准备从Nexus 5596交换机迁移到Nexus 3132Q-V交换机
请按照以下步骤准备Cisco Nexus 5596交换机、以便迁移到Cisco Nexus 3132Q-V交换机。
如果在此集群上启用了 AutoSupport ,请通过调用 AutoSupport 消息来禁止自动创建案例:
ssystem node AutoSupport invoke -node * -type all -message MAINT=xhx 是维护时段的持续时间,以小时为单位。
此消息会通知技术支持此维护任务,以便在维护窗口期间禁止自动创建案例。 -
显示有关配置中设备的信息:
network device-discovery show显示示例
以下示例显示了在每个节点中为每个集群互连交换机配置了多少个集群互连接口:
cluster::> network device-discovery show Local Discovered Node Port Device Interface Platform ----------- ------ ------------------- ---------------- ---------------- n1 /cdp e0a CL1 Ethernet1/1 N5K-C5596UP e0b CL2 Ethernet1/1 N5K-C5596UP e0c CL2 Ethernet1/2 N5K-C5596UP e0d CL1 Ethernet1/2 N5K-C5596UP n2 /cdp e0a CL1 Ethernet1/3 N5K-C5596UP e0b CL2 Ethernet1/3 N5K-C5596UP e0c CL2 Ethernet1/4 N5K-C5596UP e0d CL1 Ethernet1/4 N5K-C5596UP 8 entries were displayed. -
确定每个集群接口的管理或运行状态:
显示网络端口属性:
network port show
显示示例
以下示例显示了系统上的网络端口属性:
cluster::*> network port show –role cluster (network port show) Node: n1 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 - - e0b Cluster Cluster up 9000 auto/10000 - - e0c Cluster Cluster up 9000 auto/10000 - - e0d Cluster Cluster up 9000 auto/10000 - - Node: n2 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 - - e0b Cluster Cluster up 9000 auto/10000 - - e0c Cluster Cluster up 9000 auto/10000 - - e0d Cluster Cluster up 9000 auto/10000 - - 8 entries were displayed.-
显示有关逻辑接口的信息: +
network interface show显示示例
以下示例显示了有关系统上所有 LIF 的常规信息:
cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e0a true n1_clus2 up/up 10.10.0.2/24 n1 e0b true n1_clus3 up/up 10.10.0.3/24 n1 e0c true n1_clus4 up/up 10.10.0.4/24 n1 e0d true n2_clus1 up/up 10.10.0.5/24 n2 e0a true n2_clus2 up/up 10.10.0.6/24 n2 e0b true n2_clus3 up/up 10.10.0.7/24 n2 e0c true n2_clus4 up/up 10.10.0.8/24 n2 e0d true 8 entries were displayed. -
显示有关已发现集群交换机的信息: +
ssystem cluster-switch show显示示例
以下示例显示了集群已知的集群交换机及其管理 IP 地址:
cluster::*> system cluster-switch show Switch Type Address Model ----------------------------- ------------------ --------------- --------------- CL1 cluster-network 10.10.1.101 NX5596 Serial Number: 01234567 Is Monitored: true Reason: Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 7.1(1)N1(1) Version Source: CDP CL2 cluster-network 10.10.1.102 NX5596 Serial Number: 01234568 Is Monitored: true Reason: Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 7.1(1)N1(1) Version Source: CDP 2 entries were displayed.
在两个节点上的集群 LIF clus1 和 clus2 上将 ` -auto-revert` 参数设置为
false:network interface modify显示示例
cluster::*> network interface modify -vserver node1 -lif clus1 -auto-revert false cluster::*> network interface modify -vserver node1 -lif clus2 -auto-revert false cluster::*> network interface modify -vserver node2 -lif clus1 -auto-revert false cluster::*> network interface modify -vserver node2 -lif clus2 -auto-revert false
根据您的需求,验证是否在新的 3132Q-V 交换机上安装了适当的 RCF 和映像,并进行必要的站点自定义,例如用户和密码,网络地址等。
此时必须准备两个交换机。如果需要升级 RCF 和映像,请按照以下步骤操作:
前往"Cisco 以太网交换机"在NetApp支持站点上。
请记下该页面上的表中的交换机和所需的软件版本。
下载适当版本的 RCF 。
在*Description*页上选择*CONTINUOD*,接受许可协议,然后按照*Download*页上的说明下载RCB。
下载相应版本的映像软件。
请参见Cluster and Management ONTAP交换机参考配置文件Download页面,然后选择相应的版本。
要查找正确的版本,请参见 _Cluster ONTAP 8.x 或更高版本的集群网络交换机下载页面 _ 。
迁移与要更换的第二个 Nexus 5596 交换机关联的 LIF :
网络接口迁移显示示例
以下示例显示了 n1 和 n2 ,但必须在所有节点上执行 LIF 迁移:
cluster::*> network interface migrate -vserver Cluster -lif n1_clus2 -source-node n1 - destination-node n1 -destination-port e0a cluster::*> network interface migrate -vserver Cluster -lif n1_clus3 -source-node n1 - destination-node n1 -destination-port e0d cluster::*> network interface migrate -vserver Cluster -lif n2_clus2 -source-node n2 - destination-node n2 -destination-port e0a cluster::*> network interface migrate -vserver Cluster -lif n2_clus3 -source-node n2 - destination-node n2 -destination-port e0d
