Snapdrive for Unix
脚本示例
贡献者
以下是使用退出状态值的脚本示例。
以下脚本使用 SnapDrive for UNIX 退出状态值:
	#!/bin/sh
	# This script demonstrates a SnapDrive
	# script that uses exit codes.
	RET=0;
	#The above statement initializes RET and sets it to 0
	snapdrive snap create -dg vg22 -snapname vg22_snap1;
	# The above statement executes the snapdrive command
	RET=$?;
	#The above statement captures the return code.
	#If the operation worked, print
	#success message. If the operation failed, print
	#failure message and exit.
	if [ $RET -eq 0 ]; then
	echo "snapshot created successfully"
	else
	echo "snapshot creation failed, snapdrive exit code was $RET"
	exit 1
	fi
	exit 0;
如果 RET=0 ,则命令已成功执行,并且脚本输出以下内容:
	# ./tst_script
	snap create: snapshot vg22_snap1 contains:
	disk group vg22 containing host volumes
	lvol1
	snap create: created snapshot betty:/vol/vol2:vg22_snap1
如果 RET = 非零值,则命令未成功执行。以下示例显示了典型输出:
	# ./tst_script
	0001-185 Command error: snapshot betty:/vol/vol2:vg22_snap1 already
	exists on betty:/vol/vol2.
	Please use -f (force) flag to overwrite existing snapshot
	snapshot creation failed, snapdrive exit code was 4
