準備從 Nexus 5596 交換器遷移到 Nexus 3132Q-V 交換機
請依照下列步驟準備將Cisco Nexus 5596 交換器遷移到Cisco Nexus 3132Q-V 交換器。
如果此叢集上啟用了AutoSupport ,則透過呼叫AutoSupport訊息來抑制自動建立案例:
system node autosupport invoke -node * -type all -message MAINT=xhx 是維護視窗的持續時間,單位為小時。
此訊息通知技術支援部門此維護任務,以便在維護期間禁止自動建立案例。 -
顯示配置中設備的資訊:
network device-discovery show顯示範例
以下範例顯示了每個節點上每個叢集互連交換器配置的叢集互連連接口數量:
cluster::> network device-discovery show Local Discovered Node Port Device Interface Platform ----------- ------ ------------------- ---------------- ---------------- n1 /cdp e0a CL1 Ethernet1/1 N5K-C5596UP e0b CL2 Ethernet1/1 N5K-C5596UP e0c CL2 Ethernet1/2 N5K-C5596UP e0d CL1 Ethernet1/2 N5K-C5596UP n2 /cdp e0a CL1 Ethernet1/3 N5K-C5596UP e0b CL2 Ethernet1/3 N5K-C5596UP e0c CL2 Ethernet1/4 N5K-C5596UP e0d CL1 Ethernet1/4 N5K-C5596UP 8 entries were displayed. -
確定每個叢集介面的管理或運作狀態:
顯示網路連接埠屬性:
network port show
顯示範例
以下範例顯示系統上的網路連接埠屬性:
cluster::*> network port show –role cluster (network port show) Node: n1 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 - - e0b Cluster Cluster up 9000 auto/10000 - - e0c Cluster Cluster up 9000 auto/10000 - - e0d Cluster Cluster up 9000 auto/10000 - - Node: n2 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 - - e0b Cluster Cluster up 9000 auto/10000 - - e0c Cluster Cluster up 9000 auto/10000 - - e0d Cluster Cluster up 9000 auto/10000 - - 8 entries were displayed.-
顯示邏輯介面資訊:+
network interface show顯示範例
以下範例顯示系統中所有 LIF 的一般資訊:
cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e0a true n1_clus2 up/up 10.10.0.2/24 n1 e0b true n1_clus3 up/up 10.10.0.3/24 n1 e0c true n1_clus4 up/up 10.10.0.4/24 n1 e0d true n2_clus1 up/up 10.10.0.5/24 n2 e0a true n2_clus2 up/up 10.10.0.6/24 n2 e0b true n2_clus3 up/up 10.10.0.7/24 n2 e0c true n2_clus4 up/up 10.10.0.8/24 n2 e0d true 8 entries were displayed. -
顯示已發現的群集交換器的相關資訊:+
system cluster-switch show顯示範例
以下範例顯示了叢集已知的叢集交換器及其管理 IP 位址:
cluster::*> system cluster-switch show Switch Type Address Model ----------------------------- ------------------ --------------- --------------- CL1 cluster-network 10.10.1.101 NX5596 Serial Number: 01234567 Is Monitored: true Reason: Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 7.1(1)N1(1) Version Source: CDP CL2 cluster-network 10.10.1.102 NX5596 Serial Number: 01234568 Is Monitored: true Reason: Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 7.1(1)N1(1) Version Source: CDP 2 entries were displayed.
設定 `-auto-revert`參數 `false`在兩個節點上的叢集 LIF clus1 和 clus2 上:
network interface modify顯示範例
cluster::*> network interface modify -vserver node1 -lif clus1 -auto-revert false cluster::*> network interface modify -vserver node1 -lif clus2 -auto-revert false cluster::*> network interface modify -vserver node2 -lif clus1 -auto-revert false cluster::*> network interface modify -vserver node2 -lif clus2 -auto-revert false
確認已根據您的要求在新 3132Q-V 交換器上安裝了相應的 RCF 和映像,並進行必要的網站自訂,例如使用者和密碼、網路位址等。
此時您必須準備好這兩個開關。如果需要升級 RCF 和鏡像,請依照下列步驟操作:
前往"Cisco乙太網路交換機"在NetApp支援網站上。
請記下您交換器的型號以及該頁表格中所需的軟體版本。
下載相應版本的RCF。
在“描述”頁面上選擇“繼續”,接受許可協議,然後按照“下載”頁面上的說明下載 RCF。
下載對應版本的影像處理軟體。
請參閱「ONTAP 8.x 或更高版本叢集和管理網路交換器參考設定檔下載」頁面,然後選擇對應的版本。
若要尋找正確的版本,請參閱_ONTAP 8.x 或更高版本叢集網路交換器下載頁面_。
遷移與待替換的第二台 Nexus 5596 交換器相關的 LIF:
network interface migrate顯示範例
以下範例顯示了 n1 和 n2,但 LIF 遷移必須在所有節點上執行:
cluster::*> network interface migrate -vserver Cluster -lif n1_clus2 -source-node n1 - destination-node n1 -destination-port e0a cluster::*> network interface migrate -vserver Cluster -lif n1_clus3 -source-node n1 - destination-node n1 -destination-port e0d cluster::*> network interface migrate -vserver Cluster -lif n2_clus2 -source-node n2 - destination-node n2 -destination-port e0a cluster::*> network interface migrate -vserver Cluster -lif n2_clus3 -source-node n2 - destination-node n2 -destination-port e0d
