Group action-volume thresholds section
PDF of this doc site
- Online Help
- Monitor and manage cluster performance
- Monitor and manage cluster health
Creating your file...
The group action-volume thresholds section enables you to configure group-level health thresholds for volumes. These thresholds are applied to all the volumes in a group. When the volume health thresholds are configured at the group level, the global health threshold values are not affected.
You can configure volume health thresholds for the following to configure a group action:
Capacity
Growth
Qtree quota
Snapshot copies
Inodes
Global default values are used if volume health thresholds are not configured for any of these categories. You can set health thresholds for the following:
Capacity
Growth
Qtree quota
Snapshot copies
Inodes
Capacity section
You can set conditions for the following volume capacity health thresholds:
Space Nearly Full
Specifies the percentage at which a volume is considered to be nearly full:
Default value: 80 percent
The value for this threshold must be lower than the value for the Volume Full threshold for the management server to generate an event.
Event generated: Volume Nearly Full
Event severity: Warning
Space Full
Specifies the percentage at which a volume is considered full:
Default value: 90 percent
Event generated: Volume Full
Event severity: Error
Overcommitted
Specifies the percentage at which a volume is considered to be overcommitted:
Default value: 100 percent
Event generated: Volume Overcommitted
Growth section
You can set the following health threshold conditions for volume growth:
Growth Rate
Specifies the percentage at which a volume's growth rate is considered to be normal before the system generates a Volume Growth Rate Abnormal event:
Default value: 1 percent
Event generated: Volume Growth Rate Abnormal
Growth Rate Sensitivity
Specifies the factor that is applied to the standard deviation of a volume's growth rate. If the growth rate exceeds the factored standard deviation, a Volume Growth Rate Abnormal event is generated.
A lower value for growth rate sensitivity indicates that the aggregate is highly sensitive to changes in the growth rate. The range for the growth rate sensitivity is 1 through 5.
Default value: 2
Qtree Quota section
You can set the following health threshold conditions for volume quotas:
Nearly Overcommitted
Specifies the percentage at which a volume is considered to be nearly overcommitted by qtree quotas:
Default value: 95 percent
Event generated: Volume Qtree Quota Nearly Overcommitted
Overcommitted
Specifies the percentage at which a volume is considered to be overcommitted by qtree quotas:
Event generated: Volume Qtree Quota Overcommitted
Snapshot Copies section
You can set the following health threshold conditions for the Snapshot copies in the volume:
Snapshot Reserve Full
Specifies the percentage at which the space reserved for Snapshot copies is considered full:
Event generated: Volume Snapshot Reserve Full
Days Until Full
Specifies the number of days remaining before the space reserved for Snapshot copies reaches full capacity:
Default value: 7
Event generated: Volume Snapshot Reserve Days Until Full
Count
Specifies the number of Snapshot copies on a volume that are considered to be too many:
Default value: 250
Event generated: Too Many Snapshot Copies
Inodes section
You can set the following health threshold conditions for inodes:
Nearly Full
Specifies the percentage at which a volume is considered to have consumed most of its inodes:
Event generated: Inodes Nearly Full
Full
Specifies the percentage at which a volume is considered to have consumed all of its inodes:
Event generated: Inodes Full
