cluster_hourly_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
timeTk
Int32
是
时间维度的 TK。
dateTk
Int32
是
日期维度的 TK。
clusterTk
Int32
是
K8s 集群的 TK。
双线
是
可分配 CPU 饱和度百分比。
双线
是
容量 CPU 饱和度百分比。
双线
是
可分配内存饱和度百分比。
双线
是
容量内存饱和度百分比。
allocatableCpuCores
双线
是
可分配 CPU 内核。
capacityCpuCores
双线
是
容量 CPU 内核。
usageCpuCores
双线
是
CPU内核使用量。
requestsCpuCores
双线
是
请求 CPU 内核。
limitsCpuCores
双线
是
限制 CPU 内核。
双线
是
可分配内存(以字节为单位)。
capacityMemoryBytes
双线
是
容量内存(以字节为单位)。
limitsMemoryBytes
双线
是
限制内存(以字节为单位)。
requestsMemoryBytes
双线
是
请求内存(以字节为单位)。
usageMemoryBytes
双线
是
使用内存(以字节为单位)。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
k8s_namespace_daily_metrics_fact
↑ top
实体集:k8s_namespace_daily_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
dateTk
Int32
是
日期维度的 TK。
namespaceTk
Int32
是
k8s 命名空间的 TK。
clusterTk
Int32
是
K8s 集群的 TK。
cpuHardLimit
双线
是
K8S 命名空间 CPU 硬限制。
cpuUsedLimit
双线
是
K8S 命名空间 CPU 使用限制。
cpuHardRequest
双线
是
K8S 命名空间 CPU 硬请求。
cpuUsedRequest
双线
是
K8S 命名空间 CPU 已使用请求。
memoryHardLimit
双线
是
K8S 命名空间内存硬限制。
memoryUsedLimit
双线
是
K8S 命名空间内存使用限制。
memoryHardRequest
双线
是
K8S 命名空间内存硬请求。
memoryUsedRequest
双线
是
K8S 命名空间内存已用请求。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
↑ top
实体集:k8s_namespace_dimension
字段 类型 可为Null 注释
tk
Int32
是
此命名空间行的 TK。
标识符
字符串
是
命名空间的唯一标识符。
name
字符串
是
命名空间的名称。
clusterName
字符串
是
命名空间的集群名称。
ID
Int64
是
dwh_inventory.k8s_namespace 中命名空间的 GUID
最新
字符串
是
指示此行是否为此命名空间的最新行。
dateTk
Int32
是
此命名空间行的创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
许多
许多
k8s_namespace_group_bridge
↑ top
实体集:k8s_namespace_group_bridge
字段 类型 可为Null 注释
k8sNamespaceGroupTk
Int32
是
k8s 命名空间组的 TK。
k8sNamespaceTk
Int32
是
k8s 命名空间的 TK。
isRep
字符串
是
指示此 k8s 命名空间是否表示其 k8s 命名空间组。
↑ top
实体集:k8s_namespace_group_dimension
字段 类型 可为Null 注释
tk
Int32
是
k8s 命名空间组的 TK。
repK8sNamespace
字符串
是
表示 k8s 命名空间组的应用程序的名称。
repK8sNamespaceTk
Int32
是
表示组的 k8s 命名空间的 TK。
基数
Int32
是
应用程序组中的 k8s 命名空间数。
dateTk
Int32
是
K8S 命名空间组行创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
许多
许多
k8s_namespace_hourly_metrics_fact
↑ top
实体集:k8s_namespace_hourly_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
timeTk
Int32
是
时间维度的 TK。
dateTk
Int32
是
日期维度的 TK。
namespaceTk
Int32
是
k8s 命名空间的 TK。
clusterTk
Int32
是
K8s 集群的 TK。
cpuHardLimit
双线
是
K8S 命名空间 CPU 硬限制。
cpuUsedLimit
双线
是
K8S 命名空间 CPU 使用限制。
cpuHardRequest
双线
是
K8S 命名空间 CPU 硬请求。
cpuUsedRequest
双线
是
K8S 命名空间 CPU 已使用请求。
memoryHardLimit
双线
是
K8S 命名空间内存硬限制。
memoryUsedLimit
双线
是
K8S 命名空间内存使用限制。
memoryHardRequest
双线
是
K8S 命名空间内存硬请求。
memoryUsedRequest
双线
是
K8S 命名空间内存已用请求。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
k8s_node_daily_metrics_fact
↑ top
实体集:k8s_node_daily_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
dateTk
Int32
是
日期维度的 TK。
nodeTk
Int32
是
K8s 节点的 TK。
clusterTk
Int32
是
K8s 集群的 TK。
vmTk
Int32
是
VM 的 TK。
双线
是
可分配 CPU 饱和度百分比。
双线
是
容量 CPU 饱和度百分比。
双线
是
可分配内存饱和度百分比。
双线
是
容量内存饱和度百分比。
双线
是
可分配内存(字节)。
capacityMemoryBytes
双线
是
容量内存(字节)。
memoryUsageBytes
双线
是
内存使用量(字节)。
cpuUsageNanocores
双线
是
CPU 使用量(以纳核为单位)。
allocatableCpu
双线
是
Kube 节点状态可分配 CPU。
capacityCpu
双线
是
Kube 节点状态容量 CPU。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
k8s_node_dimension
↑ top
实体集:k8s_node_dimension
字段 类型 可为Null 注释
tk
Int32
是
此节点行的 TK。
标识符
字符串
是
节点的唯一标识符。
name
字符串
是
节点名称。
clusterName
字符串
是
节点的集群名称。
internalIp
字符串
是
K8S 节点的内部 IP
osImage
字符串
是
K8S 节点的 OS 映像
ID
Int64
是
dwh_inventory.k8s_node 中节点的 GUID
最新
字符串
是
指示此行是否为此节点的最新行。
dateTk
Int32
是
此节点行创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
k8s_node_hourly_metrics_fact
↑ top
实体集:k8s_node_hourly_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
timeTk
Int32
是
时间维度的 TK。
dateTk
Int32
是
日期维度的 TK。
nodeTk
Int32
是
K8s 节点的 TK。
clusterTk
Int32
是
K8s 集群的 TK。
vmTk
Int32
是
VM 的 TK。
双线
是
可分配 CPU 饱和度百分比。
双线
是
容量 CPU 饱和度百分比。
双线
是
可分配内存饱和度百分比。
双线
是
容量内存饱和度百分比。
双线
是
