解决方案验证概述
贡献者
在本节中、我们从多个源执行了SQL测试查询、以验证功能、测试并验证是否溢出到NetApp存储。
对象存储上的SQL查询
在dremio.env中将每个服务器的内存设置为250 GB
root@hadoopmaster:~# for i in hadoopmaster hadoopnode1 hadoopnode2 hadoopnode3 hadoopnode4; do ssh $i "hostname; grep -i DREMIO_MAX_MEMORY_SIZE_MB /opt/dremio/conf/dremio-env; cat /proc/meminfo | grep -i memtotal"; done hadoopmaster #DREMIO_MAX_MEMORY_SIZE_MB=120000 DREMIO_MAX_MEMORY_SIZE_MB=250000 MemTotal: 263515760 kB hadoopnode1 #DREMIO_MAX_MEMORY_SIZE_MB=120000 DREMIO_MAX_MEMORY_SIZE_MB=250000 MemTotal: 263515860 kB hadoopnode2 #DREMIO_MAX_MEMORY_SIZE_MB=120000 DREMIO_MAX_MEMORY_SIZE_MB=250000 MemTotal: 263515864 kB hadoopnode3 #DREMIO_MAX_MEMORY_SIZE_MB=120000 DREMIO_MAX_MEMORY_SIZE_MB=250000 MemTotal: 264004556 kB node4 #DREMIO_MAX_MEMORY_SIZE_MB=120000 DREMIO_MAX_MEMORY_SIZE_MB=250000 MemTotal: 263515484 kB root@hadoopmaster:~#
检查dremio.conf文件和存储详细信息中的溢出位置(${DREMIO_HOME}"/dremiocache)。
paths: { # the local path for dremio to store data. local: ${DREMIO_HOME}"/dremiocache" # the distributed path Dremio data including job results, downloads, uploads, etc #dist: "hdfs://hadoopmaster:9000/dremiocache" dist: "dremioS3:///dremioconf" } services: { coordinator.enabled: true, coordinator.master.enabled: true, executor.enabled: false, flight.use_session_service: false } zookeeper: "10.63.150.130:2181,10.63.150.153:2181,10.63.150.151:2181" services.coordinator.master.embedded-zookeeper.enabled: false
将d不良 位置指向NetApp NFS存储
root@hadoopnode1:~# ls -ltrh /dremiocache total 4.0K drwx------ 3 nobody nogroup 4.0K Sep 13 16:00 spilling_stlrx2540m4-12-10g_45678 root@hadoopnode1:~# ls -ltrh /opt/dremio/dremiocache/ total 8.0K drwxr-xr-x 3 dremio dremio 4.0K Aug 22 18:19 spill_old drwxr-xr-x 4 dremio dremio 4.0K Aug 22 18:19 cm lrwxrwxrwx 1 root root 12 Aug 22 19:03 spill -> /dremiocache root@hadoopnode1:~# ls -ltrh /dremiocache total 4.0K drwx------ 3 nobody nogroup 4.0K Sep 13 16:00 spilling_stlrx2540m4-12-10g_45678 root@hadoopnode1:~# df -h /dremiocache Filesystem Size Used Avail Use% Mounted on 10.63.150.159:/dremiocache_hadoopnode1 2.1T 209M 2.0T 1% /dremiocache root@hadoopnode1:~#
选择上下文。在我们的测试中、我们会对驻留在ONTAP S3中的TPCDS生成的镶木地板文件运行测试。D不良 信息板→ SQL运行程序→上下文→ NetApp ONTAPS3→Parquet1TB
从D雷 米奥信息板运行TPC-DS quory67
检查作业是否正在所有执行器上运行。d不良 信息板→作业→<jobid>→原始配置文件→选择外部排序→主机名
运行SQL查询时、您可以检查拆分文件夹中的NetApp存储控制器中是否存在数据缓存。
root@hadoopnode1:~# ls -ltrh /dremiocache total 4.0K drwx------ 3 nobody nogroup 4.0K Sep 13 16:00 spilling_stlrx2540m4-12-10g_45678 root@hadoopnode1:~# ls -ltrh /dremiocache/spilling_stlrx2540m4-12-10g_45678/ total 4.0K drwxr-xr-x 2 root daemon 4.0K Sep 13 16:23 1726243167416
SQL查询已完成、但溢出
作业完成摘要。
检查溢出的数据大小
适用于NAS和StorageGRID对象存储的过程相同。
