完成从双节点无交换机集群到 Cisco Nexus 3232C 集群交换机的迁移
贡献者 netapp-yvonneo netapp-jsnyder
完成最后步骤,使用 Cisco Nexus 3232C 集群交换机从双节点无交换机集群迁移到双节点交换机集群。
步骤
  1. 验证所有集群互连端口现在都已恢复到其主端口:
    network interface show -role cluster
    `Current Port` 列中列出的所有端口的  `Is Home` 列均应显示值  `true`。如果显示的值为  `false`,则表示该端口尚未恢复。
    显示示例
    cluster::*> network interface show -role cluster
     (network interface show)
                Logical    Status     Network            Current       Current Is
    Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
    Cluster
                n1_clus1   up/up      10.10.0.1/24       n1            e4a     true
                n1_clus2   up/up      10.10.0.2/24       n1            e4e     true
                n2_clus1   up/up      10.10.0.3/24       n2            e4a     true
                n2_clus2   up/up      10.10.0.4/24       n2            e4e     true
    4 entries were displayed.
  2. 验证所有集群互连端口均处于 `up`状态:
    network port show -role cluster
  3. 显示每个集群端口连接到每个节点所经过的集群交换机端口号:
    network device-discovery show
    显示示例
    cluster::*> network device-discovery show
                Local  Discovered
    Node        Port   Device              Interface        Platform
    n1          /cdp
                e4a    C1                  Ethernet1/7      N3K-C3232C
                e4e    C2                  Ethernet1/7      N3K-C3232C
    n2          /cdp
                e4a    C1                  Ethernet1/8      N3K-C3232C
                e4e    C2                  Ethernet1/8      N3K-C3232C
  4. 显示发现和监控的集群交换机:
    system cluster-switch show
    显示示例
    cluster::*> system cluster-switch show
    Switch                      Type               Address          Model
    C1                          cluster-network    10.10.1.101      NX3232CV
    Serial Number: FOX000001
    Is Monitored: true
    Reason:
    Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 7.0(3)I6(1)
    Version Source: CDP
    C2                          cluster-network     10.10.1.102      NX3232CV
    Serial Number: FOX000002
    Is Monitored: true
    Reason:
    Version Source: CDP 2 entries were displayed.
  5. 验证无交换机集群检测是否已将无交换机集群选项更改为禁用:
    network options switchless-cluster show
  6. 验证远程集群接口的连接性:
ONTAP 9.9.1 及更高版本
你可以使用 `network interface check cluster-connectivity`执行命令以启动集群连接性检查,然后显示详细信息:
network interface check cluster-connectivity start`和 `network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
*注意:*运行程序前请等待几秒钟 `show`显示详细信息的命令。
cluster1::*> network interface check cluster-connectivity show
                                  Source           Destination      Packet
Node   Date                       LIF              LIF              Loss
n1
       3/5/2022 19:21:18 -06:00   n1_clus2         n2-clus1         none
       3/5/2022 19:21:20 -06:00   n1_clus2         n2_clus2         none
n2
       3/5/2022 19:21:18 -06:00   n2_clus2         n1_clus1         none
       3/5/2022 19:21:20 -06:00   n2_clus2         n1_clus2         none
所有ONTAP版本
对于所有ONTAP版本,您也可以使用 `cluster ping-cluster -node <name>`检查连接性的命令:
cluster1::*> cluster ping-cluster -node local
Host is n1
Getting addresses from network interface table...
Cluster n1_clus1 n1        e4a    10.10.0.1
Cluster n1_clus2 n1        e4e    10.10.0.2
Cluster n2_clus1 n2        e4a    10.10.0.3
Cluster n2_clus2 n2        e4e    10.10.0.4
Local = 10.10.0.1 10.10.0.2
Remote = 10.10.0.3 10.10.0.4
Cluster Vserver Id = 4294967293
Ping status:....
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s) ................
Detected 9000 byte MTU on 32 path(s):
    Local 10.10.0.1 to Remote 10.10.0.3
    Local 10.10.0.1 to Remote 10.10.0.4
    Local 10.10.0.2 to Remote 10.10.0.3
    Local 10.10.0.2 to Remote 10.10.0.4
Larger than PMTU communication succeeds on 4 path(s) RPC status:
1 paths up, 0 paths down (tcp check)
1 paths up, 0 paths down (ucp check)
  1. 如果您禁止自动创建案例,请通过调用 AutoSupport 消息重新启用它:
下一步是什么?
完成交换机迁移后,您可以 "配置交换机健康监控"。