可分配内存(字节)。
capacityMemoryBytes
双线
是
容量内存(字节)。
memoryUsageBytes
双线
是
内存使用量(字节)。
cpuUsageNanocores
双线
是
CPU 使用量(以纳核为单位)。
allocatableCpu
双线
是
Kube 节点状态可分配 CPU。
capacityCpu
双线
是
Kube 节点状态容量 CPU。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
k8s_pv_dimension
↑ top
实体集:k8s_pv_dimension
字段 类型 可为Null 注释
tk
Int32
是
此 PV 行的 TK。
标识符
字符串
是
pv 的唯一标识符。
name
字符串
是
PV 的名称。
clusterName
字符串
是
pv 的集群名称。
阶段
字符串
是
K8S 持久卷的阶段(绑定等)
pvcName
字符串
是
K8S 持久卷绑定到的 pvc 的名称
storageClass
字符串
是
K8S 永久卷的存储类的名称
ID
Int64
是
dwh_inventory.k8s_pv 中 pvc 的 GUID
最新
字符串
是
指示此行是否为此 pv 的最新行。
dateTk
Int32
是
此 PV 行创建日期的 TK。
k8s_pvc_daily_metrics_fact
↑ top
实体集:k8s_pvc_daily_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
dateTk
Int32
是
日期维度的 TK。
pvcTk
Int32
是
K8s pvc 的 TK。
clusterTk
Int32
是
K8s 集群的 TK。
namespaceTk
Int32
是
k8s 命名空间的 TK。
pvTk
Int32
是
K8s pv 的 TK。
readIops
双线
是
K8S pvc Read Iops。
writeIops
双线
是
K8S pvc Write Iops。
totalIops
双线
是
K8S pvc 总 Iops。
readThroughput
双线
是
K8S pvc 读取吞吐量。
writeThroughput
双线
是
K8S pvc 写入吞吐量。
totalThroughput
双线
是
K8S pvc 总吞吐量。
readLatency
双线
是
K8S pvc 读取延迟。
writeLatency
双线
是
K8S pvc Write Latency。
totalLatency
双线
是
K8S pvc Total Latency。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
k8s_pvc_dimension
↑ top
实体集:k8s_pvc_dimension
字段 类型 可为Null 注释
tk
Int32
是
此pvc行的TK。
标识符
字符串
是
pvc 的唯一标识符。
name
字符串
是
PVC 的名称。
clusterName
字符串
是
pvc 的集群名称。
namespaceName
字符串
是
pvc 的命名空间名称。
pvName
字符串
是
链接到此 PVC 的 PV 名称。
阶段
字符串
是
K8S 持久卷声明的阶段(绑定等)
ID
Int64
是
dwh_inventory.k8s_pvc 中 pvc 的 GUID
最新
字符串
是
指示此行是否为此 pvc 的最新行。
dateTk
Int32
是
此pvc行的创建日期的TK。
k8s_pvc_hourly_metrics_fact
↑ top
实体集:k8s_pvc_hourly_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
timeTk
Int32
是
时间维度的 TK。
dateTk
Int32
是
日期维度的 TK。
pvcTk
Int32
是
K8s pvc 的 TK。
clusterTk
Int32
是
K8s 集群的 TK。
namespaceTk
Int32
是
k8s 命名空间的 TK。
pvTk
Int32
是
K8s pv 的 TK。
readIops
双线
是
K8S pvc Read Iops。
writeIops
双线
是
K8S pvc Write Iops。
totalIops
双线
是
K8S pvc 总 Iops。
readThroughput
双线
是
K8S pvc 读取吞吐量。
writeThroughput
双线
是
K8S pvc 写入吞吐量。
totalThroughput
双线
是
K8S pvc 总吞吐量。
readLatency
双线
是
K8S pvc 读取延迟。
writeLatency
双线
是
totalLatency
双线
是
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
k8s_workload_daily_metrics_fact
↑ top
实体集:k8s_workload_daily_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
dateTk
Int32
是
日期维度的 TK。
workloadTk
Int32
是
k8s 工作负载的 TK。
clusterTk
Int32
是
K8s 集群的 TK。
namespaceTk
Int32
是
k8s 命名空间的 TK。
usageCpuCores
双线
是
K8S 工作负载 CPU 使用量(核心数)。
requestCpuCores
双线
是
K8S 工作负载请求 CPU(核心)。
limitCpuCores
双线
是
K8S 工作负载限制 CPU(核心)。
usageMemoryBytes
双线
是
K8S 工作负载内存使用量(字节)。
requestMemoryBytes
双线
是
K8S 工作负载请求内存(字节)。
limitMemoryBytes
双线
是
K8S 工作负载限制内存(字节)。
runningPodCount
Int32
是
K8S 工作负载正在运行的副本数。
desiredPodCount
Int32
是
K8S 工作负载所需副本的数量。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
k8s_workload_dimension
↑ top
实体集:k8s_workload_dimension
字段 类型 可为Null 注释
tk
Int32
是
此工作负载行的 TK。
标识符
字符串
是
工作负载的唯一标识符。
name
字符串
是
工作负载的名称。
clusterName
字符串
是
工作负载的集群名称。
namespaceName
字符串
是
工作负载的命名空间名称。
type
字符串
是
工作负载类型(Pod、statefulset 等)
ID
Int64
是
dwh_inventory.k8s_workload 中工作负载的 GUID
最新
字符串
是
指示此行是否是此工作负载的最新行。
dateTk
Int32
是
此工作负载行创建日期的 TK。
k8s_workload_hourly_metrics_fact
↑ top
实体集:k8s_workload_hourly_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
timeTk
Int32
是
时间维度的 TK。
dateTk
Int32
是
日期维度的 TK。
workloadTk
Int32
是
k8s 工作负载的 TK。
clusterTk
Int32
是
K8s 集群的 TK。
namespaceTk
Int32
是
k8s 命名空间的 TK。
usageCpuCores
双线
是
requestCpuCores
双线
是
K8S 工作负载请求 CPU(核心)。
limitCpuCores
双线
是
K8S 工作负载限制 CPU(核心)。
usageMemoryBytes
双线
是
K8S 工作负载内存使用量(字节)。
requestMemoryBytes
双线
是
K8S 工作负载请求内存(字节)。
limitMemoryBytes
双线
是
K8S 工作负载限制内存(字节)。
runningPodCount
Int32
是
K8S 工作负载正在运行的副本数。
desiredPodCount
Int32
是
K8S 工作负载所需副本的数量。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
端口尺寸
↑ top
