Active IQ Unified Manager
9.7
HTTPS Certificate page
The HTTPS Certificate page enables you to view the current security certificate, download a certificate signing request, generate a new HTTPS certificate, or install a new HTTPS certificate.
If you have not generated a new HTTPS certificate, the certificate that appears on this page is the certificate that was generated during installation.
Command buttons
The command buttons enable you to perform the following operations:
  • Download HTTPS Certificate Signing Request
    Downloads a certification request for the currently installed HTTPS certificate. Your browser prompts you to save the <hostname>.csr file so that you can provide the file to a Certificate Authority to sign.
  • Install HTTPS Certificate
    Enables you to upload and install a security certificate after a Certificate Authority has signed and returned it. The new certificate is in effect after you restart the management server.
  • Regenerate HTTPS Certificate
    Enables you to generate an HTTPS certificate, which replaces the current security certificate. The new certificate is in effect after you restart Unified Manager.
