用於 ONTAP 儲存組態的 HP-UX Host Utilities 指令
使用 HP-UX Host Utilities 6.0 範例指令參考,透過 Host Utilities 工具對ONTAP儲存設定進行端對端驗證。
列出所有對應至主機的主機啟動器
檢索映射到主機的所有主機啟動器的清單。
sanlun fcp show adapter -v
顯示範例輸出
adapter name: fclp2 WWPN: 10000000c985ef92 WWNN: 20000000c985ef92 driver name: fclp model: AJ763-63001 model description: HP 8Gb Dual Channel PCI-e 2.0 FC HBA serial number: MY19034N9U hardware version: 3 driver version: @(#) FCLP: PCIe Fibre Channel driver (FibrChanl-02), B.11.31.1805, Feb 5 2018, FCLP_IFC (3,2) firmware version: 2.02X2 SLI-3 (U3D2.02X2) Number of ports: 1 of 2 port type: Unknown port state: Link Down supported speed: 8 GBit/sec negotiated speed: Speed not established OS device name: /dev/fclp2 adapter name: fclp3 WWPN: 10000000c985ef93 WWNN: 20000000c985ef93 driver name: fclp model: AJ763-63001 model description: HP 8Gb Dual Channel PCI-e 2.0 FC HBA serial number: MY19034N9U hardware version: 3 driver version: @(#) FCLP: PCIe Fibre Channel driver (FibrChanl-02), B.11.31.1805, Feb 5 2018, FCLP_IFC (3,2) firmware version: 2.02X2 SLI-3 (U3D2.02X2) Number of ports: 2 of 2 port type: Unknown port state: Link Down supported speed: 8 GBit/sec negotiated speed: Speed not established OS device name: /dev/fclp3
列出所有對應至主機的LUN
檢索對應到主機的所有 LUN 的清單。
sanlun lun show -p -v all
顯示範例輸出
ONTAP Path: vs_hp_cluster:/vol/chathpux_217_vol_en_1_10/hp_en_217_lun
LUN: 55
LUN Size: 15g
Host Device: /dev/rdisk/disk718
Mode: C
VG: /dev/vg_data
Multipath Policy: A/A
Multipath Provider: Native
host vserver /dev/dsk HP A/A
path path filename host vserver path failover
state type or hardware path adapter LIF priority
up primary /dev/dsk/c37t6d7 fclp0 hpux_7 0
up primary /dev/dsk/c22t6d7 fclp1 hpux_8 0
up secondary /dev/dsk/c36t6d7 fclp0 hpux_5 1
up secondary /dev/dsk/c44t6d7 fclp1 hpux_6 1
列出從特定SVM對應至主機的所有LUN
檢索從特定 SVM 對應到主機的所有 LUN 的清單。
sanlun lun show -p -v vs_hp_cluster
顯示範例輸出
LUN: 55
LUN Size: 15g
Mode: C
VG: /dev/vg_data
列出對應至主機之特定LUN的所有屬性
檢索對應到主機的指定 LUN 的所有屬性的清單。
sanlun lun show -p -v vs_hp_cluster:/vol/chathpux_217_vol_en_1_5/hp_en_217_lun
顯示範例輸出
ONTAP Path: vs_hp_cluster:/vol/chathpux_217_vol_en_1_5/hp_en_217_lun
LUN: 49
LUN Size: 15g
Host Device: /dev/rdisk/disk712
Mode: C
VG: /dev/vg_data
up primary /dev/dsk/c37t6d1 fclp0 hpux_7 0
up primary /dev/dsk/c22t6d1 fclp1 hpux_8 0
up secondary /dev/dsk/c36t6d1 fclp0 hpux_5 1
up secondary /dev/dsk/c44t6d1 fclp1 hpux_6 1
依主機裝置檔案名稱列出 ONTAP LUN 屬性
透過指定的主機設備檔案名稱擷取ONTAP LUN 屬性清單。
sanlun lun show -dv /dev/rdisk/disk716
顯示範例輸出
device host lun
vserver lun-pathname filename adapter protocol size mode
vs_hp_cluster /vol/chathpux_217_vol_en_1_14/hp_en_217_lun /dev/rdisk/disk716 0 FCP 15g C
LUN Serial number: 80D7l?NiNP5U
Controller Model Name: AFF-A800
Vserver FCP nodename: 208400a098ba7afe
Vserver FCP portname: 207e00a098ba7afe
Vserver LIF name: hpux_5
Vserver IP address: 10.141.54.30
10.141.54.35
10.141.54.37
10.141.54.33
10.141.54.31
Vserver volume name: chathpux_217_vol_en_1_14 MSID::0x00000000000000000000000080915935
Vserver snapshot name:
列出附加至主機的所有SVM目標LIF WWPN
檢索連接到主機的所有 SVM 目標 LIF WWPN 的清單。
sanlun lun show -wwpn
顯示範例輸出
controller(7mode)/ vserver(Cmode) target wwpn lun-pathname device filename -------------------------------------------------------------------------------------------------------- vs_hp_cluster 208300a098ba7afe /vol/chathpux_217_vol_en_1_10/hp_en_217_lun /dev/rdsk/c22t6d7 vs_hp_cluster 208100a098ba7afe /vol/chathpux_217_vol_en_1_10/hp_en_217_lun /dev/rdsk/c44t6d7 vs_hp_cluster 208200a098ba7afe /vol/chathpux_217_vol_en_1_10/hp_en_217_lun /dev/rdsk/c37t6d7 vs_hp_cluster 207e00a098ba7afe /vol/chathpux_217_vol_en_1_10/hp_en_217_lun /dev/rdsk/c36t6d7 vs_hp_cluster 207d00a098ba7afe /vol/chathpux_217_os/hp_217_os /dev/rdsk/c18t7d4 vs_hp_cluster 207f00a098ba7afe /vol/chathpux_217_os/hp_217_os /dev/rdsk/c42t7d4 host adapter lun size mode --------------------------------- fclp1 15g C fclp1 15g C fclp0 15g C fclp0 15g C fclp1 30g C fclp0 30g C