实体集:port_dimension
字段 类型 可为Null 注释
tk
Int32
是
此端口行的 TK。
wwn
字符串
是
端口的WWN。
name
字符串
是
端口名称。
gbicType
字符串
是
用于端口的 GBIC(千兆接口转换器)类型。
type
字符串
是
端口类型,通常用于标识与其他设备通信所使用的协议,取自设备本身:F-port、E-port 等。
速度
字符串
是
端口速度,以 Gbps 为单位。
isGenerated
字符串
是
指示这是否是生成的 wwn(如果我们不知道真正的 wwn)。
url
字符串
是
Insight Server 中此端口的 URL。
ID
Int64
是
dwh_inventory.switch_port 中端口的 GUID。
最新
字符串
是
指示此行是否是此端口的最新行。
dateTk
Int32
是
创建端口行的日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
↑ top
实体集:qtree_daily_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int32
是
事实的 TK。
Int32
是
日期维度的 TK。
qtreeTk [FK] →"qtree_dimension".tk
Int32
是
性能计数器的 qtree 的 TK。
Int32
是
性能计数器的 qtree 存储的 TK。
Int32
是
性能计数器的qtree存储池的TK。
Int32
是
性能计数器的 qtree 内部卷的 TK。
virtualStorageTk
Int32
是
如果此 qtree 位于虚拟内部卷上,则为前端阵列的 TK。否则,值为 N/A。
Int32
是
层的 TK。
Int32
是
服务级别的 TK。
Int32
是
应用程序的 TK。
Int32
是
应用程序组的 TK。
Int32
是
商业实体的 TK。
Int32
是
k8s 命名空间的 TK。
Int32
是
k8s 命名空间组的 TK。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
服务级别维度
"服务级别维度"
内部卷尺寸
"内部卷尺寸"
存储维度
"存储维度"
层级维度
"层级维度"
业务实体维度
"业务实体维度"
应用维度
"应用维度"
qtree_dimension
"qtree_dimension"
一个 JOIN:qtreeTk="qtree_dimension".tk
存储池维度
"存储池维度"
日期维度
"日期维度"
应用组维度
"应用组维度"
qtree_dimension
↑ top
实体集:qtree_dimension
字段 类型 可为Null 注释
tk
Int32
是
此 qtree 行的 TK。
name
字符串
是
qtree 的名称。
标识符
字符串
是
qtree 的标识符。
storageIdentifier
字符串
是
此qtree驻留的存储的标识符。
type
字符串
是
Qtree 类型。
url
字符串
是
Insight Server 中此 qtree 的 URL。
ID
Int64
是
dwh_inventory.qtree 中的 qtree 的 GUID
最新
字符串
是
指示此行是否为此 qtree 的最新行。
dateTk
Int32
是
此qtree行的创建日期的TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
↑ top
实体集:qtree_hourly_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
Int32
是
性能计数器的 qtree 的 TK。
Int32
是
Int32
是
性能计数器的qtree存储池的TK。
Int32
是
virtualStorageTk
Int32
是
Int32
是
层的 TK。
Int32
是
服务级别的 TK。
Int32
是
应用程序的 TK。
Int32
是
应用程序组的 TK。
Int32
是
商业实体的 TK。
Int32
是
k8s 命名空间的 TK。
Int32
是
k8s 命名空间组的 TK。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
内部卷尺寸
"内部卷尺寸"
存储维度
"存储维度"
业务实体维度
"业务实体维度"
应用组维度
"应用组维度"
服务级别维度
"服务级别维度"
层级维度
"层级维度"
应用维度
"应用维度"
时间维度
"时间维度"
qtree_dimension
"qtree_dimension"
存储池维度
"存储池维度"
日期维度
"日期维度"
服务级别维度
↑ top
实体集:service_level_dimension
字段 类型 可为Null 注释
tk
Int32
是
此服务级别行的 TK。
name
字符串
是
标识服务级别的名称。
序列
Int32
是
dwh_inventory.annotation_value 中定义的服务级别的序列号。
成本
双线
是
与此服务级别关联的成本。
ID
Int64
是
dwh_inventory.annotation_value 中服务级别的 GUID。
最新
字符串
是
指示此行是否为此服务级别的最新行。
dateTk
Int32
是
此服务级别行的创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
存储维度
↑ top
实体集:storage_dimension
字段 类型 可为Null 注释
tk
Int32
是
此存储阵列行的 TK。
name
字符串
是
存储阵列的名称。
标识符
字符串
是
设备的标识符。
IP
字符串
是
存储阵列的 IP 地址。
型号
字符串
是
存储阵列的型号。
制造商
字符串
是
存储阵列的制造商。
serialNumber
字符串
是
存储阵列的序列号。
microcodeVersion
字符串
是
存储阵列上运行的固件版本。
family(系列)
字符串
是
存储阵列的系列名称(例如 Clariion、Symmetrix 等)。
url
字符串
是
Insight Server 中此存储的 URL。
ID
Int64
是
dwh_inventory.storage 中存储阵列的 GUID。
最新
字符串
是
指示此行是否是此存储的最新行。
dateTk
Int32
是
创建此存储阵列行的日期的 TK。
dataCenter
字符串
是
dataCenter 注释值已分配给 dwh_dimensions.storage_dimension
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
↑ top
实体集:storage_node_daily_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int32
是
事实的 TK。
Int32
是
日期维度的 TK。
Int32
是
存储的 TK。
Int32
是
存储节点的 TK。
Int32
是
层的 TK。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间。
totalResponseTime
双线
是
总响应时间。
双线
是
总最大响应时间。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readIops
双线
是
每秒读取 IO。
writeIops
双线
是
每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
diskReadsReplaced
双线
是
磁盘读取已更换。
cacheHitRatio
双线
是
缓存命中率。
利用率
双线
是
利用率 (%)
utilizationMax
双线
是
最大利用率(%)
readFileSystemIops
双线
是
文件系统读取 IOPS
writeFileSystemIops
双线
是
文件系统写入 IOPS
readFileSystemThroughput
双线
是
文件系统读取吞吐量
writeFileSystemThroughput
双线
是
文件系统写入吞吐量
portUtilization
双线
是
[Deprecated] 端口利用率 (%)
portErrors
Int64
是
[Deprecated] 端口错误。
portTraffic
双线
是
[Deprecated] 端口流量。
已访问
Int32
是
是否可以访问存储节点?