验证集群的运行状况:
以下示例显示了上一个
network interface migrate命令的结果:cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e0a true n1_clus2 up/up 10.10.0.2/24 n1 e0a false n1_clus3 up/up 10.10.0.3/24 n1 e0d false n1_clus4 up/up 10.10.0.4/24 n1 e0d true n2_clus1 up/up 10.10.0.5/24 n2 e0a true n2_clus2 up/up 10.10.0.6/24 n2 e0a false n2_clus3 up/up 10.10.0.7/24 n2 e0d false n2_clus4 up/up 10.10.0.8/24 n2 e0d true 8 entries were displayed. -
关闭物理连接到交换机 CL2 的集群互连端口:
network port modify显示示例
以下命令会关闭 n1 和 n2 上的指定端口,但必须关闭所有节点上的端口:
cluster::*> network port modify -node n1 -port e0b -up-admin false cluster::*> network port modify -node n1 -port e0c -up-admin false cluster::*> network port modify -node n2 -port e0b -up-admin false cluster::*> network port modify -node n2 -port e0c -up-admin false
验证远程集群接口的连接:
您可以使用 network interface check cluster-connectivity 命令启动集群连接的可访问性检查、然后显示详细信息:
network interface check cluster-connectivity start 和 network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
*注:*请等待几秒钟、然后再运行show命令显示详细信息。
cluster1::*> network interface check cluster-connectivity show
Source Destination Packet
Node Date LIF LIF Loss
n1
3/5/2022 19:21:18 -06:00 n1_clus2 n2_clus1 none
3/5/2022 19:21:20 -06:00 n1_clus2 n2_clus2 none
n2
3/5/2022 19:21:18 -06:00 n2_clus2 n1_clus1 none
3/5/2022 19:21:20 -06:00 n2_clus2 n1_clus2 none
对于所有ONTAP版本、您还可以使用 cluster ping-cluster -node <name> 用于检查连接的命令:
cluster::*> cluster ping-cluster -node n1
Host is n1
Getting addresses from network interface table...
Cluster n1_clus1 n1 e0a 10.10.0.1
Cluster n1_clus2 n1 e0b 10.10.0.2
Cluster n1_clus3 n1 e0c 10.10.0.3
Cluster n1_clus4 n1 e0d 10.10.0.4
Cluster n2_clus1 n2 e0a 10.10.0.5
Cluster n2_clus2 n2 e0b 10.10.0.6
Cluster n2_clus3 n2 e0c 10.10.0.7
Cluster n2_clus4 n2 e0d 10.10.0.8
Local = 10.10.0.1 10.10.0.2 10.10.0.3 10.10.0.4
Remote = 10.10.0.5 10.10.0.6 10.10.0.7 10.10.0.8
Cluster Vserver Id = 4294967293
Ping status:....
Basic connectivity succeeds on 16 path(s)
Basic connectivity fails on 0 path(s)
Detected 1500 byte MTU on 16 path(s):
Local 10.10.0.1 to Remote 10.10.0.5
Local 10.10.0.1 to Remote 10.10.0.6
Local 10.10.0.1 to Remote 10.10.0.7
Local 10.10.0.1 to Remote 10.10.0.8
Local 10.10.0.2 to Remote 10.10.0.5
Local 10.10.0.2 to Remote 10.10.0.6
Local 10.10.0.2 to Remote 10.10.0.7
Local 10.10.0.2 to Remote 10.10.0.8
Local 10.10.0.3 to Remote 10.10.0.5
Local 10.10.0.3 to Remote 10.10.0.6
Local 10.10.0.3 to Remote 10.10.0.7
Local 10.10.0.3 to Remote 10.10.0.8
Local 10.10.0.4 to Remote 10.10.0.5
Local 10.10.0.4 to Remote 10.10.0.6
Local 10.10.0.4 to Remote 10.10.0.7
Local 10.10.0.4 to Remote 10.10.0.8
Larger than PMTU communication succeeds on 16 path(s)
RPC status:
4 paths up, 0 paths down (tcp check)
4 paths up, 0 paths down (udp check)
关闭活动Nexus 5596交换机CL1上的ISL端口41到48:
显示示例
以下示例显示了如何关闭 Nexus 5596 交换机 CL1 上的 ISL 端口 41 到 48 :
(CL1)# configure (CL1)(Config)# interface e1/41-48 (CL1)(config-if-range)# shutdown (CL1)(config-if-range)# exit (CL1)(Config)# exit (CL1)#
如果要更换Nexus 5010或5020、请为ISL指定适当的端口号。
在 CL1 和 C2 之间构建临时 ISL 。
显示示例
以下示例显示了在 CL1 和 C2 之间设置的临时 ISL :
C2# configure C2(config)# interface port-channel 2 C2(config-if)# switchport mode trunk C2(config-if)# spanning-tree port type network C2(config-if)# mtu 9216 C2(config-if)# interface breakout module 1 port 24 map 10g-4x C2(config)# interface e1/24/1-4 C2(config-if-range)# switchport mode trunk C2(config-if-range)# mtu 9216 C2(config-if-range)# channel-group 2 mode active C2(config-if-range)# exit C2(config-if)# exit
"配置端口"(英文)
