SMIS 卷
smis volumes 命令可列出存储系统的传统卷和灵活卷。
语法
smis volumes
` [-t { * http* | * https * } ]`
对于ONTAP、您必须使用命令、 `smis pools`而不是 `smis volumes`命令。 |
位置
C : \Program Files ( x86 ) \NetApp\SMIs\pegasus\bin
权限级别
具有有效用户名和密码的用户
` * ( -t { http : https } ) *`
要使用的协议: HTTPS (默认)或 HTTP
示例
smis volumes 命令及其缩写输出:
smis volumes ONTAP_LogicalDisk.CreationClassName="ONTAP_LogicalDisk",DeviceID="d46de7f0-3925- 11df-8516-00a0980558ea",SystemCreationClassName="ONTAP_StorageSystem",SystemName ="ONTAP:0084259609" ONTAP_LogicalDisk.CreationClassName="ONTAP_LogicalDisk",DeviceID="397cd140-3a45- 11df-8516-00a0980558ea",SystemCreationClassName="ONTAP_StorageSystem",SystemName ="ONTAP:0084259609" ONTAP_LogicalDisk.CreationClassName="ONTAP_LogicalDisk",DeviceID="69c472c0-4b27- 11df-8517-00a0980558ea",SystemCreationClassName="ONTAP_StorageSystem",SystemName ="ONTAP:0084259609" ONTAP_LogicalDisk.CreationClassName="ONTAP_LogicalDisk",DeviceID="6c7ea0b0-3927- 11df-8516-00a0980558ea",SystemCreationClassName="ONTAP_StorageSystem",SystemName ="ONTAP:0084259609"
