SMIS CRP.
smis 命令可描述 NetApp SMI-S Provider 支持的已注册 CIM 配置文件,包括 NetApp SMI-S Provider 配置文件。
语法
SMIS CRP.
` [-t { * http* | * https * } ]`
位置
C : \Program Files ( x86 ) \NetApp\SMIs\pegasus\bin
权限级别
具有有效用户名和密码的用户
` * ( -t { http : https } ) *`
要使用的协议: HTTPS (默认)或 HTTP
示例
smis 命令及其输出:
smis crp PG_RegisteredProfile.InstanceID="SNIA:Profile Registration:1.4.0" PG_RegisteredProfile.InstanceID="SNIA:SMI-S:1.4.0" PG_RegisteredProfile.InstanceID="SNIA:SMI-S:1.5.0" PG_RegisteredProfile.InstanceID="SNIA:SMI-S:1.6.0" PG_RegisteredProfile.InstanceID="SNIA:Server:1.4.0" PG_RegisteredProfile.InstanceID="SNIA:Server:1.5.0" PG_RegisteredProfile.InstanceID="SNIA:Server:1.6.0" PG_RegisteredProfile.InstanceID="DMTF:Profile Registration:1.4.0" PG_RegisteredProfile.InstanceID="DMTF:Indications:1.4.0" PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.4.0" PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.5.0" PG_RegisteredSubProfile.InstanceID="SNIA:Indication:1.6.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.4.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.5.0" PG_RegisteredSubProfile.InstanceID="SNIA:Software:1.6.0" PG_RegisteredSubProfile.InstanceID="SNIA:Object Manager Adapter:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:iSCSI Target Ports:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:iSCSI Target Ports:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Software:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Disk Drive Lite:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Multiple Computer System:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Access Points:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Target Port:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FC Initiator Ports:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Masking and Mapping:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Masking and Mapping:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Extent Composition:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Server Performance:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Server Performance:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Physical Package:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Physical Package:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Block Services:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Health:1.2.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FileSystem:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Storage:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export Manipulation:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Export Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File System Manipulation:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Filesystem Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:File Server Manipulation:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:FileSystem Quotas:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Job Control:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Job Control:1.3.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Location:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:NAS Network Port:1.4.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Replication Services:1.5.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Replication Services:1.6.0" ONTAP_RegisteredSubProfile.InstanceID="ONTAP:Capacity Utilization:1.4.0"
