編輯參考組態檔案(RCF)
貢獻者
若要啟動新授權的連接埠、您必須編輯最新版的RCF、然後取消註釋適用的連接埠詳細資料。預設授權會啟動連接埠0/1到0/16和0/55到0/56、而新授權的連接埠則會在連接埠0/17到0/54之間、視可用授權的類型和數量而定。
如需有關用於B3作業 叢集交換器的可用授權類型詳細資料、請參閱 "安裝B封閉 環境叢集交換器的授權"。
例如、若要啟動SW-BES54248-40-100g-LIC授權、您必須取消註解RCF中的下列章節:
. . ! ! 2-port or 6-port 40/100GbE node port license block ! interface 0/49 no shutdown description "40/100GbE Node Port" !speed 100G full-duplex speed 40G full-duplex service-policy in WRED_100G spanning-tree edgeport mtu 9216 switchport mode trunk datacenter-bridging priority-flow-control mode on priority-flow-control priority 5 no-drop exit exit ! interface 0/50 no shutdown description "40/100GbE Node Port" !speed 100G full-duplex speed 40G full-duplex service-policy in WRED_100G spanning-tree edgeport mtu 9216 switchport mode trunk datacenter-bridging priority-flow-control mode on priority-flow-control priority 5 no-drop exit exit ! interface 0/51 no shutdown description "40/100GbE Node Port" speed 100G full-duplex !speed 40G full-duplex service-policy in WRED_100G spanning-tree edgeport mtu 9216 switchport mode trunk datacenter-bridging priority-flow-control mode on priority-flow-control priority 5 no-drop exit exit ! interface 0/52 no shutdown description "40/100GbE Node Port" speed 100G full-duplex !speed 40G full-duplex service-policy in WRED_100G spanning-tree edgeport mtu 9216 switchport mode trunk datacenter-bridging priority-flow-control mode on priority-flow-control priority 5 no-drop exit exit ! interface 0/53 no shutdown description "40/100GbE Node Port" speed 100G full-duplex !speed 40G full-duplex service-policy in WRED_100G spanning-tree edgeport mtu 9216 switchport mode trunk datacenter-bridging priority-flow-control mode on priority-flow-control priority 5 no-drop exit exit ! interface 0/54 no shutdown description "40/100GbE Node Port" speed 100G full-duplex !speed 40G full-duplex service-policy in WRED_100G spanning-tree edgeport mtu 9216 switchport mode trunk datacenter-bridging priority-flow-control mode on priority-flow-control priority 5 no-drop exit exit ! . .
對於0/49到0/54(含)之間的高速連接埠、請針對每個連接埠取消註解、但在RCF中只取消註釋一條*速度*線路、以便針對每個連接埠: |
速度100公克全雙工
速度40G全雙工
如範例所示。
對於0/17到0/48(含)之間的低速度連接埠、請在啟用適當授權後、取消註釋整個8埠區段。