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
存储节点尺寸
"存储节点尺寸"
存储维度
"存储维度"
层级维度
"层级维度"
日期维度
"日期维度"
存储节点尺寸
↑ top
实体集:storage_node_dimension
字段 类型 可为Null 注释
tk
Int32
是
此存储节点行的 TK。
name
字符串
是
存储节点的名称。
标识符
字符串
是
存储节点的标识符。
version
字符串
是
存储节点的版本。
型号
字符串
是
存储节点的型号。
serialNumber
字符串
是
SerialNumber 是存储节点的序列号。
siteName
字符串
是
存储节点的站点名称。
url
字符串
是
Insight Server 中此存储节点的 URL。
ID
Int64
是
dwh_inventory.storage_node 中存储节点的 GUID
最新
字符串
是
指示此行是否是此存储节点的最新行。
dateTk
Int32
是
此存储节点行的创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
许多
许多
↑ top
实体集:storage_node_hourly_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int32
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
Int32
是
存储的 TK。
Int32
是
存储节点的 TK。
Int32
是
层的 TK。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间。
totalResponseTime
双线
是
总响应时间。
双线
是
总最大响应时间。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readIops
双线
是
每秒读取 IO。
writeIops
双线
是
每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
diskReadsReplaced
双线
是
磁盘读取已更换。
cacheHitRatio
双线
是
缓存命中率。
利用率
双线
是
利用率 (%)
utilizationMax
双线
是
最大利用率(%)
readFileSystemIops
双线
是
文件系统读取 IOPS
writeFileSystemIops
双线
是
文件系统写入 IOPS
双线
是
文件系统读取吞吐量
双线
是
文件系统写入吞吐量
portUtilization
双线
是
portErrors
Int64
是
[Deprecated] 端口错误。
portTraffic
双线
是
[Deprecated] 端口流量。
已访问
Int32
是
是否可以访问存储节点?
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
存储节点尺寸
"存储节点尺寸"
存储维度
"存储维度"
层级维度
"层级维度"
时间维度
"时间维度"
日期维度
"日期维度"
存储池维度
↑ top
实体集:storage_pool_dimension
字段 类型 可为Null 注释
tk
Int32
是
此存储池行的 TK。
标识符
字符串
是
设备的标识符。
name
字符串
是
存储池的名称。
storageName
字符串
是
此存储池所在的存储的名称。
storageIP
字符串
是
此存储池所在存储的 IP。
type
字符串
是
存储池类型(例如 RAID、AGGREGATE 等)。
冗余
字符串
是
存储池冗余。
字符串
是
指示存储池是否支持精简配置。
isVirtual
字符串
是
虚拟表示这是阵列虚拟化中的前端存储池。
usesFlashPools
字符串
是
指示此存储池是否使用闪存池。
url
字符串
是
Insight Server 中此存储池的 URL。
ID
Int64
是
dwh_inventory.storage_pool 中存储池的 GUID
最新
字符串
是
指示此行是否为此存储池的最新行。
dateTk
Int32
是
此存储池行的创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
许多
许多
许多
许多
切换维度
↑ top
实体集:switch_dimension
字段 类型 可为Null 注释
tk
Int32
是
此开关行的 TK。
wwn
字符串
是
交换机的 WWN。
name
字符串
是
交换机的名称。
标识符
字符串
是
设备的标识符。
IP
字符串
是
交换机的 IP 地址。
型号
字符串
是
交换机型号。
制造商
字符串
是
交换机制造商。
固件
字符串
是
交换机上运行的固件版本。
serialNumber
字符串
是
交换机的序列号。
npv
字符串
是
指示此交换机是否为 NPV 交换机。
isGenerated
字符串
是
指示此交换机是否与物理设备不对应。它用于对一对多端口连接进行建模。
type
字符串
是
交换机类型。
url
字符串
是
Insight Server 中此交换机的 URL。
ID
Int64
是
dwh_inventory.switch 中交换机的 GUID。
最新
字符串
是
指示此行是否为此交换机的最新行。
dateTk
Int32
是
此开关行创建日期的 TK。
dataCenter
字符串
是
dataCenter 注释值已分配给 dwh_dimensions.switch_dimension
switchLevel
字符串
是
switchLevel 注释值已分配给 dwh_dimensions.switch_dimension
导航属性(联接)
导航属性 相关实体 基数/联接
许多
↑ top
实体集:switch_performance_for_host_hourly_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
Int32
是
主机的 TK。
Int32
是
主机的代表性应用程序维度的 TK。
Int32
是
应用程序组维度的 TK。
Int32
是
业务实体维度的 TK。
rxTraffic
双线
是
接收流量(MB)
txTraffic
双线
是
正在传输流量(MB)
totalTraffic
双线
是
总流量(MB)
errorRateFlag
字符串
是
错误率标记
crcErrorRateFlag
字符串
是
CRC错误率标志
syncLossCount
Int64
是
同步丢失计数
signalLossCount
Int64
是
信号丢失计数
class3DiscardCount
Int64
是
Class 3 丢弃计数
frameTooShortCount
Int64
是
帧太短计数
frameTooLongCount
Int64
是
帧过长计数
bbCreditErrorCount
Int64
是
BB 信用错误计数
rx
双线
是
接收使用率(%)
tx
双线
是
传输使用率(%)
rxMax
双线
是
最大接收使用率(%)
txMax
双线
是
最大传输使用率(%)
trafficUtilizationTotal
双线
是
总流量使用率(%)
trafficUtilizationTotalMax
双线
是
最大总流量使用率(%)
rxLinkResets
Int64
是
接收链接重置
txLinkResets
Int64
是
传输链接重置
balanceIndex
Int32
是
主机端口平衡索引
weightedBalanceIndex
Int32
是
主机端口加权均衡索引
portSpeed
Int32
是
FACT 的端口速度
portCount
Int32
是
事实的端口计数
portErrorsLinkFailure
Int64
是
链路故障计数
bbCreditZeroRx
Int64
是
接收 BBCredit 零
bbCreditZeroTx
Int64
是
转移 BBCredit zero
bbCreditZeroMsTx
双线
是
[已弃用] Transfer BBCredit Zero Ms
bbCreditZeroTotal
Int64
是
总 BBCredit 为零
trafficRateTx
双线
是
传输流量速率
trafficRateRx
双线
是
接收流量速率
trafficRateTotal
双线
是
总流量率
trafficFrameRateTx
双线
是
传输流量帧速率
trafficFrameRateRx
双线
是
接收流量帧速率
trafficFrameRateTotal
双线
是
总流量帧速率
trafficFrameSizeAvgTx
Int64
是
传输流量帧平均大小
trafficFrameSizeAvgRx
Int64
是
接收流量帧平均大小
portErrorsTimeoutDiscardTx
Int64
是
传输超时丢弃计数
portErrorsCrc
Int64
是
CRC错误计数
portErrorsEncIn
Int64
是
帧内编码错误
portErrorsEncOut
Int64
是
帧外的编码错误
导航属性(联接)
导航属性 相关实体 基数/联接
业务实体维度
"业务实体维度"
应用维度
"应用维度"
时间维度
"时间维度"
主机维度
"主机维度"
日期维度
"日期维度"
应用组维度
"应用组维度"
↑ top
实体集:switch_performance_for_port_hourly_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
portTk [FK] →"端口尺寸".tk
Int32
是
端口的 TK。
switchTk [FK] →"切换维度".tk
Int32
是
交换机的 TK。
fabricTk [FK] →"fabric_dimension".tk
Int32
是
织物的 TK。
connectedDeviceTk [FK] →"已连接设备维度".tk
Int32
是
已连接设备的 TK。
connectivityType
字符串
是
已连接设备的类型。
isl
字符串
是
此端口是 ISL 端口吗?
