安装 NX-OS 软件
提供者 netapp-yvonneo netapp-martyh
您可以使用此操作步骤在 Nexus 9336C-x2 集群交换机上安装 NX-OS 软件。
  1. 将集群交换机连接到管理网络。
  2. 使用 ping 命令验证与托管 NX-OS 软件和 RCF 的服务器的连接。
    此示例验证交换机是否可以通过 IP 地址 172.19.2.1 访问服务器:
    cs2# ping 172.19.2.1
    Pinging 172.19.2.1 with 0 bytes of data:
    Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
  3. 将 NX-OS 软件和 EPLD 映像复制到 Nexus 9336C-x2 交换机。
    cs2# copy sftp: bootflash: vrf management
    Enter source filename: /code/nxos.9.3.5.bin
    Enter hostname for the sftp server: 172.19.2.1
    Enter username: user1
    Outbound-ReKey for 172.19.2.1:22
    Inbound-ReKey for 172.19.2.1:22
    user1@172.19.2.1's password:
    sftp> progress
    Progress meter enabled
    sftp> get   /code/nxos.9.3.5.bin  /bootflash/nxos.9.3.5.bin
    /code/nxos.9.3.5.bin  100% 1261MB   9.3MB/s   02:15
    sftp> exit
    Copy complete, now saving to disk (please wait)...
    Copy complete.
    Enter source filename: /code/n9000-epld.9.3.5.img
    sftp> progress
    sftp> get   /code/n9000-epld.9.3.5.img  /bootflash/n9000-epld.9.3.5.img
    /code/n9000-epld.9.3.5.img  100%  161MB   9.5MB/s   00:16
    sftp> exit
    Copy complete.
  4. 验证正在运行的 NX-OS 软件版本:
    cs2# show version
    Cisco Nexus Operating System (NX-OS) Software
    TAC support: http://www.cisco.com/tac
    Copyright (C) 2002-2020, Cisco and/or its affiliates.
    All rights reserved.
    The copyrights to certain works contained in this software are
    owned by other third parties and used and distributed under their own
    licenses, such as open source.  This software is provided "as is," and unless
    otherwise stated, there is no warranty, express or implied, including but not
    limited to warranties of merchantability and fitness for a particular purpose.
    Certain components of this software are licensed under
    the GNU General Public License (GPL) version 2.0 or
    GNU General Public License (GPL) version 3.0  or the GNU
    Lesser General Public License (LGPL) Version 2.1 or
    Lesser General Public License (LGPL) Version 2.0.
    A copy of each such license is available at
    http://www.opensource.org/licenses/gpl-2.0.php and
    http://opensource.org/licenses/gpl-3.0.html and
    http://www.opensource.org/licenses/lgpl-2.1.php and
    http://www.gnu.org/licenses/old-licenses/library.txt.
    Software
      BIOS: version 08.38
      NXOS: version 9.3(4)
      BIOS compile time:  05/29/2020
      NXOS image file is: bootflash:///nxos.9.3.4.bin
      NXOS compile time:  4/28/2020 21:00:00 [04/29/2020 02:28:31]
    Hardware
      cisco Nexus9000 C9336C-FX2 Chassis
      Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory.
      Processor Board ID FOC20291J6K
      Device name: cs2
      bootflash:   53298520 kB
    Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 42 second(s)
    Last reset at 157524 usecs after Mon Nov  2 18:32:06 2020
      Reason: Reset Requested by CLI command reload
      System version: 9.3(4)
      Service:
    plugin
      Core Plugin, Ethernet Plugin
    Active Package(s):
    cs2#
  5. 安装 NX-OS 映像。
    安装映像文件会导致每次重新启动交换机时加载该映像文件。
    cs2# install all nxos bootflash:nxos.9.3.5.bin
    Installer will perform compatibility check first. Please wait.
    Installer is forced disruptive
    Verifying image bootflash:/nxos.9.3.5.bin for boot variable "nxos".
    [####################] 100% -- SUCCESS
    Verifying image type.
    Preparing "nxos" version info using image bootflash:/nxos.9.3.5.bin.
    Preparing "bios" version info using image bootflash:/nxos.9.3.5.bin.
    Performing module support checks.
    Notifying services about system upgrade.
    Compatibility check is done:
    Module  bootable       Impact     Install-type  Reason
      1       yes      disruptive         reset     default upgrade is not hitless
    Images will be upgraded according to following table:
    Module   Image    Running-Version(pri:alt                  New-Version         Upg-Required
      1      nxos     9.3(4)                                   9.3(5)                  yes
      1      bios     v08.37(01/28/2020):v08.23(09/23/2015)    v08.38(05/29/2020)      yes
    Switch will be reloaded for disruptive upgrade.
    Do you want to continue with the installation (y/n)?  [n] **y**
    Install is in progress, please wait.
    Performing runtime checks.
    Setting boot variables.
    Performing configuration copy.
    Module 1: Refreshing compact flash and upgrading bios/loader/bootrom.
    Warning: please do not remove or power off the module at this time.
    Finishing the upgrade, switch will reboot in 10 seconds.
  6. 在交换机重新启动后验证 NX-OS 软件的新版本: show version
    cs2# show version
    Software
      BIOS: version 05.33
      NXOS: version 9.3(5)
      BIOS compile time:  09/08/2018
      NXOS image file is: bootflash:///nxos.9.3.5.bin
      NXOS compile time:  11/4/2018 21:00:00 [11/05/2018 06:11:06]
    Hardware
      Device name: cs2
    Last reset at 277524 usecs after Mon Nov  2 22:45:12 2020
      Reason: Reset due to upgrade
      Service:
    plugin
    Active Package(s):
  7. 升级 EPLD 映像并重新启动交换机。
    cs2# show version module 1 epld
    EPLD Device                     Version
    MI   FPGA                        0x7
    IO   FPGA                        0x17
    MI   FPGA2                       0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    cs2# install epld bootflash:n9000-epld.9.3.5.img module 1
    Compatibility check:
    Module        Type         Upgradable        Impact   Reason
         1         SUP         Yes       disruptive  Module Upgradable
    Retrieving EPLD versions.... Please wait.
    Module  Type   EPLD              Running-Version   New-Version  Upg-Required
         1  SUP    MI FPGA           0x07              0x07         No
         1  SUP    IO FPGA           0x17              0x19         Yes
         1  SUP    MI FPGA2          0x02              0x02         No
    The above modules require upgrade.
    The switch will be reloaded at the end of the upgrade
    Do you want to continue (y/n) ?  [n] y
    Proceeding to upgrade Modules.
    Starting Module 1 EPLD Upgrade
    Module 1 : IO FPGA [Programming] : 100.00% (     64 of      64 sectors)
    Module 1 EPLD upgrade is successful.
    Module   Type  Upgrade-Result
         1   SUP   Success
    EPLDs upgraded.
  8. 交换机重新启动后,重新登录并验证是否已成功加载新版本的 EPLD 。
    EPLD Device                     Version
    MI   FPGA                        0x7
    IO   FPGA                        0x19
    MI   FPGA2                       0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
    GEM  FPGA                        0x2
