Active IQ Unified Manager 9.8
9.8
Group action-volume thresholds section
The group action-volume thresholds section enables you to configure group-level health thresholds for volumes. These thresholds are applied to all the volumes in a group. When the volume health thresholds are configured at the group level, the global health threshold values are not affected.
You can configure volume health thresholds for the following to configure a group action:
  • Capacity
  • Growth
  • Qtree quota
  • Snapshot copies
  • Inodes
Global default values are used if volume health thresholds are not configured for any of these categories. You can set health thresholds for the following:
  • Capacity
  • Growth
  • Qtree quota
  • Snapshot copies
  • Inodes
Capacity section
You can set conditions for the following volume capacity health thresholds:
  • Space Nearly Full
    Specifies the percentage at which a volume is considered to be nearly full:
    • Default value: 80 percent
      The value for this threshold must be lower than the value for the Volume Full threshold for the management server to generate an event.
    • Event generated: Volume Nearly Full
    • Event severity: Warning
  • Space Full
    Specifies the percentage at which a volume is considered full:
    • Default value: 90 percent
    • Event generated: Volume Full
    • Event severity: Error
  • Overcommitted
    Specifies the percentage at which a volume is considered to be overcommitted:
    • Default value: 100 percent
    • Event generated: Volume Overcommitted
Growth section
You can set the following health threshold conditions for volume growth:
  • Growth Rate
    Specifies the percentage at which a volume's growth rate is considered to be normal before the system generates a Volume Growth Rate Abnormal event:
    • Default value: 1 percent
    • Event generated: Volume Growth Rate Abnormal
  • Growth Rate Sensitivity
    Specifies the factor that is applied to the standard deviation of a volume's growth rate. If the growth rate exceeds the factored standard deviation, a Volume Growth Rate Abnormal event is generated.
    A lower value for growth rate sensitivity indicates that the aggregate is highly sensitive to changes in the growth rate. The range for the growth rate sensitivity is 1 through 5.
    • Default value: 2
Qtree Quota section
You can set the following health threshold conditions for volume quotas:
  • Nearly Overcommitted
    Specifies the percentage at which a volume is considered to be nearly overcommitted by qtree quotas:
    • Default value: 95 percent
    • Event generated: Volume Qtree Quota Nearly Overcommitted
  • Overcommitted
    Specifies the percentage at which a volume is considered to be overcommitted by qtree quotas:
    • Event generated: Volume Qtree Quota Overcommitted
Snapshot Copies section
You can set the following health threshold conditions for the Snapshot copies in the volume:
  • Snapshot Reserve Full
    Specifies the percentage at which the space reserved for Snapshot copies is considered full:
    • Event generated: Volume Snapshot Reserve Full
  • Days Until Full
    Specifies the number of days remaining before the space reserved for Snapshot copies reaches full capacity:
    • Default value: 7
    • Event generated: Volume Snapshot Reserve Days Until Full
  • Count
    Specifies the number of Snapshot copies on a volume that are considered to be too many:
    • Default value: 250
    • Event generated: Too Many Snapshot Copies
Inodes section
You can set the following health threshold conditions for inodes:
  • Nearly Full
    Specifies the percentage at which a volume is considered to have consumed most of its inodes:
    • Event generated: Inodes Nearly Full
  • Full
    Specifies the percentage at which a volume is considered to have consumed all of its inodes:
    • Event generated: Inodes Full
