准备配置Azure NetApp Files 后端
在配置ANF后端之前、您需要确保满足以下要求。
如果您是首次使用 Azure NetApp Files 或在新位置使用,则需要进行一些初始配置。
要设置Azure NetApp Files 并创建NFS卷、请参见 "Azure:设置Azure NetApp Files 并创建NFS卷"。
要配置Azure NetApp Files 并添加SMB卷、请参见: "Azure:为Azure NetApp Files 创建SMB卷"。
要求
配置和使用 "Azure NetApp Files" 后端,您需要满足以下要求:
subscriptionID从启用了Azure NetApp Files 的Azure订阅。 -
tenantID,clientID,和clientSecret从 "应用程序注册" 在 Azure Active Directory 中,具有足够的 Azure NetApp Files 服务权限。应用程序注册应使用以下任一项:-
所有者或贡献者角色 "由Azure预定义"
答 "自定义贡献者角色" 订阅级别 (
assignableScopes)、并具有以下权限、这些权限仅限于Astra Trident所需的权限。创建自定义角色后、 "使用Azure门户分配角色"。{ "id": "/subscriptions/<subscription-id>/providers/Microsoft.Authorization/roleDefinitions/<role-definition-id>", "properties": { "roleName": "custom-role-with-limited-perms", "description": "custom role providing limited permissions", "assignableScopes": [ "/subscriptions/<subscription-id>" ], "permissions": [ { "actions": [ "Microsoft.NetApp/netAppAccounts/capacityPools/read", "Microsoft.NetApp/netAppAccounts/capacityPools/write", "Microsoft.NetApp/netAppAccounts/capacityPools/volumes/read", "Microsoft.NetApp/netAppAccounts/capacityPools/volumes/write", "Microsoft.NetApp/netAppAccounts/capacityPools/volumes/delete", "Microsoft.NetApp/netAppAccounts/capacityPools/volumes/snapshots/read", "Microsoft.NetApp/netAppAccounts/capacityPools/volumes/snapshots/write", "Microsoft.NetApp/netAppAccounts/capacityPools/volumes/snapshots/delete", "Microsoft.NetApp/netAppAccounts/capacityPools/volumes/subvolumes/read", "Microsoft.NetApp/netAppAccounts/capacityPools/volumes/subvolumes/write", "Microsoft.NetApp/netAppAccounts/capacityPools/volumes/subvolumes/delete", "Microsoft.NetApp/netAppAccounts/capacityPools/volumes/subvolumes/GetMetadata/action", "Microsoft.NetApp/netAppAccounts/capacityPools/volumes/MountTargets/read", "Microsoft.Network/virtualNetworks/read", "Microsoft.Network/virtualNetworks/subnets/read", "Microsoft.Features/featureProviders/subscriptionFeatureRegistrations/read", "Microsoft.Features/featureProviders/subscriptionFeatureRegistrations/write", "Microsoft.Features/featureProviders/subscriptionFeatureRegistrations/delete", "Microsoft.Features/features/read", "Microsoft.Features/operations/read", "Microsoft.Features/providers/features/read", "Microsoft.Features/providers/features/register/action", "Microsoft.Features/providers/features/unregister/action", "Microsoft.Features/subscriptionFeatureRegistrations/read" ], "notActions": [], "dataActions": [], "notDataActions": [] } ] } }
Azure
location至少包含一个 "委派子网"。自Trident 22.01日开始location参数是后端配置文件顶层的必填字段。在虚拟池中指定的位置值将被忽略。
SMB卷的其他要求
一个Kubernetes集群、其中包含一个Linux控制器节点以及至少一个运行Windows Server 2019的Windows工作节点。Astra Trident仅支持将SMB卷挂载到Windows节点上运行的Pod。
至少有一个包含Active Directory凭据的Astra Trident密钥、以便ANF可以向Active Directory进行身份验证。以生成密钥
smbcreds:kubectl create secret generic smbcreds --from-literal username=user --from-literal password='pw'
配置为Windows服务的CSI代理。配置
csi-proxy、请参见 "GitHub:CSI代理" 或 "GitHub:适用于Windows的CSI代理" 适用于在Windows上运行的Kubernetes节点。