驗證集群健康狀況:
以下範例展示了前一個結果。 `network interface migrate`命令:
cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e0a true n1_clus2 up/up 10.10.0.2/24 n1 e0a false n1_clus3 up/up 10.10.0.3/24 n1 e0d false n1_clus4 up/up 10.10.0.4/24 n1 e0d true n2_clus1 up/up 10.10.0.5/24 n2 e0a true n2_clus2 up/up 10.10.0.6/24 n2 e0a false n2_clus3 up/up 10.10.0.7/24 n2 e0d false n2_clus4 up/up 10.10.0.8/24 n2 e0d true 8 entries were displayed. -
關閉與交換器 CL2 實體連線的叢集互連連接埠:
network port modify顯示範例
以下命令關閉 n1 和 n2 上的指定端口,但必須關閉所有節點上的端口:
cluster::*> network port modify -node n1 -port e0b -up-admin false cluster::*> network port modify -node n1 -port e0c -up-admin false cluster::*> network port modify -node n2 -port e0b -up-admin false cluster::*> network port modify -node n2 -port e0c -up-admin false
驗證遠端集群介面的連接性:
你可以使用 `network interface check cluster-connectivity`執行命令以啟動叢集連接性檢查,然後顯示詳細資訊:
network interface check cluster-connectivity start`和 `network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
*注意:*在執行 show 命令顯示詳細資訊之前,請等待幾秒鐘。
cluster1::*> network interface check cluster-connectivity show
Source Destination Packet
Node Date LIF LIF Loss
n1
3/5/2022 19:21:18 -06:00 n1_clus2 n2_clus1 none
3/5/2022 19:21:20 -06:00 n1_clus2 n2_clus2 none
n2
3/5/2022 19:21:18 -06:00 n2_clus2 n1_clus1 none
3/5/2022 19:21:20 -06:00 n2_clus2 n1_clus2 none
對於所有ONTAP版本,您也可以使用 `cluster ping-cluster -node <name>`檢查連接性的命令:
cluster::*> cluster ping-cluster -node n1
Host is n1
Getting addresses from network interface table...
Cluster n1_clus1 n1 e0a 10.10.0.1
Cluster n1_clus2 n1 e0b 10.10.0.2
Cluster n1_clus3 n1 e0c 10.10.0.3
Cluster n1_clus4 n1 e0d 10.10.0.4
Cluster n2_clus1 n2 e0a 10.10.0.5
Cluster n2_clus2 n2 e0b 10.10.0.6
Cluster n2_clus3 n2 e0c 10.10.0.7
Cluster n2_clus4 n2 e0d 10.10.0.8
Local = 10.10.0.1 10.10.0.2 10.10.0.3 10.10.0.4
Remote = 10.10.0.5 10.10.0.6 10.10.0.7 10.10.0.8
Cluster Vserver Id = 4294967293
Ping status:....
Basic connectivity succeeds on 16 path(s)
Basic connectivity fails on 0 path(s)
Detected 1500 byte MTU on 16 path(s):
Local 10.10.0.1 to Remote 10.10.0.5
Local 10.10.0.1 to Remote 10.10.0.6
Local 10.10.0.1 to Remote 10.10.0.7
Local 10.10.0.1 to Remote 10.10.0.8
Local 10.10.0.2 to Remote 10.10.0.5
Local 10.10.0.2 to Remote 10.10.0.6
Local 10.10.0.2 to Remote 10.10.0.7
Local 10.10.0.2 to Remote 10.10.0.8
Local 10.10.0.3 to Remote 10.10.0.5
Local 10.10.0.3 to Remote 10.10.0.6
Local 10.10.0.3 to Remote 10.10.0.7
Local 10.10.0.3 to Remote 10.10.0.8
Local 10.10.0.4 to Remote 10.10.0.5
Local 10.10.0.4 to Remote 10.10.0.6
Local 10.10.0.4 to Remote 10.10.0.7
Local 10.10.0.4 to Remote 10.10.0.8
Larger than PMTU communication succeeds on 16 path(s)
RPC status:
4 paths up, 0 paths down (tcp check)
4 paths up, 0 paths down (udp check)
關閉活動 Nexus 5596 交換器 CL1 上的 ISL 連接埠 41 至 48:
顯示範例
以下範例展示如何關閉 Nexus 5596 交換器 CL1 上的 ISL 連接埠 41 至 48:
(CL1)# configure (CL1)(Config)# interface e1/41-48 (CL1)(config-if-range)# shutdown (CL1)(config-if-range)# exit (CL1)(Config)# exit (CL1)#
如果您要更換 Nexus 5010 或 5020,請指定 ISL 的對應連接埠號碼。
在 CL1 和 C2 之間建立臨時 ISL。
顯示範例
以下範例展示如何在 CL1 和 C2 之間建立臨時 ISL:
C2# configure C2(config)# interface port-channel 2 C2(config-if)# switchport mode trunk C2(config-if)# spanning-tree port type network C2(config-if)# mtu 9216 C2(config-if)# interface breakout module 1 port 24 map 10g-4x C2(config)# interface e1/24/1-4 C2(config-if-range)# switchport mode trunk C2(config-if-range)# mtu 9216 C2(config-if-range)# channel-group 2 mode active C2(config-if-range)# exit C2(config-if)# exit
做好交換器遷移準備後,您可以…"配置您的連接埠" 。
