SANtricity commands
测试外部密钥管理通信 - SANtricity CLI
贡献者 netapp-driley
`sStart storageArray externalKeyManagement test`命令可使用已配置的凭据(证书、KMIP服务器的地址和KMIP端口号)来验证存储阵列是否能够与外部KMIP服务器进行通信。
支持的阵列
此命令适用于单个 E4000、E2800、E5700、EF600、EF300、EF50 和 EF80 存储阵列。不适用于 E2700 或 E5600 存储阵列。
角色
要在 E4000、E2800、E5700、EF600、EF300、EF50 或 EF80 存储阵列上执行此命令,必须具有 Security Admin 角色。
环境
备注
此命令仅适用于外部密钥管理。
语法
start storageArray externalKeyManagement test
无
注释:
当存储阵列能够与外部密钥管理服务器通信时,以下示例显示了命令的输出。输出包括密钥管理服务器、客户端证书和服务器证书的状态。
Key servers configured:
C:\Users\Administrator\Downloads\SMcli (1)\SMcli-02.00.00.0011\bin>SMcli.bat 10.115.XX.XXX -u admin -p infiniti -k -c "start storageArray externalKeyManagement test;"
Performing syntax check...
Syntax check complete.
Executing script...
SUMMARY:
   Key management server:
      Server address: ::
      Server port: 9003
      Local controller status: Connection failure
      Alternate controller status: Unknown
      Client certificate status: Ok
      Server certificate status: Ok
DETAILS:
Unable to communicate with the key management server. To correct the problem, perform the
following steps: 1) Check that the key management server address and port is correct. 2) If
the key management server's address is a domain name, check that both controller's DNS
servers are operational and reachable from the controller given your network configuration.
3) Check that the key management server operational and reachable from the controller given
your network configuration. 4) Once the problem has been found and corrected, re-perform the
communication test between the storage array and key management server to clear the needs
attention state on the array.
Script execution complete.
SMcli completed successfully.
No key servers configured:
Executing script...
No key management servers configured.
最低固件级别
8.40
