SANtricity commands
測試外部金鑰管理通訊 - SANtricity CLI
貢獻者 netapp-driley
「Start storageArray externalKeyManagement test」命令會使用已設定的認證(憑證、KMIP伺服器位址和KMIP連接埠號)、來驗證儲存陣列是否能夠與外部KMIP伺服器通訊。
支援的陣列
此指令適用於單一 E4000、E2800、E5700、EF600、EF300、EF50 和 EF80 儲存陣列。它不適用於 E2700 或 E5600 儲存陣列。
角色
若要在 E4000、E2800、E5700、EF600、EF300、EF50 或 EF80 儲存陣列上執行此命令,您必須具有 Security Admin 角色。
背景
註
此命令僅適用於外部金鑰管理。
語法
start storageArray externalKeyManagement test
參數
無。
附註
以下範例顯示了儲存陣列能夠與外部金鑰管理伺服器通訊時命令的輸出結果。輸出結果包括金鑰管理伺服器的狀態、用戶端憑證和伺服器憑證。
Key servers configured:
C:\Users\Administrator\Downloads\SMcli (1)\SMcli-02.00.00.0011\bin>SMcli.bat 10.115.XX.XXX -u admin -p infiniti -k -c "start storageArray externalKeyManagement test;"
Performing syntax check...
Syntax check complete.
Executing script...
SUMMARY:
   Key management server:
      Server address: ::
      Server port: 9003
      Local controller status: Connection failure
      Alternate controller status: Unknown
      Client certificate status: Ok
      Server certificate status: Ok
DETAILS:
Unable to communicate with the key management server. To correct the problem, perform the
following steps: 1) Check that the key management server address and port is correct. 2) If
the key management server's address is a domain name, check that both controller's DNS
servers are operational and reachable from the controller given your network configuration.
3) Check that the key management server operational and reachable from the controller given
your network configuration. 4) Once the problem has been found and corrected, re-perform the
communication test between the storage array and key management server to clear the needs
attention state on the array.
Script execution complete.
SMcli completed successfully.
No key servers configured:
Executing script...
No key management servers configured.
最低韌體層級
8.40