rxTraffic
双线
是
接收流量(MB)
txTraffic
双线
是
正在传输流量(MB)
totalTraffic
双线
是
总流量(MB)
errorRateFlag
字符串
是
错误率标记
crcErrorRateFlag
字符串
是
CRC错误率标志
syncLossCount
Int64
是
同步丢失计数
signalLossCount
Int64
是
信号丢失计数
class3DiscardCount
Int64
是
Class 3 丢弃计数
frameTooShortCount
Int64
是
帧太短计数
frameTooLongCount
Int64
是
帧过长计数
bbCreditErrorCount
Int64
是
BB 信用错误计数
rx
双线
是
接收使用率(%)
tx
双线
是
传输使用率(%)
rxMax
双线
是
最大接收使用率(%)
txMax
双线
是
最大传输使用率(%)
双线
是
总流量使用率(%)
双线
是
最大总流量使用率(%)
rxLinkResets
Int64
是
接收链接重置
txLinkResets
Int64
是
传输链接重置
Int64
是
链路故障计数
bbCreditZeroRx
Int64
是
接收 BBCredit 零
bbCreditZeroTx
Int64
是
转移 BBCredit zero
bbCreditZeroMsTx
双线
是
bbCreditZeroTotal
Int64
是
总 BBCredit 为零
trafficRateTx
双线
是
传输流量速率
trafficRateRx
双线
是
接收流量速率
trafficRateTotal
双线
是
总流量率
trafficFrameRateTx
双线
是
传输流量帧速率
trafficFrameRateRx
双线
是
接收流量帧速率
双线
是
总流量帧速率
Int64
是
传输流量帧平均大小
Int64
是
接收流量帧平均大小
Int64
是
传输超时丢弃计数
portErrorsCrc
Int64
是
CRC错误计数
portErrorsEncIn
Int64
是
帧内编码错误
portErrorsEncOut
Int64
是
帧外的编码错误
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
已连接设备维度
"已连接设备维度"
一个 JOIN:connectedDeviceTk="已连接设备维度".tk
fabric_dimension
"fabric_dimension"
一个 JOIN:fabricTk="fabric_dimension".tk
端口尺寸
"端口尺寸"
一个 JOIN:portTk="端口尺寸".tk
时间维度
"时间维度"
日期维度
"日期维度"
切换维度
"切换维度"
一个 JOIN:switchTk="切换维度".tk
↑ top
实体集:switch_performance_for_storage_hourly_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
Int32
是
存储的 TK。
rxTraffic
双线
是
接收流量(MB)
txTraffic
双线
是
正在传输流量(MB)
totalTraffic
双线
是
总流量(MB)
errorRateFlag
字符串
是
错误率标记
crcErrorRateFlag
字符串
是
CRC错误率标志
syncLossCount
Int64
是
同步丢失计数
signalLossCount
Int64
是
信号丢失计数
class3DiscardCount
Int64
是
Class 3 丢弃计数
frameTooShortCount
Int64
是
帧太短计数
frameTooLongCount
Int64
是
帧过长计数
bbCreditErrorCount
Int64
是
BB 信用错误计数
rx
双线
是
接收使用率(%)
tx
双线
是
传输使用率(%)
rxMax
双线
是
最大接收使用率(%)
txMax
双线
是
最大传输使用率(%)
双线
是
总流量使用率(%)
双线
是
最大总流量使用率(%)
rxLinkResets
Int64
是
接收链接重置
txLinkResets
Int64
是
传输链接重置
balanceIndex
Int32
是
主机端口平衡索引
Int32
是
主机端口加权均衡索引
portSpeed
Int32
是
FACT 的端口速度
portCount
Int32
是
事实的端口计数
Int64
是
链路故障计数
bbCreditZeroRx
Int64
是
接收 BBCredit 零
bbCreditZeroTx
Int64
是
转移 BBCredit zero
bbCreditZeroMsTx
双线
是
bbCreditZeroTotal
Int64
是
总 BBCredit 为零
trafficRateTx
双线
是
传输流量速率
trafficRateRx
双线
是
接收流量速率
trafficRateTotal
双线
是
总流量率
trafficFrameRateTx
双线
是
传输流量帧速率
trafficFrameRateRx
双线
是
接收流量帧速率
双线
是
总流量帧速率
Int64
是
传输流量帧平均大小
Int64
是
接收流量帧平均大小
Int64
是
传输超时丢弃计数
portErrorsCrc
Int64
是
CRC错误计数
portErrorsEncIn
Int64
是
帧内编码错误
portErrorsEncOut
Int64
是
帧外的编码错误
导航属性(联接)
导航属性 相关实体 基数/联接
存储维度
"存储维度"
时间维度
"时间维度"
日期维度
"日期维度"
↑ top
实体集:switch_performance_for_tape_hourly_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
tapeTk [FK] →"tape_dimension".tk
Int32
是
磁带的 TK。
rxTraffic
双线
是
接收流量(MB)
txTraffic
双线
是
正在传输流量(MB)
totalTraffic
双线
是
总流量(MB)
errorRateFlag
字符串
是
错误率标记
crcErrorRateFlag
字符串
是
CRC错误率标志
syncLossCount
Int64
是
同步丢失计数
signalLossCount
Int64
是
信号丢失计数
class3DiscardCount
Int64
是
Class 3 丢弃计数
frameTooShortCount
Int64
是
帧太短计数
frameTooLongCount
Int64
是
帧过长计数
bbCreditErrorCount
Int64
是
BB 信用错误计数
rx
双线
是
接收使用率(%)
tx
双线
是
传输使用率(%)
rxMax
双线
是
最大接收使用率(%)
txMax
双线
是
最大传输使用率(%)
双线
是
总流量使用率(%)
双线
是
最大总流量使用率(%)
rxLinkResets
Int64
是
接收链接重置
txLinkResets
Int64
是
传输链接重置
balanceIndex
Int32
是
主机端口平衡索引
Int32
是
主机端口加权均衡索引
portSpeed
Int32
是
FACT 的端口速度
portCount
Int32
是
事实的端口计数
Int64
是
链路故障计数
bbCreditZeroRx
Int64
是
接收 BBCredit 零
bbCreditZeroTx
Int64
是
转移 BBCredit zero
bbCreditZeroMsTx
双线
是
bbCreditZeroTotal
