AIX 主機公用程式 6.1 範例命令參照
貢獻者
建議變更
您可以使用 AIX 主機公用程式 6.1 範例命令參照、使用主機公用程式工具來進行端點對端點 NetApp 儲存組態驗證。
列出所有對應至主機的主機啟動器
您可以擷取對應至主機的主機啟動器清單。
# sanlun fcp show adapter -v
輸出範例 *
bash-3.2# sanlun fcp show adapter -v adapter name: fcs0 WWPN: 100000109b22e143 WWNN: 200000109b22e143 driver name: /usr/lib/drivers/pci/emfcdd model: df1000e31410150 model description: FC Adapter serial number: YA50HY79S117 hardware version: Not Available driver version: 7.2.5.0 firmware version: 00012000040025700027 Number of ports: 1 port type: Fabric port state: Operational supported speed: 16 GBit/sec negotiated speed: Unknown OS device name: fcs0 adapter name: fcs1 WWPN: 100000109b22e144 WWNN: 200000109b22e144 driver name: /usr/lib/drivers/pci/emfcdd model: df1000e31410150 model description: FC Adapter serial number: YA50HY79S117 hardware version: Not Available driver version: 7.2.5.0 firmware version: 00012000040025700027 Number of ports: 1 port type: Fabric port state: Operational supported speed: 16 GBit/sec negotiated speed: Unknown OS device name: fcs1 bash-3.2#
列出所有對應至主機的LUN
您可以擷取對應至主機的所有 LUN 清單。
# sanlun lun show -p -v all
輸出範例 *
ONTAP Path: vs_aix_clus:/vol/gpfs_205p2_207p1_vol_0_8/aix_205p2_207p1_lun LUN: 88 LUN Size: 15g Host Device: hdisk9 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority ----------------------------------------------------- up primary path0 fcs0 fc_aix_1 1 up primary path1 fcs1 fc_aix_2 1 up secondary path2 fcs0 fc_aix_3 1 up secondary path3 fcs1 fc_aix_4 1
列出從特定SVM對應至主機的所有LUN
您可以從指定的 SVM 擷取對應至主機的所有 LUN 清單。
# sanlun lun show -p -v sanboot_unix
輸出範例 *
ONTAP Path: sanboot_unix:/vol/aix_205p2_boot_0/boot_205p2_lun LUN: 0 LUN Size: 80.0g Host Device: hdisk85 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority ------------------------------------------------- up primary path0 fcs0 sanboot_1 1 up primary path1 fcs1 sanboot_2 1 up secondary path2 fcs0 sanboot_3 1 up secondary path3 fcs1 sanboot_4 1
列出對應至主機之特定LUN的所有屬性
您可以擷取對應至主機之指定 LUN 的所有屬性清單。
# sanlun lun show -p -v vs_aix_clus:/vol/gpfs_205p2_207p1_vol_0_8/aix_205p2_207p1_lun
輸出範例 *
ONTAP Path: vs_aix_clus:/vol/gpfs_205p2_207p1_vol_0_8/aix_205p2_207p1_lun LUN: 88 LUN Size: 15g Host Device: hdisk9 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority --------------------------------------------------------- up primary path0 fcs0 fc_aix_1 1 up primary path1 fcs1 fc_aix_2 1 up secondary path2 fcs0 fc_aix_3 1 up secondary path3 fcs1 fc_aix_4 1
依主機裝置檔案名稱列出 ONTAP LUN 屬性
您可以透過指定主機裝置檔案名稱來擷取 ONTAP LUN 屬性清單。
#sanlun lun show -d /dev/hdisk1
輸出範例 *
controller(7mode)/ device host lun vserver(Cmode) lun-pathname ----------------------------------------------------------------------------- vs_aix_clus /vol/gpfs_205p2_207p1_vol_0_0/aix_205p2_207p1_lun filename adapter protocol size mode ----------------------------------- hdisk1 fcs0 FCP 15g C
列出附加至主機的所有SVM目標LIF WWPN
您可以擷取附加至主機的所有 SVM 目標 LIF WWPN 清單。
# sanlun lun show -wwpn
輸出範例 *
controller(7mode)/ target device host lun vserver(Cmode) wwpn lun-pathname -------------------------------------------------------------------------------- vs_aix_clus 203300a098ba7afe /vol/gpfs_205p2_207p1_vol_0_0/aix_205p2_207p1_lun vs_aix_clus 203300a098ba7afe /vol/gpfs_205p2_207p1_vol_0_9/aix_205p2_207p1_lun vs_aix_clus 203300a098ba7afe /vol/gpfs_205p2_207p1_vol_en_0_0/aix_205p2_207p1_lun_en vs_aix_clus 202f00a098ba7afe /vol/gpfs_205p2_207p1_vol_en_0_1/aix_205p2_207p1_lun_en filename adapter size mode ----------------------------------- hdisk1 fcs0 15g C hdisk10 fcs0 15g C hdisk11 fcs0 15g C hdisk12 fcs0 15g C
