Astra Automation
此產品有較新版本可以使用。
Execution Hook overview
貢獻者
The Execution Hook API provides CRUD (Create-Read-Update-Delete) access to executionHook resources in order to allow simple management of execution hooks. Execution hooks contain additional configuration and references to a hook source resource.