Int64
是
总 BBCredit 为零
trafficRateTx
双线
是
传输流量速率
trafficRateRx
双线
是
接收流量速率
trafficRateTotal
双线
是
总流量率
trafficFrameRateTx
双线
是
传输流量帧速率
trafficFrameRateRx
双线
是
接收流量帧速率
双线
是
总流量帧速率
Int64
是
传输流量帧平均大小
Int64
是
接收流量帧平均大小
Int64
是
传输超时丢弃计数
portErrorsCrc
Int64
是
CRC错误计数
portErrorsEncIn
Int64
是
帧内编码错误
portErrorsEncOut
Int64
是
帧外的编码错误
导航属性(联接)
导航属性 相关实体 基数/联接
时间维度
"时间维度"
日期维度
"日期维度"
tape_dimension
"tape_dimension"
一个 JOIN:tapeTk="tape_dimension".tk
tape_dimension
↑ top
实体集:tape_dimension
字段 类型 可为Null 注释
tk
Int32
是
此磁带行的 TK。
name
字符串
是
磁带的名称。
标识符
字符串
是
设备的标识符。
IP
字符串
是
磁带的 IP 地址。
制造商
字符串
是
磁带制造商。
serialNumber
字符串
是
磁带的序列号。
ID
Int64
是
dwh_inventory.tape 中磁带的 GUID。
最新
字符串
是
指示此行是否是此磁带的最新行。
dateTk
Int32
是
此磁带行创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
层级维度
↑ top
实体集:tier_dimension
字段 类型 可为Null 注释
tk
Int32
是
此层行的 TK。
name
字符串
是
层级的标识名称。
序列
Int32
是
dwh_inventory.annotation_value 中定义的层序号。
成本
双线
是
与此层关联的费用。
ID
Int64
是
dwh_inventory.annotation_value 中层的 GUID。
最新
字符串
是
指示此行是否为此层级的最新行。
dateTk
Int32
是
此会员等级行创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
时间维度
↑ top
实体集:time_dimension
字段 类型 可为Null 注释
tk [PK]
Int32
是
时间维度的 TK。
hourDateTime
DateTimeOffset
是
此维度的完整日期+小时表示形式(分钟和秒归零)
小时
字节
是
一天中的小时,24小时格式
分钟
字节
是
分钟(以小时为单位)
秒
字节
是
秒(分钟)
微秒
Int32
是
秒为单位的微秒
Int32
是
相关日期维度日代表的 TK(如果有)
导航属性(联接)
导航属性 相关实体 基数/联接
日期维度
"日期维度"
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
许多
↑ top
实体集:vm_daily_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int32
是
事实的 TK。
Int32
是
日期维度的 TK。
Int32
是
主机的 TK。
vmTk [FK] →"vm_dimension".tk
Int32
是
VM 的 TK。
Int32
是
商业实体的 TK。
Int32
是
应用程序代表的 TK。
Int32
是
应用程序组的 TK。
k8sNodeTk [FK] →"k8s_node_dimension".tk
Int32
是
K8s 节点的 TK。
readIops
双线
是
每秒读取 IO。
writeIops
双线
是
每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间。
totalResponseTime
双线
是
总响应时间。
双线
是
总最大响应时间。
ipReceiveThroughput
双线
是
IP 接收吞吐量。
双线
是
IP 传输吞吐量。
ipTotalThroughput
双线
是
IP 总吞吐量。
双线
是
最大IP总吞吐量。
cpuUtilization
双线
是
CPU利用率(%)
双线
是
[已弃用] 最大 CPU 利用率 (%)
maxOfMaxCpuUtilization
双线
是
最大CPU利用率(%)
memoryUtilization
双线
是
内存利用率(%)
双线
是
[已弃用] 最大内存利用率 (%)
maxOfMaxMemoryUtilization
双线
是
最大内存利用率(%)
swapInRate
双线
是
互换利率
maxOfAvgSwapInRate
双线
是
最大换入速率
swapOutRate
双线
是
换出率
maxOfAvgSwapOutRate
双线
是
最大换出速率
swapTotalRate
双线
是
总交换率
swapTotalRateMax
双线
是
最大总交换速率
处理器
Int32
是
虚拟机的处理器数。
memory
Int64
是
虚拟机的内存,以 MB 为单位。
cpuCoSchedulingDelayTimePercent
双线
是
CPU Co-Stop 时间 (%)
cpuDemandToEntitlementPercent
双线
是
CPU 需求与权利比率(%)
cpuIdleTimePercent
双线
是
CPU 空闲时间 (%)
waitingToBeScheduledTimePercent
双线
是
CPU 就绪时间 (%)
cpuTotalWaitTimePercent
双线
是
CPU 等待时间(%)
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
业务实体维度
"业务实体维度"
k8s_node_dimension
one JOIN:k8sNodeTk="k8s_node_dimension".tk
应用维度
"应用维度"
主机维度
"主机维度"
vm_dimension
"vm_dimension"
一个 JOIN:vmTk="vm_dimension".tk
日期维度
"日期维度"
应用组维度
"应用组维度"
vm_dimension
↑ top
实体集:vm_dimension
字段 类型 可为Null 注释
tk
Int32
是
此虚拟机行的 TK。
name
字符串
是
虚拟机的名称。
naturalKey
字符串
是
虚拟机的自然标识符。
操作系统
字符串
是
来宾操作系统。
virtualCenterIp
字符串
是
虚拟机的虚拟中心的 IP 地址。
ips
字符串
是
以逗号分隔的虚拟机 IP 地址列表。
url
字符串
是
Insight Server 中此虚拟机的 URL。
ID
Int64
是
dwh_inventory.hv_virtual_machine 中虚拟机的 GUID
最新
字符串
是
指示此行是否是此虚拟机的最新行。
dateTk
Int32
是
此虚拟机行的创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
许多
许多
↑ top
实体集:vm_hourly_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
Int32
是
主机的 TK。
Int32
是
VM 的 TK。
Int32
是
商业实体的 TK。
Int32
是
应用程序代表的 TK。
Int32
是
应用程序组的 TK。
Int32
是
