準備從 CN1610 交換器遷移到 3232C 交換機
請依照下列步驟準備將 CN1610 交換器遷移到Cisco Nexus 3232C 交換器。
如果此叢集上啟用了AutoSupport ,則透過呼叫AutoSupport訊息來抑制自動建立案例:
system node autosupport invoke -node * -type all -message MAINT=xhx 是維護視窗的持續時間,單位為小時。
此訊息通知技術支援部門此維護任務,以便在維護期間禁止自動建立案例。
顯示配置中設備的資訊:
network device-discovery show顯示範例
以下範例顯示了每個節點上每個叢集互連交換器配置的叢集互連連接口數量:
cluster::> network device-discovery show Local Discovered Node Port Device Interface Platform ------ ------ ------------ ----------- ---------- n1 /cdp e0a CL1 0/1 CN1610 e0b CL2 0/1 CN1610 e0c CL2 0/2 CN1610 e0d CL1 0/2 CN1610 n2 /cdp e0a CL1 0/3 CN1610 e0b CL2 0/3 CN1610 e0c CL2 0/4 CN1610 e0d CL1 0/4 CN1610 8 entries were displayed. -
確定每個叢集介面的管理或運作狀態。
顯示集群網路連接埠屬性:
network port show -role cluster顯示範例
cluster::*> network port show -role cluster (network port show) Node: n1 Broadcast Speed (Mbps) Health Ignore Port IPspace Domain Link MTU Admin/Open Status Health Status ----- --------- ---------- ----- ----- ------------ ------ ------------- e0a cluster cluster up 9000 auto/10000 - e0b cluster cluster up 9000 auto/10000 - e0c cluster cluster up 9000 auto/10000 - - e0d cluster cluster up 9000 auto/10000 - - Node: n2 Broadcast Speed (Mbps) Health Ignore Port IPspace Domain Link MTU Admin/Open Status Health Status ----- --------- ---------- ----- ----- ------------ ------ ------------- e0a cluster cluster up 9000 auto/10000 - e0b cluster cluster up 9000 auto/10000 - e0c cluster cluster up 9000 auto/10000 - e0d cluster cluster up 9000 auto/10000 - 8 entries were displayed. -
顯示邏輯介面資訊:
network interface show -role cluster顯示範例
cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home -------- ---------- ----------- -------------- -------- -------- ----- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e0a true n1_clus2 up/up 10.10.0.2/24 n1 e0b true n1_clus3 up/up 10.10.0.3/24 n1 e0c true n1_clus4 up/up 10.10.0.4/24 n1 e0d true n2_clus1 up/up 10.10.0.5/24 n2 e0a true n2_clus2 up/up 10.10.0.6/24 n2 e0b true n2_clus3 up/up 10.10.0.7/24 n2 e0c true n2_clus4 up/up 10.10.0.8/24 n2 e0d true 8 entries were displayed. -
顯示已發現的群集交換器的相關資訊:
system cluster-switch show
顯示範例
以下範例顯示了叢集已知的叢集交換器及其管理 IP 位址:
cluster::> system cluster-switch show Switch Type Address Model ----------------------------- ---------------- ------------- -------- CL1 cluster-network 10.10.1.101 CN1610 Serial Number: 01234567 Is Monitored: true Reason: Software Version: 1.2.0.7 Version Source: ISDP CL2 cluster-network 10.10.1.102 CN1610 Serial Number: 01234568 Is Monitored: true Reason: Software Version: 1.2.0.7 Version Source: ISDP 2 entries displayed. -
確認已根據您的要求在新 3232C 交換器上安裝了相應的 RCF 和映像,並進行任何必要的網站自訂。
此時您應該準備好這兩台交換器。如果需要升級 RCF 和鏡像,則必須完成以下步驟:
看"Cisco乙太網路交換機"在NetApp支援網站上。
請記下您交換器的型號以及該頁表格中所需的軟體版本。
下載相應版本的RCF。
在“描述”頁面上選擇“繼續”,接受許可協議,然後按照“下載”頁面上的說明下載 RCF。
請從以下網址下載對應版本的影像處理軟體:"Cisco叢集和管理網路交換器參考設定檔下載" 。
遷移與計畫替換的第二個 CN1610 交換器關聯的 LIF:
network interface migrate -vserver vserver-name -lif lif-name -source-node source-node-name destination-node destination-node-name -destination-port destination-port-name顯示範例
您必須按照以下範例所示,逐一遷移每個 LIF:
cluster::*> network interface migrate -vserver cluster -lif n1_clus2 -source-node n1 -destination-node n1 -destination-port e0a cluster::*> network interface migrate -vserver cluster -lif n1_clus3 -source-node n1 -destination-node n1 -destination-port e0d cluster::*> network interface migrate -vserver cluster -lif n2_clus2 -source-node n2 -destination-node n2 -destination-port e0a cluster::*> network interface migrate -vserver cluster -lif n2_clus3 -source-node n2 -destination-node n2 -destination-port e0d
驗證集群健康狀況:
cluster::*> network interface show -role cluster (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home -------- ---------- ----------- --------------- -------- -------- ----- Cluster n1_clus1 up/up 10.10.0.1/24 n1 e0a true n1_clus2 up/up 10.10.0.2/24 n1 e0a false n1_clus3 up/up 10.10.0.3/24 n1 e0d false n1_clus4 up/up 10.10.0.4/24 n1 e0d true n2_clus1 up/up 10.10.0.5/24 n2 e0a true n2_clus2 up/up 10.10.0.6/24 n2 e0a false n2_clus3 up/up 10.10.0.7/24 n2 e0d false n2_clus4 up/up 10.10.0.8/24 n2 e0d true 8 entries were displayed.
做好交換器遷移準備後,您可以…"將 CN1610 交換器 CL2 更換為 3232C 交換器 C2" 。
