准备从Nexus 5596交换机迁移到Nexus 3232C交换机
请按照以下步骤准备Cisco Nexus 5596交换机、以便迁移到Cisco Nexus 3232C交换机。
如果在此集群上启用了 AutoSupport ,则通过调用 AutoSupport 消息禁止自动创建案例:
ssystem node AutoSupport invoke -node * -type all - 消息 MAINT=xhx 是维护时段的持续时间,以小时为单位。
AutoSupport 消息会通知技术支持此维护任务,以便在维护窗口期间禁止自动创建案例。
显示有关配置中设备的信息:
network device-discovery show显示示例
以下示例显示了在每个节点中为每个集群互连交换机配置了多少个集群互连接口:
cluster::> network device-discovery show Local Discovered Node Port Device Interface Platform ----------- ------ ------------------- ---------------- ---------------- n1 /cdp e0a CL1 Ethernet1/1 N5K-C5596UP e0b CL2 Ethernet1/1 N5K-C5596UP e0c CL2 Ethernet1/2 N5K-C5596UP e0d CL1 Ethernet1/2 N5K-C5596UP n2 /cdp e0a CL1 Ethernet1/3 N5K-C5596UP e0b CL2 Ethernet1/3 N5K-C5596UP e0c CL2 Ethernet1/4 N5K-C5596UP e0d CL1 Ethernet1/4 N5K-C5596UP 8 entries were displayed. -
确定每个集群接口的管理或运行状态。
显示网络端口属性:
network port show -role cluster显示示例
以下示例显示了节点 n1 和 n2 上的网络端口属性:
cluster::*> network port show –role cluster (network port show) Node: n1 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 - - e0b Cluster Cluster up 9000 auto/10000 - - e0c Cluster Cluster up 9000 auto/10000 - - e0d Cluster Cluster up 9000 auto/10000 - - Node: n2 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 - - e0b Cluster Cluster up 9000 auto/10000 - - e0c Cluster Cluster up 9000 auto/10000 - - e0d Cluster Cluster up 9000 auto/10000 - - 8 entries were displayed. -
显示有关逻辑接口的信息:
network interface show -role cluster显示示例
以下示例显示了有关集群上所有 LIF 的常规信息,包括其当前端口:
cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e0a true n1_clus2 up/up 10.10.0.2/24 n1 e0b true n1_clus3 up/up 10.10.0.3/24 n1 e0c true n1_clus4 up/up 10.10.0.4/24 n1 e0d true n2_clus1 up/up 10.10.0.5/24 n2 e0a true n2_clus2 up/up 10.10.0.6/24 n2 e0b true n2_clus3 up/up 10.10.0.7/24 n2 e0c true n2_clus4 up/up 10.10.0.8/24 n2 e0d true 8 entries were displayed. -
显示有关已发现的集群交换机的信息:
ssystem cluster-switch show
显示示例
以下示例显示了活动集群交换机:
cluster::*> system cluster-switch show Switch Type Address Model ----------------------------- ------------------ --------------- --------------- CL1 cluster-network 10.10.1.101 NX5596 Serial Number: 01234567 Is Monitored: true Reason: Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 7.1(1)N1(1) Version Source: CDP CL2 cluster-network 10.10.1.102 NX5596 Serial Number: 01234568 Is Monitored: true Reason: Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 7.1(1)N1(1) Version Source: CDP 2 entries were displayed. -
根据您的需要,验证是否在新的 3232C 交换机上安装了适当的 RCF 和映像,并进行必要的站点自定义,例如用户和密码,网络地址以及其他自定义设置。
此时必须准备两个交换机。
如果需要升级 RCF 和映像,必须完成以下步骤:
转到 NetApp 支持站点上的 _Cisco 以太网交换机 _ 页面。
请记下该页面上的表中的交换机和所需的软件版本。
下载适当版本的 RCF 。
在*Description*页上选择*CONTINUOD*,接受许可协议,然后按照*Download*页上的说明下载RCB。
下载相应版本的映像软件。
请参见Cluster and Management ONTAP交换机参考配置文件下载页面,然后选择相应的版本。
要查找正确的版本,请参见 _Cluster ONTAP 8.x 或更高版本的集群网络交换机下载页面 _ 。
迁移与要更换的第二个 Nexus 5596 交换机关联的 LIF :
network interface migrate -vserver vserver-name -lif lif-name -source-node source-node-name - destination-node node-name -destination-port destination-port-name显示示例
以下示例显示了要为节点 n1 和 n2 迁移的 LIF ;必须在所有节点上执行 LIF 迁移:
cluster::*> network interface migrate -vserver Cluster -lif n1_clus2 -source-node n1 - destination-node n1 -destination-port e0a cluster::*> network interface migrate -vserver Cluster -lif n1_clus3 -source-node n1 - destination-node n1 -destination-port e0d cluster::*> network interface migrate -vserver Cluster -lif n2_clus2 -source-node n2 - destination-node n2 -destination-port e0a cluster::*> network interface migrate -vserver Cluster -lif n2_clus3 -source-node n2 - destination-node n2 -destination-port e0d
验证集群的运行状况:
以下示例显示了每个集群的当前状态:
cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e0a true n1_clus2 up/up 10.10.0.2/24 n1 e0a false n1_clus3 up/up 10.10.0.3/24 n1 e0d false n1_clus4 up/up 10.10.0.4/24 n1 e0d true n2_clus1 up/up 10.10.0.5/24 n2 e0a true n2_clus2 up/up 10.10.0.6/24 n2 e0a false n2_clus3 up/up 10.10.0.7/24 n2 e0d false n2_clus4 up/up 10.10.0.8/24 n2 e0d true 8 entries were displayed.
"配置端口"(英文)