K8s 节点的 TK。
readIops
双线
是
每秒读取 IO。
writeIops
双线
是
每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间。
totalResponseTime
双线
是
总响应时间。
双线
是
总最大响应时间。
ipReceiveThroughput
双线
是
IP 接收吞吐量。
双线
是
IP 传输吞吐量。
ipTotalThroughput
双线
是
IP 总吞吐量。
双线
是
最大IP总吞吐量。
cpuUtilization
双线
是
CPU利用率(%)
memoryUtilization
双线
是
内存利用率(%)
cpuUtilizationMax
双线
是
最大CPU利用率(%)
memoryUtilizationMax
双线
是
最大内存利用率(%)
swapInRate
双线
是
互换利率
swapOutRate
双线
是
换出率
swapTotalRate
双线
是
总交换率
swapTotalRateMax
双线
是
最大总交换速率
处理器
Int32
是
虚拟机的处理器数。
memory
Int64
是
虚拟机的内存,以 MB 为单位。
双线
是
CPU Co-Stop 时间 (%)
双线
是
CPU 需求与权利比率(%)
cpuIdleTimePercent
双线
是
CPU 空闲时间 (%)
双线
是
CPU 就绪时间 (%)
双线
是
CPU 等待时间(%)
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
业务实体维度
"业务实体维度"
k8s_node_dimension
应用维度
"应用维度"
时间维度
"时间维度"
主机维度
"主机维度"
vm_dimension
"vm_dimension"
日期维度
"日期维度"
应用组维度
"应用组维度"
↑ top
实体集:vmdk_daily_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int32
是
事实的 TK。
Int32
是
日期维度的 TK。
vmdkTk [FK] →"vmdk_dimension".tk
Int32
是
虚拟磁盘的 TK。
dataStoreTk [FK] →"数据存储_维度".tk
Int32
是
数据存储库的 TK。
Int32
是
VM 的 TK。
Int32
是
主机的 TK。
Int32
是
层的 TK。
Int32
是
服务级别的 TK。
Int32
是
存储的 TK。
readIops
双线
是
每秒读取 IO。
writeIops
双线
是
每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间。
totalResponseTime
双线
是
总响应时间。
双线
是
总最大响应时间。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
服务级别维度
"服务级别维度"
存储维度
"存储维度"
层级维度
"层级维度"
数据存储_维度
"数据存储_维度"
一个 JOIN:dataStoreTk="数据存储_维度".tk
主机维度
"主机维度"
vm_dimension
"vm_dimension"
vmdk_dimension
"vmdk_dimension"
一个 JOIN:vmdkTk="vmdk_dimension".tk
日期维度
"日期维度"
vmdk_dimension
↑ top
实体集:vmdk_dimension
字段 类型 可为Null 注释
tk
Int32
是
此虚拟磁盘行的 TK。
naturalKey
字符串
是
虚拟磁盘的 OID。
name
字符串
是
虚拟磁盘的名称。
type
字符串
是
虚拟磁盘的类型。
url
字符串
是
Insight Server 中此虚拟磁盘的 URL。
ID
Int64
是
dwh_inventory.hv_virtual_disk 中虚拟磁盘的 GUID
最新
字符串
是
指示此行是否为此虚拟磁盘的最新行。
dateTk
Int32
是
此虚拟磁盘行的创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
↑ top
实体集:vmdk_hourly_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
Int32
是
虚拟磁盘的 TK。
Int32
是
数据存储库的 TK。
Int32
是
VM 的 TK。
Int32
是
主机的 TK。
Int32
是
层的 TK。
Int32
是
服务级别的 TK。
Int32
是
存储的 TK。
readIops
双线
是
每秒读取 IO。
writeIops
双线
是
每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间。
totalResponseTime
双线
是
总响应时间。
双线
是
总最大响应时间。
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
服务级别维度
"服务级别维度"
存储维度
"存储维度"
层级维度
"层级维度"
时间维度
"时间维度"
数据存储_维度
"数据存储_维度"
主机维度
"主机维度"
vm_dimension
"vm_dimension"
vmdk_dimension
"vmdk_dimension"
日期维度
"日期维度"
vmware_host_daily_metrics_fact
↑ top
实体集:vmware_host_daily_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
dateTk
Int32
是
日期维度的 TK。
vmwareHostTk
Int32
是
vmware 主机维度的 TK。
powerAvg
双线
是
平均功率
powerCapAvg
双线
是
功率上限平均值
energyAvg
双线
是
能量总和
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
vmware_host_dimension
↑ top
实体集:vmware_host_dimension
字段 类型 可为Null 注释
tk
Int32
是
此 VMware 主机行的 TK。
标识符
字符串
是
VMware 主机的唯一标识符。
name
字符串
是
VMware 主机名
numCpuCores
Int64
是
VMware 主机的 CPU 核心数
numCpuPackages
Int64
是
VMware 主机的 CPU 封装数量
numCpuThreads
Int64
是
VMware 主机的 CPU 线程数
numNodes
Int64
是
VMware 主机的节点数
hyperThreadActive
字符串
是
指示是否在 VMware 主机上启用超线程
hyperThreadAvailable
字符串
是
指示在 VMware 主机上是否可以使用超线程
hyperThreadConfig
字符串
是
指示是否将超线程配置为在 VMware 主机上启用
ID
Int64
是
dwh_inventory.vmware_host 中主机的 GUID
最新
字符串
是
指示此行是否是此 VMware 主机的最新行。
dateTk
Int32
是
此 VMware 主机行创建日期的 TK。
vmware_host_hourly_metrics_fact
↑ top
实体集:vmware_host_hourly_metrics_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
