VSS申請人-備份元件失敗、並出現部分寫入錯誤
訊息
Error: Vss Requestor - Backup Components failed with partial writer error. Writer Microsoft Hyper-V VSS Writer involved in backup or restore operation reported partial failure. Writer returned failure code 0x80042336. Writer state is 5. Application specific error information: Application error code: 0x1 Application error message: - Failed component information: Failed component: VM GUID XXX Writer error code: 0x800423f3 Application error code: 0x8004230f Application error message: Failed to revert to VSS snapshot on the virtual hard disk 'volume_guid' of the virtual machine 'vm_name'. (Virtual machine ID XXX)Hyper-V主機上的Windows應用程式事件記錄中會出現下列錯誤:
Volume Shadow Copy Service error: Unexpected error calling routine GetOverlappedResult. hr = 0x80070057, The parameter is incorrect. Operation: Revert a Shadow Copy Context: Execution Context: System Provider Volume Shadow Copy Service error: Error calling a routine on a Shadow Copy Provider {b5946137-7b9f-4925-af80-51abd60b20d5}. Routine details RevertToSnapshot [hr = 0x80042302, A Volume Shadow Copy Service component encountered an unexpected error. Check the Application event log for more information.]. Operation: Revert a Shadow Copy Context: Execution Context: Coordinator -
說明
執行資料集的應用程式一致備份時、會出現此訊息。此錯誤會導致資料集中部分虛擬機器的備份失敗。
修正行動
重試資料集備份。
如果重試嘗試再次失敗、請將資料集分割成兩個資料集、以便將備份失敗的所有VM放入單一資料集、所有其他VM都會放入另一個資料集。然後再次執行備份。
