HTTPS Certificate page
PDF of this doc site
- Online help
- Monitor and manage cluster performance
- Monitor and manage cluster health
Creating your file...
The HTTPS Certificate page enables you to view the current security certificate, download a certificate signing request, generate a new HTTPS certificate, or install a new HTTPS certificate.
If you have not generated a new HTTPS certificate, the certificate that appears on this page is the certificate that was generated during installation.
Command buttons
The command buttons enable you to perform the following operations:
Download HTTPS Certificate Signing Request
Downloads a certification request for the currently installed HTTPS certificate. Your browser prompts you to save the
<hostname>.csr
file so that you can provide the file to a Certificate Authority to sign. -
Install HTTPS Certificate
Enables you to upload and install a security certificate after a Certificate Authority has signed and returned it. The new certificate is in effect after you restart the management server.
Regenerate HTTPS Certificate
Enables you to generate an HTTPS certificate, which replaces the current security certificate. The new certificate is in effect after you restart Unified Manager.