timeTk
Int32
是
时间维度的 TK。
dateTk
Int32
是
日期维度的 TK。
vmwareHostTk
Int32
是
vmware 主机维度的 TK。
powerAvg
双线
是
平均功率
powerCapAvg
双线
是
功率上限平均值
energyAvg
双线
是
能量总和
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
↑ top
实体集:volume_daily_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int32
是
事实的 TK。
Int32
是
日期维度的 TK。
volumeTk [FK] →"体积尺寸".tk
Int32
是
性能编号的卷的 TK。
Int32
是
性能编号存储的 TK。
virtualStorageTk
Int32
是
Int32
是
存储节点的 TK。
Int32
是
性能编号存储池的 TK。
Int32
是
应用程序代表的 TK。
Int32
是
应用程序组的 TK。
Int32
是
房东代表的 TK。
Int32
是
主机组的 TK。
Int32
是
层的 TK。
Int32
是
服务级别的 TK。
Int32
是
商业实体的 TK。
Int32
是
k8s 命名空间的 TK。
Int32
是
k8s 命名空间组的 TK。
readResponseTime
双线
是
读取平均响应时间。
writeResponseTime
双线
是
写入平均响应时间。
totalResponseTime
双线
是
平均响应时间的最大值。
双线
是
响应时间的最大值。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readIops
双线
是
平均每秒读取 io。
writeIops
双线
是
平均每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
readCacheHitRatio
双线
是
读缓存命中率。
writeCacheHitRatio
双线
是
写入缓存命中率。
totalCacheHitRatio
双线
是
总缓存命中率。
双线
是
最大总缓存命中率。
writePending
Int64
是
一天的最大挂起写入次数。
readIoDensity
双线
是
读取 io 密度。
writeIoDensity
双线
是
写入 IO 密度。
totalIoDensity
双线
是
总 IO 密度。
totalIoDensityMax
双线
是
最大总 IO 密度。
双线
是
压缩节省量 (%)。
双线
是
压缩节省空间。
totalTimeToFull
双线
是
充满时间。
双线
是
Time to Full 的置信区间。
已访问
Int32
是
是否已访问卷?
前端
字符串
是
是卷前端吗?
后端
字符串
是
是卷后端吗?
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
存储节点尺寸
"存储节点尺寸"
存储维度
"存储维度"
业务实体维度
"业务实体维度"
主机组维度
"主机组维度"
应用组维度
"应用组维度"
服务级别维度
"服务级别维度"
层级维度
"层级维度"
应用维度
"应用维度"
存储池维度
"存储池维度"
主机维度
"主机维度"
日期维度
"日期维度"
体积尺寸
"体积尺寸"
一个 JOIN:volumeTk="体积尺寸".tk
体积尺寸
↑ top
实体集:volume_dimension
字段 类型 可为Null 注释
tk
Int32
是
此卷行的 TK。
storageIdentifier
字符串
是
卷存储的标识符。
name
字符串
是
卷的名称。
标签
字符串
是
卷的标签。
thinProvisioned
字符串
是
卷是否已精简配置?
type
字符串
是
卷的类型。
isVirtual
字符串
是
卷是虚拟卷吗?
meta
字符串
是
卷是元卷吗?
Snapshot
字符串
是
指示此卷是否为快照卷。
technologyType
字符串
是
uuid
字符串
是
卷的 UUID。
isMainframe
字符串
是
是大型机卷吗?
url
字符串
是
Insight Server 中此卷的 URL。
ID
Int64
是
卷在 dwh_inventory.volume 中的 GUID
最新
字符串
是
指示此行是否是此卷的最新行。
dateTk
Int32
是
此卷行的创建日期的 TK。
导航属性(联接)
导航属性 相关实体 基数/联接
许多
许多
↑ top
实体集:volume_hourly_performance_fact
字段 类型 可为Null 注释
tk [PK]
Int64
是
事实的 TK。
Int32
是
时间维度的 TK。
Int32
是
日期维度的 TK。
Int32
是
性能编号的卷的 TK。
Int32
是
性能编号存储的 TK。
virtualStorageTk
Int32
是
Int32
是
存储节点的 TK。
Int32
是
性能编号存储池的 TK。
Int32
是
应用程序代表的 TK。
Int32
是
应用程序组的 TK。
Int32
是
房东代表的 TK。
Int32
是
主机组的 TK。
Int32
是
层的 TK。
Int32
是
服务级别的 TK。
Int32
是
商业实体的 TK。
Int32
是
k8s 命名空间的 TK。
Int32
是
k8s 命名空间组的 TK。
readResponseTime
双线
是
读取响应时间。
writeResponseTime
双线
是
写入响应时间
totalResponseTime
双线
是
总响应时间。
双线
是
响应时间的最大值。
readThroughput
双线
是
读取吞吐量平均值。
writeThroughput
双线
是
写入平均吞吐量。
totalThroughput
双线
是
总吞吐量平均值(读+写)。
totalThroughputMax
双线
是
最大总吞吐量。
readIops
双线
是
平均每秒读取 io。
writeIops
双线
是
平均每秒写入 io。
totalIops
双线
是
平均每秒总 IO 数(读+写)。
totalIopsMax
双线
是
最大 IO/秒。
readCacheHitRatio
双线
是
读缓存命中率。
writeCacheHitRatio
双线
是
写入缓存命中率。
totalCacheHitRatio
双线
是
总缓存命中率。
双线
是
最大总缓存命中率。
writePending
Int64
是
挂起的写入次数。
readIoDensity
双线
是
读取 io 密度。
writeIoDensity
双线
是
写入 IO 密度。
totalIoDensity
双线
是
总 IO 密度。
totalIoDensityMax
双线
是
最大总 IO 密度。
双线
是
压缩节省量 (%)。
双线
是
压缩节省空间。
totalTimeToFull
双线
是
充满时间。
双线
是
Time to Full 的置信区间。
已访问
Int32
是
是否已访问卷?
前端
字符串
是
是卷前端吗?
后端
字符串
是
是卷后端吗?
时间戳 [PK]
Int64
是
事实开始时间戳,用于分区
导航属性(联接)
导航属性 相关实体 基数/联接
存储节点尺寸
"存储节点尺寸"
存储维度
"存储维度"
业务实体维度
"业务实体维度"
主机组维度
"主机组维度"
应用组维度
"应用组维度"
服务级别维度
"服务级别维度"
层级维度
"层级维度"
应用维度
"应用维度"
时间维度
"时间维度"
存储池维度
"存储池维度"
主机维度
"主机维度"
日期维度
"日期维度"
体积尺寸
"体积尺寸"
