BlueXP classification
Supported BlueXP classification instance types
Contributors netapp-tonacki
BlueXP classification software must run on a host that meets specific operating system requirements, RAM requirements, software requirements, and so on. When deploying BlueXP classification in the cloud, we recommend that you use a system with the "large" characteristics for full functionality.
You can deploy BlueXP classification on a system with fewer CPUs and less RAM, but there are some limitations when using these less powerful systems. Learn about these limitations.
In the following tables, if the system marked as "default" is not available in the region where you are installing BlueXP classification, the next system in the table will be deployed.
AWS instance types
System size Specs Instance type
Extra Large
32 CPUs, 128 GB RAM, 1 TiB gp3 SSD
m6i.8xlarge (default)
Large
16 CPUs, 64 GB RAM, 500 GiB SSD
m6i.4xlarge (default)
m6a.4xlarge
m5a.4xlarge
m5.4xlarge
m4.4xlarge
Medium
8 CPUs, 32 GB RAM, 200 GiB SSD
m6i.2xlarge (default)
m6a.2xlarge
m5a.2xlarge
m5.2xlarge
m4.2xlarge
Small
8 CPUs, 16 GB RAM, 100 GiB SSD
c6a.2xlarge (default)
c5a.2xlarge
c5.2xlarge
c4.2xlarge
Azure instance types
Extra Large
32 CPUs, 128 GB RAM, OS Disk (2,048 GiB, min 250 MB/s throughput), and Data Disk (1 TiB SSD, min 750 MB/s throughput)
Standard_D32_v3 (default)
Large
Standard_D16s_v3 (default)
GCP instance types
Large
n2-standard-16 (default)
n2d-standard-16
n1-standard-16
