完成到 Cisco Nexus 3132Q-V 集群交换机的迁移
贡献者 netapp-yvonneo netapp-jsnyder
完成最后步骤,使用 Cisco Nexus 3132Q-V 集群交换机从双节点无交换机集群迁移到双节点交换机集群。
步骤
  1. 显示每个节点上每个集群端口连接的集群交换机端口号:
    network device-discovery show
    显示示例
    	cluster::*> network device-discovery show
                Local  Discovered
    Node        Port   Device              Interface        Platform
    n1         /cdp
                e4a    C1                  Ethernet1/7      N3K-C3132Q-V
                e4e    C2                  Ethernet1/7      N3K-C3132Q-V
    n2         /cdp
                e4a    C1                  Ethernet1/8      N3K-C3132Q-V
                e4e    C2                  Ethernet1/8      N3K-C3132Q-V
  2. 显示发现和监控的集群交换机:
    system cluster-switch show
    显示示例
    cluster::*> system cluster-switch show
    Switch                      Type               Address          Model
    C1                          cluster-network    10.10.1.101      NX3132V
         Serial Number: FOX000001
          Is Monitored: true
                Reason:
      Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                        7.0(3)I4(1)
        Version Source: CDP
    C2                          cluster-network      10.10.1.102    NX3132V
         Serial Number: FOX000002
          Is Monitored: true
                Reason:
                        7.0(3)I4(1)
        Version Source: CDP
    2 entries were displayed.
  3. 禁用任何节点上的双节点无开关配置设置:
    network options switchless-cluster
    network options switchless-cluster modify -enabled false
  4. 验证该 `switchless-cluster`选项是否已禁用。
    network options switchless-cluster show
  5. 验证远程集群接口的连接性:
ONTAP 9.9.1 及更高版本
你可以使用 `network interface check cluster-connectivity`执行命令以启动集群连接性检查,然后显示详细信息:
network interface check cluster-connectivity start`和 `network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
注意: 运行 show 命令之前,请等待几秒钟以显示详细信息。
cluster1::*> network interface check cluster-connectivity show
                                  Source          Destination       Packet
Node   Date                       LIF             LIF               Loss
n1
       3/5/2022 19:21:18 -06:00   n1_clus2        n2_clus1      none
       3/5/2022 19:21:20 -06:00   n1_clus2        n2_clus2      none
n2
       3/5/2022 19:21:18 -06:00   n2_clus2        n1_clus1      none
       3/5/2022 19:21:20 -06:00   n2_clus2        n1_clus2      none
所有ONTAP版本
对于所有ONTAP版本,您也可以使用 `cluster ping-cluster -node <name>`检查连接性的命令:
cluster::*> cluster ping-cluster -node n1
Host is n1
Getting addresses from network interface table...
Cluster n1_clus1 n1		e4a	10.10.0.1
Cluster n1_clus2 n1		e4e	10.10.0.2
Cluster n2_clus1 n2		e4a	10.10.0.3
Cluster n2_clus2 n2		e4e	10.10.0.4
Local = 10.10.0.1 10.10.0.2
Remote = 10.10.0.3 10.10.0.4
Cluster Vserver Id = 4294967293
Ping status:....
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s)
Detected 1500 byte MTU on 32 path(s):
    Local 10.10.0.1 to Remote 10.10.0.3
    Local 10.10.0.1 to Remote 10.10.0.4
    Local 10.10.0.2 to Remote 10.10.0.3
    Local 10.10.0.2 to Remote 10.10.0.4
Larger than PMTU communication succeeds on 4 path(s)
RPC status:
1 paths up, 0 paths down (tcp check)
1 paths up, 0 paths down (ucp check)
  1. 如果您已禁用自动创建案例功能,请通过调用AutoSupport消息重新启用该功能:
下一步是什么?
完成交换机迁移后,您可以"配置交换机健康监控"。
