Cluster capacity fields
PDF of this doc site
- Online Help
- Monitor and manage cluster performance
- Monitor and manage cluster health
Creating your file...
The following fields are available in the Capacity: All Clusters view and can be used in custom views and in reports.
Cluster
The cluster name. You can click the cluster name to navigate to that cluster's capacity details page.
Cluster FQDN
The fully qualified domain name (FQDN) of the cluster.
HA Pair
The HA pair value obtained by forming two nodes.
Total Raw Capacity
Displays the total physical capacity of all disks in the array.
Unconfigured Raw Capacity
The unconfigured capacity of disks whose container type is other than aggregate, broken, spare, or shared. This capacity is always higher than the physical capacity of the disk in ONTAP. For example, consider a 2 TB disk. The physical capacity of the disk is 1.6 TB in ONTAP whereas the unconfigured raw capacity in Unified Manager is 1.8 TB.
Aggregate Total Capacity
The total size of the available aggregates for the user. This includes the Snapshot copy reserve.
Aggregate Used Capacity
The capacity already in use on aggregates. This includes the capacity consumed by volumes, LUNs, and other storage efficiency technology overheads.
Aggregate Unused Capacity
The capacity that might be available for storing additional data on the aggregate. This includes the Snapshot copy reserve.
Logical Space Used
The real size of the data that is being stored on all aggregates on this cluster without applying the savings from using ONTAP storage efficiency technologies.
Allocated LUN Capacity
The capacity of LUNs that are mapped.
Unallocated LUN Capacity
The capacity of all LUNs not mapped to the Host.
Volume Total Capacity
The total capacity of the volumes (used plus unused).
Volume Used Capacity
The used capacity of the volumes.
Volume Unused Capacity
The unused capacity of the volumes.
Volume Protection Capacity
The capacity of volumes that have SnapMirror and SnapVault enabled.
Cluster Licensed Cloud Tier Used
The space used by data in the cloud tier for storage providers that require a FabricPool license.
Cluster StorageGRID Capacity Used
The space used by data in the cloud tier for StorageGRID systems that do not require a FabricPool license.
Model/Family
The model or family name of the cluster.
OS Version
The version of ONTAP installed on the system.
Contact
The contact information of the cluster.
Location
The location of the cluster.
